Home » Newcomers » Newcomers » Link errors running VTK java pplication with Eclipse
Link errors running VTK java pplication with Eclipse [message #93544] Tue, 09 August 2005 12:19
Originally posted by: skslimjim.aol.com
Hoping to find someone with experience using the Visualization
Toolkit(VTK)and Eclipse. Program works with another IDE with no change to
envi variables listed below.
Been struggling with this error when executing the test
program--simplevtk.java
Exception in thread "AWT-EventQueue-0" java.lang.UnsatisfiedLinkError:
RenderCreate
at vtkPanel.RenderCreate(Native Method)
at vtkPanel.Render(vtkPanel.java:139)
at vtkPanel.paint(vtkPanel.java:159)
at sun.awt.RepaintArea.paintComponent(Unknown Source)
at sun.awt.RepaintArea.paint(Unknown Source)
at sun.awt.windows.WComponentPeer.handleEvent(Unknown Source)
at java.awt.Component.dispatchEventImpl(Unknown Source)
at java.awt.Component.dispatchEvent(Unknown Source)
at java.awt.EventQueue.dispatchEvent(Unknown Source)
at java.awt.EventDispatchThread.pumpOneEventForHierarchy(Unknow n Source)
at java.awt.EventDispatchThread.pumpEventsForHierarchy(Unknown Source)
at java.awt.EventDispatchThread.pumpEvents(Unknown Source)
at java.awt.EventDispatchThread.run(Unknown Source)
Tried:
CLASSPATH = .;%JAVA_HOME%\lib\classes.zip;C:\Program
Files\vtk42\bin\;C:\Program Files\vtk42\bin\vtk.jar;C:\Program
Files\vtk42\lib\vtk;C:\Program Files\vtk42\lib
Path = ...;%JAVA_HOME%\bin;%JAVA_HOME%\jre\bin;c:\GLF;C:\Program
In the Ecllipse Run window Selected the Arguments tab. In the VM Arguments
area created variable -Djava.library.path set to C:\Program
Files\vtk42\bin\ Then tried setting to C:\Program
Files\vtk42\lib;;C:\j2sdk1.4.2_08\lib;C:\j2sdk1.4.2_08\lib\j awt.lib
This causes Java VM Launcher to crash--
Message window--" Can't find Main Class"
Console reports--java.lang.NoClassDefFoundError: C:\Program Exception in
thread "main"
Later, tried adding to CLASSPATH and Path----
C:\j2sdk1.4.2_08\lib;C:\j2sdk1.4.2_08\lib\jawt.lib
What else can I do?
Previous Topic:looking for editable format of images that used in eclipse
Next Topic:Profiling Remote java application
Current Time: Wed Aug 13 14:21:59 EDT 2025
Powered by FUDForum. Page generated in 0.08721 seconds
