Home » Archived » SeMantic Information Logistics Architecture (SMILA) » Exception when using Numeric Fields / Patch
Exception when using Numeric Fields / Patch [message #751] Thu, 26 February 2009 09:17 Go to next message
Hi again,
sorry - always reporting about bugs here. ;)
see https://bugs.eclipse.org/bugs/show_bug.cgi?id=266264
Hope that you can use my provided patch.
Andreas
Re: Exception when using Numeric Fields / Patch [message #756 is a reply to message #751] Fri, 27 February 2009 03:28 Go to previous message
Thanks Andreas,
every found bug is a good bug :-) So keep on the good work.
I will have a look into this issue after we have merged the new crawler
api back to trunk.
Bye,
Daniel
Re: Exception when using Numeric Fields / Patch [message #563943 is a reply to message #751] Fri, 27 February 2009 03:28 Go to previous message
Thanks Andreas,
api back to trunk.
Bye,
Daniel
Previous Topic:Exception when using Numeric Fields / Patch
Next Topic:Login details for SVN
Current Time: Sat Jul 12 14:16:22 EDT 2025
Powered by FUDForum. Page generated in 0.05959 seconds
