Home » Eclipse Projects » Eclipse Platform » Decorator problem
Decorator problem [message #93519] Mon, 14 July 2003 18:34 Go to next message
Originally posted by: lfu.site.uottawa.ca
I am new to eclipse and have been struglling with a decorator problem.
I have a tree displaying some simple TreeObject(name,full name,etc), but
When I use objectClass in enablement to decorate with tree node(TreeObject),
like <enablement>
<objectClass="org.kbre.treeviewer.views.TreeObject"/><enablement >. No
decoration effected, while if I can to
<objectClass="org.eclipse.core.resources.IFile">, decoration in other views
work fine.
Does decoration only work to IResource type, not user defined ones?
Eric Fu
Re: Decorator problem [message #94949 is a reply to message #93519] Wed, 16 July 2003 10:45 Go to previous messageGo to next message
I believe that is correct, and that you need to have your daa-object implement
IAdaptable, like this:
public Object getAdapter (final Class adapter) {
return (adapter == IResource.class)
? getTheFileFor(this.getDataObject()) // it may be hat
getDataObject() returns "this"
: null;
HTH,
Paul K
Eric Fu wrote:
> like <enablement>
> work fine.
> Thanks
> Eric Fu
Re: Decorator problem [message #144845 is a reply to message #94949] Thu, 16 October 2003 07:57 Go to previous message
Originally posted by: rich.boakes.com
In his original post Eric described the exact problem that's stumping me
today.
I too have a TreeViewer which contains instances of a INode class (which
extends IAdaptable).
My (lightweight) decorator class works perfectly in other views when I
enable it for IResource objects, yet it does nothing for these INodes in
my tree view.
Paul's solution below looked promising, so I put trace in the
INode.getAdapter method to see if I could work out what I needed to do
to use it. This showed that it's only getting called when I popup a
context menu on the INodes, so I'm wondering what exactly I'm supposed
to be listening for / returning.
It seems to me that there must be some fundamental step that I'm
missing, perhaps some connection to a listener, or an initialization step?
I think I've been through every article, relevant newsgroup posting and
the javadoc and come up blank.
Has *anyone* managed to get an ILightweightLabelDecorator to work with
anything other than an IResource?
cheers,
Rich
> : null;
> HTH,
> Paul K
> Eric Fu wrote:
>>Hi,
>>like <enablement>
>>work fine.
>>Thanks
>>Eric Fu
Previous Topic:How to contribute resources
Next Topic:IDocument locs workspace while being connected to FileInputStream
Current Time: Thu Jul 17 23:52:35 EDT 2025
Powered by FUDForum. Page generated in 0.03515 seconds
