Problem with agent controllers using TPTP under Vista [message #93510] |
Wed, 14 March 2007 14:32  |
Originally posted by: andrew.chapman.brighterworking.com
I've installed the latest Eclipse (Version: 3.2.2
Build id: M20070212-1330) and TPTP (all components are 4.1.1 or later).
If I go into preferences->profiling....->hosts and try to do "Test
Connection" for the Local Direct Connection I get:
"The Remote Agent Controller(RAC) is currently running. You need to stop
the Remote Agent Controller before activating the Local Direct
Connection, or select localhost instead of Local Direct Connection."
If I do "Test Connection" for localhost:10002 (the only other host) I get:
"Connection failed on host localhost.
Reason:
IWAT0284E The agent controller is not available on host localhost."
(and so on)
Also, if I go into the agent controller preferences, there is only the
integrated agent controller and everything on the settings for it is
greyed out.
I haven't installed the RAC as far as I am aware (I even searched my
whole machine for ACServer.exe just to make sure).
I get the same behaviour with Windows firewall turned off.
I get the same behaviour with Eclipse set to "Run as administrator" or not.
The user I run Eclipse as has administrator privileges on Vista.
Any ideas what is going on and how to fix it? I am pretty sure it's a
Vista problem as I was happily using TPTP on my XP box previously.
Cheers
Andy
Re: Problem with agent controllers using TPTP under Vista [message #93609 is a reply to message #93540] |
Thu, 15 March 2007 22:44   |
Originally posted by: wohlgemuth.ucdavis.edu
as sad as it is i'm fighting with the exact same problem since 2 days.
my specifications:
1. eclipse 3.2.1
- calissto installed TPDP
- 32 bit windowx vista (dual core centrino)
2. eclipse 3.2.1
- 64bit gentoo linux on intel EMT64 (old xeons netburst technologie)
i run in the same message and have no idea what todo and would love to be
pointed in the right direction. I reinstalled eclipse several time, used
different user accounds, created several workspaces. Reinstalled the linux
box.
The error message i got:
dear eclipse team please help us, we are sure you know a solution!
regards gert wohlgemuth
"Andy Chapman" <andrew.chapman@brighterworking.com> wrote in message
news:etbakg$q9d$1@utils.eclipse.org...
>> get:
>> Reason:
>> (and so on)
>> greyed out.
>> not.
>> Cheers
>> Andy
> A little extra information. Having read back through the newsgroup (this
> seems to be a common symptom with various causes), I have gone back to
> J2SE1.5.0_11 (I uninstalled 1.6 just to be sure). So, Eclipse is now
> running in the 1.5.0_11 JRE and I've changed the settings for the IAC to
> the same.
> No change.
Re: Problem with agent controllers using TPTP under Vista [message #93669 is a reply to message #93609] |
Fri, 16 March 2007 17:05   |
today I checked it with a 32 bit windows XP and the problem doesn't exist.
any ideas?
does the RAC server generate a pid file somewhere? And if yes where?
"gert wohlgemuth" <wohlgemuth@ucdavis.edu> wrote in message
news:etd0aq$uns$1@utils.eclipse.org...
> my specifications:
> 1. eclipse 3.2.1
> 2. eclipse 3.2.1
> box.
>>> get:
>>> Reason:
>>> (and so on)
>>> greyed out.
>>> not.
>>> Cheers
>>> Andy
>> the same.
>> No change.
Re: Problem with agent controllers using TPTP under Vista [message #95988 is a reply to message #95654] |
Mon, 16 April 2007 09:09  |
Brilliant. Just did a software update and got the TPTP patches. Fixed
the problem straight away.
Cheers
Andy
Paul Slauenwhite wrote:
> Hi Andy,
> Samson Wai from the TPTP Platform Team has provide the following
> response:
> This seems to be related to the following Vista-specific bugs:
> https://bugs.eclipse.org/bugs/show_bug.cgi?id=176074
> https://bugs.eclipse.org/bugs/show_bug.cgi?id=176744
> https://bugs.eclipse.org/bugs/show_bug.cgi?id=176745
> The manifest file for the IAC fragment failed to load on some JDKs.
> Also, make sure Eclipse is started as Administrator or otherwise IAC will
> not be able to create shared memory.
> Paul
> news:et9f4q$j03$1@utils.eclipse.org...
>> Build id: M20070212-1330) and TPTP (all components are 4.1.1 or later). If
>> the Remote Agent Controller before activating the Local Direct Connection,
>> Reason:
>> (and so on)
>> greyed out.
>> I haven't installed the RAC as far as I am aware (I even searched my whole
>> not.
>> Cheers
>> Andy
FUDForum. Page generated in 0.06851 seconds
