Eclipse/ANT problem with javac task [message #93430] |
Mon, 14 July 2003 16:05  |
Hello everyone,
since a few weeks I keep getting the attached error message if I invoke
a javac ant task from within Eclipse on my WinXP system. It happens with
versions 2.1 and 2.1.1.
I can't remember what configuration I have been fooling around.
However, I double-checked:
- JAVA_HOME is indeed defined (as a system environment variable).
- The correct JARs are included in the Ant classpath
(Preferences->Ant->Runtime->Classes).
What else should I check?
Now here is the error message:
compile:
[copy] Copying 1 file to C:\eclipse\workspace\xxx\build\classes
[javac] Compiling 1 source file to
[javac] BUILD FAILED:
file:C:/eclipse/workspace/xxx/build.xml:27: Unable to find a javac compiler;
com.sun.tools.javac.Main is not on the classpath.
Perhaps JAVA_HOME does not point to the JDK
Andreas
Re: Eclipse/ANT problem with javac task [message #95601 is a reply to message #93430] |
Thu, 17 July 2003 06:15  |
Originally posted by: veith.pixel.de
hi,
I got this "feature" too, some time ago. The point is, eclipse does not
use the runtime, you've specified by java_home but the jre that has
set the registry entry (under windows) JavaHome. A jre does not contain
any compilers. You can force eclipse to use the runtime under java_home:
-vm %java_home%/bin/javaw.exe
Gernot
Andreas Schildbach wrote:
> Hello everyone,
> compile:
> [javac] BUILD FAILED: file:C:/eclipse/workspace/xxx/build.xml:27:
> Andreas
FUDForum. Page generated in 0.06125 seconds
