Home » Language IDEs » C / C++ IDE (CDT) » c / c++
c / c++ [message #93413] Wed, 04 February 2004 21:27 Go to next message
Originally posted by: rkharrazi.hotmail.com
Hi all,
Can somebody please walk me through on how to install the c / c++ component
for the eclipse.
thankx
Andrew
Re: c / c++ [message #93443 is a reply to message #93413] Wed, 04 February 2004 23:04 Go to previous message
Hi.
To install cdt for every user, unzip the cdt-full-1.2-linux-gtk.zip (or
whatever version you may have downloaded) in your [eclipse_home]/plugins
directory (I would check the contents of the zip files if the path is
correct. I believe in this case eclipse/plugins is even in the zip file,
so you need to unzip this file in [eclipse_home]/../)
To install for a single user, unzip it in the user's home directory.
An alternate way is to check
http://dev.eclipse.org/viewcvs/index.cgi/%7Echeckout%7E/cdt- home/downloads/main.html?cvsroot=Tools_Project
to see which URL you want to add to the update manager. But AFAIK you
can only install for a single user via the update manager (at least on
linux).
Matthijs.
Reza Andrew wrote:
> Hi all,
> for the eclipse.
> thankx
> Andrew
Previous Topic:post build steps?
Next Topic:Parsing compile error msgs
Current Time: Mon Sep 01 01:11:41 EDT 2025
Powered by FUDForum. Page generated in 0.06628 seconds
