Home » Eclipse Projects » Eclipse Platform » problems starting eclipse
problems starting eclipse [message #93373] Mon, 14 July 2003 14:27
Originally posted by: David.Knittle.siemens.com
when starting eclipse, the splash screen shows, then very briefly, the
frames for the application show, then i get the old exception message. it is
using the correct JRE, based on the screen. I tried both the JRE, and the
JDK using the -vm option. I also put the JRE ahead of system32 in my path.
same problem.
here are the last parts of my log file
An unexpected exception has been detected in native code outside the VM.
Unexpected Signal : EXCEPTION_ACCESS_VIOLATION (0xc0000005) occurred at
PC=0x77D68E45
Function=MapVirtualKeyExW+0x26
Library=C:\WINDOWS\system32\USER32.dll
Current Java thread:
at org.eclipse.swt.internal.win32.OS.DrawTextW(Native Method)
at org.eclipse.swt.internal.win32.OS.DrawText(OS.java:1313)
at org.eclipse.swt.graphics.GC.drawText(GC.java:1242)
at org.eclipse.swt.graphics.GC.drawText(GC.java:1194)
at org.eclipse.swt.custom.CLabel.onPaint(CLabel.java:380)
at org.eclipse.swt.custom.CLabel.access$0(CLabel.java:287)
at org.eclipse.swt.custom.CLabel$1.paintControl(CLabel.java:102 )
I am running XP media center edition. I ran through a few of the sample sin
the JDK, thinking there may be a problem with my install, but everything
seems ok.
Previous Topic:Editor lose of focus
Next Topic:Bug using prefixes in plugin.xml?
Current Time: Sat Aug 30 20:20:39 EDT 2025
Powered by FUDForum. Page generated in 0.02147 seconds
