Home » Eclipse Projects » Eclipse Platform » removing workbench menus throws NPE
removing workbench menus throws NPE [message #93330] Mon, 14 July 2003 13:53 Go to next message
Originally posted by: rdearing.cysive.com
All,
I have my own perspective and I need to remove the standard menu's from
the workbench. I am using the MenuManager to individually remove each menu
(is this
the right approach?). While executing the following code, there are
NullPointerExceptions
thrown when the workbench appears.
WorkbenchWindow window = null;
Workbench bench = (Workbench)super.getWorkbench();
if (bench != null)
IWorkbenchWindow[] windows = bench.getWorkbenchWindows();
for (int i = 0; i < windows.length; i++)
window = (WorkbenchWindow)windows[i];
if (window != null)
MenuManager manager = window.getMenuBarManager();
manager.setRemoveAllWhenShown(true);
manager.remove(IWorkbenchActionConstants.M_HELP);
manager.remove(IWorkbenchActionConstants.M_NAVIGATE);
manager.remove(IWorkbenchActionConstants.M_EDIT);
manager.remove(IWorkbenchActionConstants.M_PROJECT);
manager.remove(IWorkbenchActionConstants.M_WINDOW);
Re: removing workbench menus throws NPE [message #93387 is a reply to message #93330] Mon, 14 July 2003 15:19 Go to previous messageGo to next message
Originally posted by: simon.ibm.oti.lab
Sorry, but you can't do that. Are you trying to write a standalone
application using Eclipse as the UI? If so, you may be interested in the
rich client platform work we are doing for 3.0 release.
Simon :-)
"Ron" <rdearing@cysive.com> wrote in message
news:beuqlk$fh5$1@eclipse.org...
> All,
> (is this
> if (bench != null)
> if (window != null)
Re: removing workbench menus throws NPE [message #94098 is a reply to message #93387] Tue, 15 July 2003 11:17 Go to previous messageGo to next message
Actually, I have my own plugin and perspective.
When will this functionality be available in the 3.0 release?
"Simon Arsenault" <simon@ibm.oti.lab> wrote in message
news:beuvno$lnn$1@eclipse.org...
> Simon :-)
> > All,
menu
> > (is this
> > if (bench != null)
> > if (window != null)
Re: removing workbench menus throws NPE [message #94155 is a reply to message #94098] Tue, 15 July 2003 13:31 Go to previous message
The plan is to have some working rich client platform for M3
Simon :-)
news:bf15su$t48$1@eclipse.org...
> > Simon :-)
> > > All,
from
> menu
> > > (is this
> > > if (bench != null)
> > > if (window != null)
Previous Topic:Perspective action
Next Topic:Undo Limits
Current Time: Sat Jul 26 15:16:29 EDT 2025
Powered by FUDForum. Page generated in 0.03322 seconds
