How to set up JBoss IDE 1.2 with Eclipse 3.0 [message #8400] |
Mon, 15 September 2003 11:39 |
Originally posted by: stevenhelp03.yahoo.com
I tried to set up the JBoss IDE 1.2 with Eclipse 3.0 but not successful.
Please help!
Here's what I did:
1. installed Eclipse 3
2. installed JBoss App Server 3.2.2
3. installed JBoss IDE plugins into Eclipse 3 directory
4. launched Eclipse to set up start up parameters for JBoss App Server and
I received the following erros.
Thankx.
!SESSION Sep 15, 2003 09:43:41.361
java.version=1.4.1_02
Command-line arguments: -os win32 -ws win32 -arch x86 -install
file:D:/Profiles/thuydung/My Documents/Documents/Eclipse/eclipse/
!ENTRY org.jboss.ide.eclipse.launcher.core 4 0 Sep 15, 2003 09:43:41.361
!MESSAGE Internal Error
!STACK 1
org.eclipse.core.runtime.CoreException: Launch mode run not supported for
configuration type
org.jboss.ide.eclipse.launcher.configuration.jboss.JBoss32xL aunchConfigurationDelegate
org.eclipse.debug.internal.core.LaunchConfigurationType.getD elegate(LaunchConfigurationType.java:211)
org.eclipse.debug.internal.core.LaunchConfigurationType.getD elegate(LaunchConfigurationType.java:203)
org.jboss.ide.eclipse.launcher.core.ServerLaunchManager.isSe rverConfiguration(ServerLaunchManager.java:251)
org.jboss.ide.eclipse.launcher.core.ServerLaunchManager.getS erverConfigurations(ServerLaunchManager.java:182)
org.jboss.ide.eclipse.launcher.ui.views.ServerNavigatorConte ntProvider.getElements(ServerNavigatorContentProvider.java:6 3)
org.eclipse.jface.viewers.StructuredViewer.getRawChildren(St ructuredViewer.java:502)
org.eclipse.jface.viewers.AbstractTreeViewer.getRawChildren( AbstractTreeViewer.java:670)
org.eclipse.jface.viewers.StructuredViewer.getFilteredChildr en(StructuredViewer.java:449)
org.eclipse.jface.viewers.StructuredViewer.getSortedChildren (StructuredViewer.java:553)
org.eclipse.jface.viewers.AbstractTreeViewer.updateChildren( AbstractTreeViewer.java:1372)
org.eclipse.jface.viewers.AbstractTreeViewer.internalRefresh Struct(AbstractTreeViewer.java:992)
org.eclipse.jface.viewers.AbstractTreeViewer.internalRefresh (AbstractTreeViewer.java:970)
org.eclipse.jface.viewers.AbstractTreeViewer.internalRefresh (AbstractTreeViewer.java:938)
org.eclipse.jface.viewers.StructuredViewer$8.run(StructuredV iewer.java:881)
org.eclipse.jface.viewers.StructuredViewer.preservingSelecti on(StructuredViewer.java:796)
org.eclipse.jface.viewers.StructuredViewer.refresh(Structure dViewer.java:879)
org.eclipse.jface.viewers.StructuredViewer.refresh(Structure dViewer.java:839)
org.jboss.ide.eclipse.launcher.ui.views.ServerNavigator$2.ru n(ServerNavigator.java:274)
at org.eclipse.swt.widgets.RunnableLock.run(RunnableLock.java:3 5)
org.eclipse.swt.widgets.Synchronizer.runAsyncMessages(Synchr onizer.java:102)
at org.eclipse.swt.widgets.Display.runAsyncMessages(Display.jav a:2165)
at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java :1882)
at org.eclipse.jface.window.Window.runEventLoop(Window.java:583 )
at org.eclipse.jface.window.Window.open(Window.java:563)
org.eclipse.debug.internal.ui.launchConfigurations.LaunchCon figurationsDialog.openDialogOnSelection(LaunchConfigurations Dialog.java:488)
org.eclipse.debug.internal.ui.launchConfigurations.LaunchCon figurationsDialog.open(LaunchConfigurationsDialog.java:442)
at org.eclipse.debug.ui.DebugUITools$1.run(DebugUITools.java:38 4)
at org.eclipse.swt.custom.BusyIndicator.showWhile(BusyIndicator .java:84)
org.eclipse.debug.ui.DebugUITools.openLaunchConfigurationDia logOnGroup(DebugUITools.java:388)
org.eclipse.debug.ui.DebugUITools.openLaunchConfigurationDia logOnGroup(DebugUITools.java:330)
org.eclipse.debug.ui.DebugUITools.openLaunchConfigurationDia log(DebugUITools.java:303)
org.jboss.ide.eclipse.launcher.ui.views.ServerNavigator.doCo nfiguration(ServerNavigator.java:153)
org.jboss.ide.eclipse.launcher.ui.views.ServerNavigator$10.r un(ServerNavigator.java:759)
at org.eclipse.jface.action.Action.runWithEvent(Action.java:842 )
org.eclipse.jface.action.ActionContributionItem.handleWidget Selection(ActionContributionItem.java:529)
org.eclipse.jface.action.ActionContributionItem.access$4(Act ionContributionItem.java:482)
org.eclipse.jface.action.ActionContributionItem$5.handleEven t(ActionContributionItem.java:429)
at org.eclipse.swt.widgets.EventTable.sendEvent(EventTable.java :82)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:847)
at org.eclipse.swt.widgets.Display.runDeferredEvents(Display.ja va:2188)
at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java :1878)
at org.eclipse.ui.internal.Workbench.runEventLoop(Workbench.jav a:2036)
at org.eclipse.ui.internal.Workbench.run(Workbench.java:2019)
org.eclipse.core.internal.boot.InternalBootLoader.run(Intern alBootLoader.java:858)
at org.eclipse.core.boot.BootLoader.run(BootLoader.java:461)
at org.eclipse.core.launcher.Main.basicRun(Main.java:295)
at org.eclipse.core.launcher.Main.run(Main.java:751)
at org.eclipse.core.launcher.Main.main(Main.java:587)
!ENTRY org.eclipse.debug.core 4 120 Sep 15, 2003 09:43:41.361
!MESSAGE Launch mode run not supported for configuration type
!ENTRY org.eclipse.ui 4 4 Sep 15, 2003 09:43:41.481
!MESSAGE Unhandled exception caught in event loop.
!ENTRY org.eclipse.ui 4 0 Sep 15, 2003 09:43:41.511
!MESSAGE Failed to execute runnable
(org.eclipse.jface.util.Assert$AssertionFailedException: null argument;)
!STACK 0
org.eclipse.swt.SWTException: Failed to execute runnable
at org.eclipse.swt.SWT.error(SWT.java:2367)
org.eclipse.swt.widgets.Synchronizer.runAsyncMessages(Synchr onizer.java:105)
!ENTRY org.eclipse.ui 4 4 Sep 15, 2003 09:43:41.531
!MESSAGE
*** Stack trace of contained exception ***
!ENTRY org.eclipse.ui 4 0 Sep 15, 2003 09:43:41.541
!MESSAGE null argument;
!STACK 0
at org.eclipse.jface.util.Assert.isNotNull(Assert.java:139)
at org.eclipse.jface.util.Assert.isNotNull(Assert.java:116)
org.eclipse.jface.viewers.StructuredViewer.getRawChildren(St ructuredViewer.java:503)
!ENTRY org.jboss.ide.eclipse.launcher.core 4 0 Sep 15, 2003 09:43:41.561
!STACK 1
configuration type
!ENTRY org.eclipse.debug.core 4 120 Sep 15, 2003 09:43:41.571
!ENTRY org.eclipse.ui 4 4 Sep 15, 2003 09:43:41.591
!ENTRY org.eclipse.ui 4 0 Sep 15, 2003 09:43:41.611
!STACK 0
!ENTRY org.eclipse.ui 4 4 Sep 15, 2003 09:43:41.651
!MESSAGE
!ENTRY org.eclipse.ui 4 0 Sep 15, 2003 09:43:41.671
!STACK 0
!ENTRY org.jboss.ide.eclipse.launcher.core 4 0 Sep 15, 2003 09:43:41.691
!STACK 1
configuration type
!ENTRY org.eclipse.debug.core 4 120 Sep 15, 2003 09:43:41.701
!ENTRY org.eclipse.ui 4 4 Sep 15, 2003 09:43:41.721
!ENTRY org.eclipse.ui 4 0 Sep 15, 2003 09:43:41.741
!STACK 0
!ENTRY org.eclipse.ui 4 4 Sep 15, 2003 09:43:41.761
!MESSAGE
!ENTRY org.eclipse.ui 4 0 Sep 15, 2003 09:43:41.792
!STACK 0
!ENTRY org.jboss.ide.eclipse.launcher.core 4 0 Sep 15, 2003 09:43:41.812
!STACK 1
configuration type
org.jboss.ide.eclipse.launcher.ui.views.ServerNavigator$1.ru n(ServerNavigator.java:250)
!ENTRY org.eclipse.debug.core 4 120 Sep 15, 2003 09:43:41.812
!ENTRY org.eclipse.ui 4 4 Sep 15, 2003 09:43:41.832
!ENTRY org.eclipse.ui 4 0 Sep 15, 2003 09:43:41.862
!STACK 0
!ENTRY org.eclipse.ui 4 4 Sep 15, 2003 09:43:41.882
!MESSAGE
!ENTRY org.eclipse.ui 4 0 Sep 15, 2003 09:43:41.902
!STACK 0
!ENTRY org.jboss.ide.eclipse.launcher.core 4 0 Sep 15, 2003 09:43:41.922
!STACK 1
configuration type
!ENTRY org.eclipse.debug.core 4 120 Sep 15, 2003 09:43:41.922
!ENTRY org.eclipse.ui 4 4 Sep 15, 2003 09:43:41.952
!ENTRY org.eclipse.ui 4 0 Sep 15, 2003 09:43:41.972
!STACK 0
FUDForum. Page generated in 0.04649 seconds
