Home » Modeling » BPEL Designer » Code on tip is Europa and WTP 2.0 dependent.
Code on tip is Europa and WTP 2.0 dependent. [message #8393] Fri, 22 June 2007 18:04
The code on the tip is now WTP 2.0 dependent.
In particular, the following are needed.
GEF-ALL-3.3RC3.zip
dtp-sdk_1.5RC3.zip
eclipse-SDK-3.3RC4-win32.zip
emf-sdo-xsd-SDK-2.3.0RC3.zip
wtp-sdk-S-2.0RC3-200706140654.zip
This fixes one of the issue that most of us have hated - the WSDL model
dependency ...
At this point, you should be able to extend the BPEL model and
regenerated it if you want without problems.
-michal
Previous Topic:Does BPEL validator require Java 6.0?
Next Topic:BPMN Survey Online
Current Time: Sat May 10 17:56:17 EDT 2025
Powered by FUDForum. Page generated in 0.03132 seconds
