Coolbar disappear after perspective reset [message #93152] |
Thu, 12 June 2008 17:30  |
Hi again,
Still with 1.1RC3.
Here is the problem. Let's say I start the application, then close a few views, or resize them. Then, through an action
(IWorkbenchWindowActionDelegate) I reset the perspective [workbenchWindow.getActivePage().resetPerspective(); ].
Everything returns to normal (views reopen, are resized and everything), but I loose my buttons on my Coolbar. The
buttons are defined with an actionSet in plugin.xml.
Should I call some method on some object to reactivate, retrieve my buttons?
Patrick
Re: Coolbar disappear after perspective reset [message #93362 is a reply to message #93152] |
Fri, 13 June 2008 10:48   |
Originally posted by: rherrmann.innoopract.com
Patrick,
this appears to be a bug. Could you please file a bug report?
Rüdiger
Patrick Turcotte wrote:
> Hi again,
> Still with 1.1RC3.
> but I loose my buttons on my Coolbar. The buttons are defined with an
> buttons?
> Patrick
Re: Coolbar disappear after perspective reset [message #93391 is a reply to message #93362] |
Fri, 13 June 2008 11:15  |
Yes, i'll file a bug report.
Patrick
> Patrick,
> Thanks
> Rüdiger
>> Hi again,
>> Still with 1.1RC3.
>> everything), but I loose my buttons on my Coolbar. The buttons are
>> buttons?
>> Thanks,
>> Patrick
FUDForum. Page generated in 0.05408 seconds
