Home » Archived » SeMantic Information Logistics Architecture (SMILA) » Login details for SVN
Login details for SVN [message #746] Tue, 24 February 2009 05:30 Go to next message
We would like to obtain SMILE from SVN and were wondering what the process
is for requesting login details.
Re: Login details for SVN [message #761 is a reply to message #746] Fri, 27 February 2009 03:34 Go to previous message
As this was also discussed on the mailinglist, I will give a summary here
for completeness:
You can access the Smila SVN repository (in fact all eclipse repositories)
anonymously. Please check out the following link:
http://wiki.eclipse.org/SVN_Howto. The SVN repository path for Smila is
/svnroot/rt/org.eclipse.smila
Be warned that there is currently only an outdated code base available and
that there is no running build process, as we are in the middle of IP
process!
If you are looking for an up to date binary build check out
http://www.brox.de/en/products/smila.jsp
To get access to our temporary development repository
https://svn.brox.de/svn/eccenca/EILF/trunk please contaxt the guys from
brox (http://www.brox.de/en/)
Daniel
Re: Login details for SVN [message #563966 is a reply to message #746] Fri, 27 February 2009 03:34 Go to previous message
for completeness:
http://wiki.eclipse.org/SVN_Howto The SVN repository path for Smila is
process!
Daniel
Previous Topic:Exception when using Numeric Fields / Patch
Next Topic:Meet us at EclipseCon 2009 and see SMILA in action!
Current Time: Tue Jul 22 01:46:07 EDT 2025
Powered by FUDForum. Page generated in 0.04546 seconds
