Home » Archived » M2M (model-to-model transformation) » [ATL] "If then else" with multiple code lines Syntax problem
[ATL] "If then else" with multiple code lines Syntax problem [message #92985] Tue, 21 October 2008 11:50 Go to next message
I have a problem writing this recursive helper, it seems like i cannot
have multiple code lines in the "if then else" statement of a helper! Do
you have a solution for this?
helper context UML2!Package def : getAllChildren () :
OrderedSet(UML2!Package) =
self.nestedPackage->iterate( child ; elements : OrderedSet(UML2!Package) =
OrderedSet{} |
if not(child.packageIsLeaf()) then
{elements.append(child);
elements.union(child.getAllChildren ());
else
{ elements.append(child);}
endif
Can anybody help ?!!
Skander TURKI
skander.turki@gmail.com
Université de Bretagne-Sud, Lorient
Lab-STICC (Lanester) laboratory
Re: [ATL] "If then else" with multiple code lines Syntax problem [message #93000 is a reply to message #92985] Tue, 21 October 2008 12:06 Go to previous messageGo to next message
ATL helpers are not imperative functions you don't have the right to
write this.
the expresssions in statements must return a result
Skander a écrit :
> Hi, I have a problem writing this recursive helper, it seems like i
> cannot have multiple code lines in the "if then else" statement of a
> helper! Do you have a solution for this?
> OrderedSet(UML2!Package) = OrderedSet{} |
> else
> endif
> Skander TURKI
Re: [ATL] "If then else" with multiple code lines Syntax problem [message #93063 is a reply to message #93000] Wed, 22 October 2008 08:10 Go to previous message
"Tristan FAURE" <tristan.faure@atosorigin.com> schreef in bericht
news:gdkum7$g9q$1@build.eclipse.org...
> ATL helpers are not imperative functions you don't have the right to write
> this.
exactly.
And in Ocl there is also an if statement, however the syntax is different:
let x:Boolean=true in if x then 'yes' else 'no' endif
Alfons
Previous Topic:[QVTO] Trace meta-model ?
Next Topic:[ATL] Model Copy/Clone
Current Time: Mon Jul 21 22:22:53 EDT 2025
Powered by FUDForum. Page generated in 0.02591 seconds
