Home » Modeling » EMF "Technology" (Ecore Tools, EMFatic, etc) » [TENEO] Sequence generation problem
Re: [TENEO] Sequence generation problem [message #92774 is a reply to message #92759] |
Wed, 08 August 2007 19:18 |
Martin Taal Messages: 5468 Registered: July 2009 |
--------------080508020903000407070303
Hi Jason,
Afair sequence generators need to be defined on package level, in xsd this means just below the
xsd:schema element.
See the attachment for an example of one of the testcases.
gr. Martin
Jason Henriksen wrote:
> Hi All,
> Am I doing this wrong? I need my object to use a pre-existing sequence, but
> I get this exception:
> Caused by: java.lang.IllegalStateException: No sequence generator found with
> the name: SEQ_CMR3605T, name is used in annotation of element
> Address/addressSK
> The XSD I'm using looks like this (taken from a JPA annotation reference)
> <xsd:element name="addressSK" type="xsd:int">
> <xsd:annotation>
> <xsd:appinfo source="teneo.jpa">
> @Id
> @Column(name="ADDRESS_SK" nullable="false")
> @SequenceGenerator(name="SEQ_CMR3605T", sequenceName="SEQ_CMR3605T",
> allocationSize=1)
> @GeneratedValue(strategy=SEQUENCE, generator="SEQ_CMR3605T")
> </xsd:appinfo>
> <xsd:documentation>A generated key to uniquely the
> record.</xsd:documentation>
> </xsd:annotation>
> </xsd:element>
> Here's the stack trace:
> Address/addressSK
> at
> org.eclipse.emf.teneo.annotations.pamodel.impl.PAnnotatedMod elImpl.getSequen
> ceGenerator(PAnnotatedModelImpl.java:462)
> at
> org.eclipse.emf.teneo.hibernate.mapper.IdMapper.processIdPro perty(IdMapper.j
> ava:257)
> at
> org.eclipse.emf.teneo.hibernate.mapper.FeatureMapper.process PAnnotatedEAttri
> bute(FeatureMapper.java:125)
> at
> org.eclipse.emf.teneo.hibernate.mapper.FeatureMapper.process (FeatureMapper.j
> ava:98)
> at
> org.eclipse.emf.teneo.hibernate.mapper.EntityMapper.processF eature(EntityMap
> per.java:490)
> at
> org.eclipse.emf.teneo.hibernate.mapper.EntityMapper.processF eatures(EntityMa
> pper.java:390)
> at
> org.eclipse.emf.teneo.hibernate.mapper.EntityMapper.processE ntity(EntityMapp
> er.java:277)
> at
> org.eclipse.emf.teneo.hibernate.mapper.HibernateMappingGener ator.processPACl
> ass(HibernateMappingGenerator.java:183)
> at
> org.eclipse.emf.teneo.hibernate.mapper.HibernateMappingGener ator.processPers
> istentClasses(HibernateMappingGenerator.java:151)
> at
> org.eclipse.emf.teneo.hibernate.mapper.HibernateMappingGener ator.generate(Hi
> bernateMappingGenerator.java:113)
> at
> org.eclipse.emf.teneo.hibernate.mapper.HibernateMappingGener ator.generateToS
> tring(HibernateMappingGenerator.java:124)
> at
> org.eclipse.emf.teneo.hibernate.HbDataStore.mapEPackages(HbD ataStore.java:55
> 1)
> at
> org.eclipse.emf.teneo.hibernate.HbSessionDataStore.mapModel( HbSessionDataSto
> re.java:163)
> at
> org.eclipse.emf.teneo.hibernate.HbSessionDataStore.initializ e(HbSessionDataS
> tore.java:77)
> (Warning: The line numbers may not line up due to some local hacking, but I
> haven't touched anything to do with sequences)
> Jason
With Regards, Martin Taal
Springsite/Elver.org
The Netherlands
Tel: +31 (0)84 420 2397
Fax: +31 (0)84 225 9307
Content-Type: text/xml;
name="id.xsd"
Content-Disposition: inline;
filename="id.xsd"
<xsd:schema targetNamespace=" http://www.eclipse.org/emf/teneo/samples/emf/annotations/hb/ generator/id"
xmlns:ecore="http://www.eclipse.org/emf/2002/Ecore"
xmlns:lib=" http://www.eclipse.org/emf/teneo/samples/emf/annotations/hb/ generator/id"
xmlns:xsd="http://www.w3.org/2001/XMLSchema">
<xsd:annotation>
<xsd:appinfo source="teneo.hibernate">
@GenericGenerator(name="system-uuid", strategy = "uuid")
@GenericGenerator(name="hibseq", strategy = "hilo",
parameters = {
@Parameter(name="table", value = "hilo_table"),
@Parameter(name="column", value="the_hilo_column")
</xsd:appinfo>
</xsd:annotation>
<xsd:complexType name="SimpleID">
<xsd:sequence>
<xsd:element name="autoID" type="xsd:long">
<xsd:annotation>
@Id @GeneratedValue
@Column(name="AUTOD" nullable="false")
</xsd:appinfo>
</xsd:annotation>
</xsd:element>
<xsd:element name="generated" type="xsd:long">
<xsd:annotation>
@Generated(ALWAYS)
</xsd:appinfo>
</xsd:annotation>
</xsd:element>
</xsd:sequence>
</xsd:complexType>
<xsd:complexType name="TableID">
<xsd:sequence>
<xsd:element name="myid" type="xsd:long">
<xsd:annotation>
@Id @GeneratedValue(generator="hibseq")
</xsd:appinfo>
</xsd:annotation>
</xsd:element>
</xsd:sequence>
</xsd:complexType>
<xsd:complexType name="IdentityID">
<xsd:sequence>
<xsd:annotation>
@Id @GeneratedValue(strategy="IDENTITY")
</xsd:appinfo>
</xsd:annotation>
</xsd:element>
</xsd:sequence>
</xsd:complexType>
</xsd:schema>
--------------080508020903000407070303--
Re: [TENEO] Sequence generation problem [message #92789 is a reply to message #92774] |
Wed, 08 August 2007 22:09 |
Jason Henriksen Messages: 231 Registered: July 2009 |
------=_NextPart_000_005B_01C7D9CE.2C0D54B0
charset="iso-8859-1"
Hi Martin,
I'm still getting:
2007/08/08 15:02:32:047 PDT [ERROR] AnnotationParserException - The =
eclass: HbAnnotatedEClass does not have an efeature for GenericGenerator =
< org.eclipse.emf.teneo.annotations.parser.AnnotationParserExc eption: The =
eclass: HbAnnotatedEClass does not have an efeature for =
GenericGenerator>org.eclipse.emf.teneo.annotations.parser.AnnotationParse=
rException: The eclass: HbAnnotatedEClass does not have an efeature for =
GenericGenerator
at =
org.eclipse.emf.teneo.annotations.parser.EAnnotationParserIm porter.proces=
sAnnotatedModelElement(EAnnotationParserImporter.java:130)
at =
s(EAnnotationParserImporter.java:71)
at =
s(EAnnotationParserImporter.java:64)
at =
org.eclipse.emf.teneo.annotations.mapper.PersistenceMappingB uilder.buildM=
apping(PersistenceMappingBuilder.java:94)
at =
org.eclipse.emf.teneo.hibernate.HbDataStore.mapEPackages(HbD ataStore.java=
:548)
at =
org.eclipse.emf.teneo.hibernate.HbSessionDataStore.mapModel( HbSessionData=
Store.java:163)
at =
org.eclipse.emf.teneo.hibernate.HbSessionDataStore.initializ e(HbSessionDa=
taStore.java:77)
at com.vsp.test.DBUpdateTest.getDataStore(DBUpdateTest.java:174 )
at com.vsp.test.DBUpdateTest.main(DBUpdateTest.java:79)
After following your advice and making my code look like this:
<?xml version=3D"1.0" encoding=3D"UTF-8"?>
<xsd:schema=20
xmlns:xsd=3D"http://www.w3.org/2001/XMLSchema"=20
xmlns:ecore=3D"http://www.eclipse.org/emf/2002/Ecore"=20
xmlns:vsp=3D"http://vsp.com/"=20
targetNamespace=3D"http://vsp.com/">
=20
<xsd:annotation><xsd:appinfo source=3D"teneo.hibernate">
@GenericGenerator(
name =3D "SEQ_CMR3601T",
strategy =3D "sequence"
parameters=3D {
@Parameter(name =3D "sequence-name", value =3D =
"SEQ_CMR3601T")
</xsd:appinfo></xsd:annotation>
=20
=20
<xsd:complexType name=3D"Consumer">
<xsd:sequence>
<xsd:element default=3D"0" name=3D"consumerSK" type=3D"xsd:int">
<xsd:annotation>
<xsd:appinfo source=3D"teneo.jpa">
@Column(name=3DCONSUMER_SK nullable=3D"false")
@Id
@GeneratedValue(generator=3D"SEQ_CMR3601T") =
=20
</xsd:appinfo>
=20
<xsd:documentation>A generated key to uniquely identify =
a person</xsd:documentation>
</xsd:annotation>
</xsd:element>
Could it be that the first annotation is teneo.hibernate while the =
second annotation is teneo.jpa?
(I've used exclusively teneo.jpa thus far). =20
I'm also wondering if you have an example where the strategy is =
'sequence'. Maybe I'm not setting the sequence name properly?
Like I say, I can't generate the sequence, I have to use the one =
provided by the DBA, but finding an example of this being done using =
annotations has proven difficult.
Thanks for any suggestions,
Jason Henriksen
Content-Type: text/html;
<HTML><HEAD>
charset=3Diso-8859-1">
<META content=3D"MSHTML 6.00.2800.1561" name=3DGENERATOR>
<STYLE></STYLE>
</HEAD>
<BODY bgColor=3D#ffffff background=3D"">
<DIV><FONT face=3DArial size=3D2>Hi Martin,</FONT></DIV>
<DIV><FONT face=3DArial size=3D2></FONT> </DIV>
<DIV><FONT face=3DArial size=3D2>I'm still getting:</FONT></DIV>
<DIV><FONT face=3DArial size=3D2>2007/08/08 15:02:32:047 PDT [ERROR]=20
AnnotationParserException - The eclass: HbAnnotatedEClass does not have =
an=20
efeature for GenericGenerator=20
<org.eclipse.emf.teneo.annotations.parser.AnnotationP arserException: =
The=20
eclass: HbAnnotatedEClass does not have an efeature for=20
GenericGenerator>org.eclipse.emf.teneo.annotations.pa rser.AnnotationPa=
rserException:=20
The eclass: HbAnnotatedEClass does not have an efeature for=20
GenericGenerator<BR> at=20
sAnnotatedModelElement(EAnnotationParserImporter.java:130)<BR > at=20
s(EAnnotationParserImporter.java:71)<BR> at=20
s(EAnnotationParserImporter.java:64)<BR> at=20
apping(PersistenceMappingBuilder.java:94)<BR> at=20
:548)<BR> at=20
Store.java:163)<BR> at=20
taStore.java:77)<BR> at=20
com.vsp.test.DBUpdateTest.getDataStore(DBUpdateTest.java:174 ) <BR> at=
=20
com.vsp.test.DBUpdateTest.main(DBUpdateTest.java:79)</FONT> </DIV>
<DIV><FONT face=3DArial size=3D2>After following your advice and making =
my code look=20
like this:</FONT></DIV>
<DIV><FONT size=3D2><FONT face=3DCourier><?xml version=3D"1.0"=20
encoding=3D"UTF-8"?><BR><xsd:schema </FONT></FONT></DIV>
<DIV><FONT size=3D2><FONT face=3DCourier>xmlns:xsd=3D"</FONT><A=20
href=3D"http://www.w3.org/2001/XMLSchema"><FONT=20
face=3DCourier>http://www.w3.org/2001/XMLSchema</FONT></A><FONT =
face=3DCourier>"=20
<DIV><FONT size=3D2><FONT face=3DCourier>xmlns:ecore=3D"</FONT><A=20
href=3D"http://www.eclipse.org/emf/2002/Ecore"><FONT=20
face=3DCourier>http://www.eclipse.org/emf/2002/Ecore</FONT></A><FONT=20
face=3DCourier>" </FONT></FONT></DIV>
<DIV><FONT size=3D2><FONT face=3DCourier>xmlns:vsp=3D"</FONT><A=20
href=3D"http://vsp.com/"><FONT =
face=3DCourier>http://vsp.com/</FONT></A><FONT=20
<DIV><FONT size=3D2><FONT face=3DCourier>targetNamespace=3D"</FONT><A=20
face=3DCourier>"><BR> <BR> =20
<xsd:annotation><xsd:appinfo=20
source=3D"teneo.hibernate"><BR> =20
@GenericGenerator(<BR> name =
=3D=20
"SEQ_CMR3601T",<BR> strategy =
=3D=20
"sequence"<BR> parameters=3D=20
{<BR> =20
@Parameter(name =3D "sequence-name", value =3D=20
"SEQ_CMR3601T")<BR> =20
}<BR> )<BR> =20
</xsd:appinfo></xsd:annotation><BR > =20
<BR> <BR> <xsd:complexType=20
name=3D"Consumer"><BR> =20
<xsd:sequence><BR> <xsd:element=20
default=3D"0" name=3D"consumerSK"=20
type=3D"xsd:int"><BR> &=
nbsp; =20
<xsd:annotation><BR>  =
;   ; =20
<xsd:appinfo=20
source=3D"teneo.jpa"><BR> &nb=
sp; &nb sp; =20
@Column(name=3DCONSUMER_SK=20
nullable=3D"false")<BR> &n=
bsp; &n bsp;=20
@Id<BR> =
=20
=20
<BR> &nb=
sp; =20
</xsd:appinfo><BR> &=
nbsp; & nbsp;=20
<BR> &nb=
sp; =20
<xsd:documentation>A generated key to uniquely identify a=20
person</xsd:documentation><BR> &=
nbsp; =20
</xsd:annotation><BR> =20
</xsd:element></FONT></FONT></DIV>
<DIV><FONT face=3DCourier size=3D2></FONT> </DIV>
<DIV><FONT face=3DArial size=3D2>Could it be that the first annotation =
is=20
teneo.hibernate while the second annotation is teneo.jpa?<BR>(I've used=20
exclusively teneo.jpa thus far). </FONT></DIV>
<DIV><FONT face=3DArial size=3D2>I'm also wondering if you have an =
example where the=20
strategy is 'sequence'. Maybe I'm not setting the sequence name=20
properly?<BR>Like I say, I can't generate the sequence, I have to use =
the one=20
annotations=20
has proven difficult.</FONT></DIV>
<DIV><FONT face=3DArial size=3D2>Thanks for any =
suggestions,</FONT></DIV>
<DIV><FONT face=3DArial=20
size=3D2> &nbs=
p; =20
Jason=20
Henriksen<BR> =
=20
</FONT></DIV></BODY></HTML>
------=_NextPart_000_005B_01C7D9CE.2C0D54B0--
Re: [TENEO] Sequence generation problem [message #92804 is a reply to message #92789] |
Wed, 08 August 2007 22:25 |
Hi Jason,
With my testcase the annotation in the top of the xsd gets translated to an annotation of the
epackage. This is how it should be. It seems that with you it gets translated to an annotation on an
EClass. Can you check in your ecore (or post that relevant part)?
gr. Martin
> Hi Martin,
> I'm still getting:
> GenericGenerator> org.eclipse.emf.teneo.annotations.parser.AnnotationParserExc eption:
> The eclass: HbAnnotatedEClass does not have an efeature for GenericGenerator
> at
> org.eclipse.emf.teneo.annotations.parser.EAnnotationParserIm porter.processAnnotatedModelElement(EAnnotationParserImporte r.java:130)
> at
> org.eclipse.emf.teneo.annotations.parser.EAnnotationParserIm porter.process(EAnnotationParserImporter.java:71)
> at
> org.eclipse.emf.teneo.annotations.parser.EAnnotationParserIm porter.process(EAnnotationParserImporter.java:64)
> at
> org.eclipse.emf.teneo.annotations.mapper.PersistenceMappingB uilder.buildMapping(PersistenceMappingBuilder.java:94)
> at
> org.eclipse.emf.teneo.hibernate.HbDataStore.mapEPackages(HbD ataStore.java:548)
> at
> org.eclipse.emf.teneo.hibernate.HbSessionDataStore.mapModel( HbSessionDataStore.java:163)
> at
> org.eclipse.emf.teneo.hibernate.HbSessionDataStore.initializ e(HbSessionDataStore.java:77)
> <xsd:schema
> xmlns:vsp="http://vsp.com/"
> targetNamespace="http://vsp.com/">
> <xsd:annotation><xsd:appinfo source="teneo.hibernate">
> @GenericGenerator(
> name = "SEQ_CMR3601T",
> strategy = "sequence"
> parameters= {
> @Parameter(name = "sequence-name", value = "SEQ_CMR3601T")
> <xsd:complexType name="Consumer">
> <xsd:sequence>
> <xsd:element default="0" name="consumerSK" type="xsd:int">
> <xsd:annotation>
> @Column(name=CONSUMER_SK nullable="false")
> @Id
> @GeneratedValue(generator="SEQ_CMR3601T")
> </xsd:appinfo>
> </xsd:annotation>
> </xsd:element>
> Jason Henriksen
The Netherlands
Re: [TENEO] Sequence generation problem [message #92819 is a reply to message #92804] |
Wed, 08 August 2007 22:57 |
Hi Martin,
Here are all the pieces in full.
Thanks or any help,
Jason
"Martin Taal" <mtaal@elver.org> wrote in message
news:f9dfta$92j$1@build.eclipse.org...
> Hi Jason,
> gr. Martin
> > Hi Martin,
> > I'm still getting:
GenericGenerator>org.eclipse.emf.teneo.annotations.parser.AnnotationParserEx
ception:
GenericGenerator
> > at
> > at
> > at
> > at
> > at
8)
> > at
re.java:163)
> > at
tore.java:77)
> > <?xml version="1.0" encoding="UTF-8"?>
> > <xsd:schema
> > @GenericGenerator(
> > parameters= {
> > <xsd:sequence>
> > <xsd:annotation>
> > @Id
> > </xsd:appinfo>
> > </xsd:annotation>
> > </xsd:element>
> > Jason Henriksen
> The Netherlands
Re: [TENEO] Sequence generation problem [message #92838 is a reply to message #92819] |
Thu, 09 August 2007 03:28 |
Hi Jason,
The @GenericGenerator is currently not supported at the EClass level only at package level. In your
model (customer.ecore) I can see that there are GenericGenerator annotations in the Address,
EmailType, Member and Phone EClasses. These should all be moved to the package level. Having
multiple GenericGenerator annotations at package level should work.
Hibernate annotations allows genericgenerator annotations on class level also. So Teneo should also
support this. Can you enter a bugzilla for this?
gr. Martin
> Hi Martin,
> Thanks or any help,
> Jason
>> Hi Jason,
>> gr. Martin
>>> Hi Martin,
>>> I'm still getting:
> ception:
> GenericGenerator
>>> at
>>> at
>>> at
>>> at
>>> at
> 8)
>>> at
> re.java:163)
>>> at
> tore.java:77)
>>> <xsd:schema
>>> @GenericGenerator(
>>> parameters= {
>>> <xsd:sequence>
>>> <xsd:annotation>
>>> @Id
>>> </xsd:appinfo>
>>> </xsd:annotation>
>>> </xsd:element>
>>> Jason Henriksen
>> The Netherlands
The Netherlands
Re: [TENEO] Sequence generation problem [message #92902 is a reply to message #92838] |
Thu, 09 August 2007 16:33 |
No problem Martin.
I should have moved them all up. I only moved Consumer up thinking I could
test that seperately, but I guess the non-Consumer classes were still
causing a problem.
I'll get that bugzilla entry in today.
Jason Henriksen
news:f9e1lm$2at$1@build.eclipse.org...
> Hi Jason,
> gr. Martin
> > Hi Martin,
> > Thanks or any help,
> > Jason
> >> Hi Jason,
to
> >> gr. Martin
> >>> Hi Martin,
> >>> I'm still getting:
GenericGenerator
The
> > ception:
> > GenericGenerator
> >>> at
> >>> at
> >>> at
> >>> at
> >>> at
> > 8)
> >>> at
> > re.java:163)
> >>> at
> > tore.java:77)
> >>> <xsd:schema
> >>> @GenericGenerator(
> >>> parameters= {
> >>> <xsd:sequence>
> >>> <xsd:annotation>
> >>> @Id
> >>> </xsd:appinfo>
identify
> >>> </xsd:annotation>
> >>> </xsd:element>
> >>> Jason Henriksen
> >> The Netherlands
> The Netherlands
Re: [TENEO] Sequence generation problem [message #609435 is a reply to message #92759] |
Hi Jason,
xsd:schema element.
gr. Martin
> Hi All,
> Address/addressSK
> <xsd:annotation>
> @Id
> allocationSize=1)
> </xsd:appinfo>
> </xsd:annotation>
> </xsd:element>
> Address/addressSK
> at
> at
> ava:257)
> at
> at
> ava:98)
> at
> per.java:490)
> at
> pper.java:390)
> at
> er.java:277)
> at
> at
> at
> at
> at
> 1)
> at
> re.java:163)
> at
> tore.java:77)
> Jason
The Netherlands
name="id.xsd"
filename="id.xsd"
<xsd:annotation>
parameters = {
</xsd:appinfo>
</xsd:annotation>
<xsd:sequence>
<xsd:annotation>
@Id @GeneratedValue
</xsd:appinfo>
</xsd:annotation>
</xsd:element>
<xsd:annotation>
@Generated(ALWAYS)
</xsd:appinfo>
</xsd:annotation>
</xsd:element>
</xsd:sequence>
</xsd:complexType>
<xsd:sequence>
<xsd:annotation>
</xsd:appinfo>
</xsd:annotation>
</xsd:element>
</xsd:sequence>
</xsd:complexType>
<xsd:sequence>
<xsd:annotation>
</xsd:appinfo>
</xsd:annotation>
</xsd:element>
</xsd:sequence>
</xsd:complexType>
</xsd:schema>
Re: [TENEO] Sequence generation problem [message #609436 is a reply to message #92774] |
Hi Martin,
I'm still getting:
GenericGenerator
at =
at =
at =
at =
at =
:548)
at =
Store.java:163)
at =
taStore.java:77)
<xsd:schema=20
=20
@GenericGenerator(
parameters=3D {
"SEQ_CMR3601T")
=20
=20
<xsd:sequence>
<xsd:annotation>
@Id
=20
</xsd:appinfo>
=20
</xsd:annotation>
</xsd:element>
Jason Henriksen
<HTML><HEAD>
<STYLE></STYLE>
</HEAD>
an=20
The=20
rserException:=20
:548)<BR> at=20
=20
my code look=20
face=3DCourier>"=20
=3D=20
=3D=20
{<BR> =20
}<BR> )<BR> =20
nbsp; =20
;   ; =20
<xsd:appinfo=20
sp; &nb sp; =20
bsp; &n bsp;=20
@Id<BR> =
=20
=20
<BR> &nb=
sp; =20
nbsp; & nbsp;=20
<BR> &nb=
sp; =20
nbsp; =20
is=20
the one=20
annotations=20
size=3D2> &nbs=
p; =20
Jason=20
Henriksen<BR> =
=20
Re: [TENEO] Sequence generation problem [message #609437 is a reply to message #92789] |
Hi Jason,
gr. Martin
> Hi Martin,
> I'm still getting:
> at
> at
> at
> at
> at
> at
> at
> <xsd:schema
> @GenericGenerator(
> parameters= {
> <xsd:sequence>
> <xsd:annotation>
> @Id
> </xsd:appinfo>
> </xsd:annotation>
> </xsd:element>
> Jason Henriksen
The Netherlands
Re: [TENEO] Sequence generation problem [message #609438 is a reply to message #92804] |
Hi Martin,
Thanks or any help,
Jason
> Hi Jason,
> gr. Martin
> > Hi Martin,
> > I'm still getting:
ception:
GenericGenerator
> > at
> > at
> > at
> > at
> > at
8)
> > at
re.java:163)
> > at
tore.java:77)
> > <xsd:schema
> > @GenericGenerator(
> > parameters= {
> > <xsd:sequence>
> > <xsd:annotation>
> > @Id
> > </xsd:appinfo>
> > </xsd:annotation>
> > </xsd:element>
> > Jason Henriksen
> The Netherlands
Re: [TENEO] Sequence generation problem [message #609439 is a reply to message #92819] |
Hi Jason,
gr. Martin
> Hi Martin,
> Thanks or any help,
> Jason
>> Hi Jason,
>> gr. Martin
>>> Hi Martin,
>>> I'm still getting:
> ception:
> GenericGenerator
>>> at
>>> at
>>> at
>>> at
>>> at
> 8)
>>> at
> re.java:163)
>>> at
> tore.java:77)
>>> <xsd:schema
>>> @GenericGenerator(
>>> parameters= {
>>> <xsd:sequence>
>>> <xsd:annotation>
>>> @Id
>>> </xsd:appinfo>
>>> </xsd:annotation>
>>> </xsd:element>
>>> Jason Henriksen
>> The Netherlands
The Netherlands
Re: [TENEO] Sequence generation problem [message #609443 is a reply to message #92838] |
No problem Martin.
causing a problem.
Jason Henriksen
> Hi Jason,
> gr. Martin
> > Hi Martin,
> > Thanks or any help,
> > Jason
> >> Hi Jason,
to
> >> gr. Martin
> >>> Hi Martin,
> >>> I'm still getting:
GenericGenerator
The
> > ception:
> > GenericGenerator
> >>> at
> >>> at
> >>> at
> >>> at
> >>> at
> > 8)
> >>> at
> > re.java:163)
> >>> at
> > tore.java:77)
> >>> <xsd:schema
> >>> @GenericGenerator(
> >>> parameters= {
> >>> <xsd:sequence>
> >>> <xsd:annotation>
> >>> @Id
> >>> </xsd:appinfo>
identify
> >>> </xsd:annotation>
> >>> </xsd:element>
> >>> Jason Henriksen
> >> The Netherlands
> The Netherlands
Current Time: Fri Apr 26 00:28:30 GMT 2024
Powered by FUDForum. Page generated in 0.03502 seconds
