Home » Archived » M2M (model-to-model transformation) » [QVTO] Trace meta-model ?
[QVTO] Trace meta-model ? [message #92733] Mon, 20 October 2008 04:24 Go to next message
I'd like to know where I can find a meta-model or documentation for the
QVTO Traces implementation ?
I've got the impression that smartQVT and QVTO have not the exact same
trace meta-model and OMG Spec don't describe an explicit meta-model for
the trace system.
Best regards.
Vincent
Re: [QVTO] Trace meta-model ? [message #92748 is a reply to message #92733] Mon, 20 October 2008 07:17 Go to previous messageGo to next message
Hi Aranega,
You're right there's no explicit description of trace metamodel nor
trace format in QVT spec.
Trace MM we used can be found at
'org.eclipse.m2m.qvt.oml/model/trace.ecore'.
Sergey.
Aranega Vincent wrote:
> QVTO Traces implementation ? I've got the impression that smartQVT and
> QVTO have not the exact same trace meta-model and OMG Spec don't
> describe an explicit meta-model for the trace system.
> Best regards.
> Vincent
Re: [QVTO] Trace meta-model ? [message #92777 is a reply to message #92748] Tue, 21 October 2008 03:30 Go to previous messageGo to next message
Thanks for your help. However, I don't found 'trace.ecore' in
'org.eclipse.m2m.qvt.oml/model/'. Actually, i don't found any 'model' in
'org.eclipse.m2m.qvt.oml' sources.
Is the 'trace.ecore' on the latest source or in another place ? (sorry for
this silly question)
Vincent
Sergey Boyko wrote:
> Hi Aranega,
> Sergey.
>> Best regards.
>> Vincent
Re: [QVTO] Trace meta-model ? [message #92792 is a reply to message #92777] Tue, 21 October 2008 03:49 Go to previous messageGo to next message
Hi Vincent,
I had the same problem. I suppose you opened the sources in eclipse via PDE.
However the models are not included in the packages, you should get them
from CVS.
Alfons
"Vincent Aranega" <vincent.aranega@gmail.com> schreef in bericht
news:1b45b8fbeeba2ad6380fe7d612e54892$1@www.eclipse.org...
> Vincent
> Sergey Boyko wrote:
>> Hi Aranega,
>> You're right there's no explicit description of trace metamodel nor trace
>> format in QVT spec.
>> Regards,
>> Sergey.
>>> Hi,
>>> Best regards.
>>> Vincent
Re: [QVTO] Trace meta-model ? [message #92807 is a reply to message #92792] Tue, 21 October 2008 04:11 Go to previous message
Hi Alfons,
I was actually opened the source via PDE. I eventually found the file on
the CVS as you say :).
Thank you very much,
Vincent
Alfons Laarman wrote:
> Hi Vincent,
> from CVS.
> Cheers,
> Alfons
>> Regards,
>> Vincent
>> Sergey Boyko wrote:
>>> Hi Aranega,
>>> format in QVT spec.
>>> Regards,
>>> Sergey.
>>>> Hi,
>>>> Best regards.
>>>> Vincent
Previous Topic:TrasientLinkSet
Next Topic:[ATL] "If then else" with multiple code lines Syntax problem
Current Time: Sun Aug 31 04:28:32 EDT 2025
Powered by FUDForum. Page generated in 0.03976 seconds
