[QVTO] Trace meta-model ? [message #92733] |
Mon, 20 October 2008 04:24  |
I'd like to know where I can find a meta-model or documentation for the
QVTO Traces implementation ?
I've got the impression that smartQVT and QVTO have not the exact same
trace meta-model and OMG Spec don't describe an explicit meta-model for
the trace system.
Best regards.
Vincent
Re: [QVTO] Trace meta-model ? [message #92792 is a reply to message #92777] |
Tue, 21 October 2008 03:49   |
Hi Vincent,
I had the same problem. I suppose you opened the sources in eclipse via PDE.
However the models are not included in the packages, you should get them
from CVS.
Alfons
"Vincent Aranega" <vincent.aranega@gmail.com> schreef in bericht
news:1b45b8fbeeba2ad6380fe7d612e54892$1@www.eclipse.org...
> Thanks for your help. However, I don't found 'trace.ecore' in
> 'org.eclipse.m2m.qvt.oml/model/'. Actually, i don't found any 'model' in
> 'org.eclipse.m2m.qvt.oml' sources.
> Is the 'trace.ecore' on the latest source or in another place ? (sorry for
> this silly question)
> Vincent
> Sergey Boyko wrote:
>> Hi Aranega,
>> You're right there's no explicit description of trace metamodel nor trace
>> format in QVT spec.
>> Trace MM we used can be found at
>> 'org.eclipse.m2m.qvt.oml/model/trace.ecore'.
>> Regards,
>> Sergey.
>> Aranega Vincent wrote:
>>> Hi,
>>> QVTO Traces implementation ? I've got the impression that smartQVT and
>>> QVTO have not the exact same trace meta-model and OMG Spec don't
>>> describe an explicit meta-model for the trace system.
>>> Best regards.
>>> Vincent
Re: [QVTO] Trace meta-model ? [message #92807 is a reply to message #92792] |
Tue, 21 October 2008 04:11  |
Hi Alfons,
I was actually opened the source via PDE. I eventually found the file on
the CVS as you say :).
Thank you very much,
Vincent
Alfons Laarman wrote:
> Hi Vincent,
> from CVS.
> Cheers,
> Alfons
>> Regards,
>> Vincent
>> Sergey Boyko wrote:
>>> Hi Aranega,
>>> format in QVT spec.
>>> Regards,
>>> Sergey.
>>>> Hi,
>>>> Best regards.
>>>> Vincent
FUDForum. Page generated in 0.39440 seconds
