Home » Eclipse Projects » Remote Application Platform (RAP) » Popup menu doesn't work on ToolBar in CTabFolder top-right
Popup menu doesn't work on ToolBar in CTabFolder top-right [message #92547] |
Tue, 10 June 2008 10:59  |
--------------060209060902080300010005
Hi all,
I've created a ToolBar with only one ToolItem of type SWT.DROP_DOWN,
then I've set the ToolBar as the top-right component of a CTabFolder
using setTopRight(...).
In the widgetSelected event of the ToolItem I show a modal popup menu.
When I click on the drop down arrow of ToolItem, the browser (both IE7
and Firefox2.0) dumps a javascript error.
It's a bug or there's another method to show popup menu from ToolItem?
I attach the code snippet and the output from IE7 and Firefox2.0
Enrico
Content-Type: application/octet-stream;
name="CTabFolder_setTopRight_ToolBar.zip"
Content-Disposition: attachment;
filename="CTabFolder_setTopRight_ToolBar.zip"
UEsDBBQAAAAIANODyjhdIC71aAIAAGQHAAAQAAAAY29kZV9zbmlwcGV0LnR4 dJ1V32/aMBB+
r9T/4dqHymhVxHiYJk1Io6NoSIwgyIa0l8ngAyw5dhQbKNr6v8+OQ35As9Ge ULAvd9/n+3yx
wVqyXQi+BC4NLFOkBr8PSQt+X19BbisuqYA+14mgB2DQBYn745y0PpWRsw0K AdpH+Blh1QAd
aDQPaiuZJu17sL+Pbfv40G6fRY3oQW0NcUADLkQ+bVXjytGXiC4GSjBMwaxy +tJH9D3M5lEQ
hROfXiYNDcZg+HufU7iIWfmUcTh+rOS4ULe4CJ8MuQ0l3jYAdi4H7JSA0V7V AE/3IFJKPFBX
o1nkBPNB7iwYvobT4c9wHPVG8CdzDEa9qEa5yhhVMuXrjSEO7H+kvqqVrb6g PbqzfM/cn4aT
X/1wPq6z1TRzabUaTyMpYzMUuDRcyRHXBqXdQEdZeHuMJsY68yYt7XO4wzTl DEt3pcF3ijPY
c7ZG46GQkQLzcYe2/9FDnhhfEcCAoaFcQLebldqbTsM55OHn9g3lFmKvVTbJ VW6OzhSOj/oW
LhKfts25xVV9BzzV5vYCps6bmCrNOsOlkqyR6mXv1MpN5VogpHYE3XzT18Wp 0AQ3Ue6ASoxf
tZ8ShxE83UP2f4B3frBB19dNQEmNdUJTtECtwKjjgZaY15UUZ6eVWlLXRzbb Lcg+DxalOf4H
13whkJh0i6+j22+4VY/cxAHXbslKI7Ofwt2dBV6XwK16b561tEVggT3uWU8y B0PNcmOTbMo/
jAVaICaNm/R8fdVUM/NL9annaQ3T52p49YIQ/jqo3xoqQXl0lVoRuNF1rTJp Tr/wl+QAq8cl
GlRWnKLZphLa9m3+5i9QSwMEFAAAAAgAXIPKOGS3j6PiAAAAkwEAABMAAABm aXJlZm94Ml9v
dXRwdXQudHh0dZCxTgNBDET7SPmHVUQRmpUQoQmiQhFQUIBA1OZuuCza292z vXfw9ziQ6hTa
8fiNPbe5xtalrA4jxUoK90kjScOhqGNIyUmwXS6Wi5fvgh1z5q07g9uT2Jor nAtYA+Rgydx5
NDEUgZdJ/W5E0lcN0UuVgtT+CveU2hhStz6/HoktZHA3br76jKFC1HfQhyRK qYH5zesFehza
8UnBa7farNwfbOpPsN5Ca5hHStSBZ8Sp922wLwWGmS6uDDTXNie0y4M2fPka fJMZxwj/Eavs
72J+p/hUYTdawv+lWL21x7yTH1BLAwQUAAAACAChg8o4B1V9mOUAAACXAQAA DgAAAGllN19v
dXRwdXQudHh0dZAxT8QwDIX3Sv0P1i13LJEQxwJiQggYGEBCzKExISh12thu +cn8DFy4qbqb
orw8f895t0VzACoCOPmsXhC+/OS5q2kQqMhDIcartmmbLWnOW/iB5SxQbIrs pgQlRhQpi6nU
6LDLaWB0PIu7m5DkVVJ2rDwghT/hwVPIieLu7Hry1WJGuIH16AuOiizO2I/E 4qlD85vXMcrh
0dYnwbqDzX4D/7C5P8J6S8EwT558xLoizr0Lyf7JaJj5/NJAa21/RLtYtPHb aXJdqXiIcB9Z
+fM+l3efnxVtR0s4XYoVrD2uO2mbX1BLAQIUABQAAAAIANODyjhdIC71aAIA AGQHAAAQAAAA
AAAAAAAAIAAAAAAAAABjb2RlX3NuaXBwZXQudHh0UEsBAhQAFAAAAAgAXIPK OGS3j6PiAAAA
kwEAABMAAAAAAAAAAAAgAAAAlgIAAGZpcmVmb3gyX291dHB1dC50eHRQSwEC FAAUAAAACACh
g8o4B1V9mOUAAACXAQAADgAAAAAAAAAAACAAAACpAwAAaWU3X291dHB1dC50 eHRQSwUGAAAA
AAMAAwC7AAAAugQAAAAA
--------------060209060902080300010005--
Re: Popup menu doesn't work on ToolBar in CTabFolder top-right [message #92873 is a reply to message #92547] |
Wed, 11 June 2008 11:31   |
Originally posted by: ifurnadjiev.innoopract.com
Hi Enrico,
first of all I can't find these too classes WFToolBar/WFToolItem, that's
why I reworked your snippet based on ToolBar/ToolItem (see the snippet
bellow). Hope that it's working for you.
final ToolBar tftb = new ToolBar(tf, SWT.HORIZONTAL | SWT.FLAT);
tf.setTopRight(tftb);
final ToolItem tfti1 = new ToolItem(tftb, SWT.DROP_DOWN);
tfti1.setText("Tool");
tfti1.addSelectionListener(new SelectionAdapter() {
public void widgetSelected(SelectionEvent e) {
if( e.detail == SWT.ARROW ) {
Menu m = new Menu( tftb.getShell(), SWT.POP_UP );
MenuItem mi1 = new MenuItem(m, SWT.NONE);
mi1.setText("First");
MenuItem mi2 = new MenuItem(m, SWT.NONE);
mi2.setText("Second");
Point point = new Point( e.x, e.y );
m.setLocation( point );
m.setVisible( true );
Best,
Ivan
Enrico Zanaga wrote:
> Hi all,
> Enrico
Re: Popup menu doesn't work on ToolBar in CTabFolder top-right [message #92887 is a reply to message #92873] |
Wed, 11 June 2008 11:54   |
Hi Ivan,
sorry, it's my mistake.
However the reworked code doesn't work for me, but it's working for you?
If yes, can you tell me what version (RAP, Eclipse) are you using, please?
I try the code in 1.1M3 and 1.1RC3 without success...
Enrico
Ivan Furnadjiev ha scritto:
> Hi Enrico,
> @Override
> Best,
> Ivan
>> Hi all,
>> Thanks,
>> Enrico
Re: Popup menu doesn't work on ToolBar in CTabFolder top-right [message #92901 is a reply to message #92887] |
Wed, 11 June 2008 12:19   |
Hi Enrico,
I run it against 1.1RC3 in FF 2.0.0.14, IE7 and Safari 3.1.1 on Windows
XP SP3.
What kind of problems do you have - JavaScript error? Did you use the
exact snippet from my previous post?
Best,
Ivan
> Hi Ivan,
> please?
> Enrico
>> Hi Enrico,
>> that's why I reworked your snippet based on ToolBar/ToolItem (see the
>> snippet bellow). Hope that it's working for you.
>> @Override
>> Best,
>> Ivan
>>> Hi all,
>>> IE7 and Firefox2.0) dumps a javascript error.
>>> Thanks,
>>> Enrico
Re: Popup menu doesn't work on ToolBar in CTabFolder top-right [message #92916 is a reply to message #92901] |
Wed, 11 June 2008 12:57   |
Hi Ivan,
running your snippet in IE7, I get the following javascript error:
Could not evaluate javascript response:
'null' è nullo o non è un oggetto
org.eclipse.swt.EventUtil.suspendEventHandling();var req =
org.eclipse.swt.Request.getInstance();req.setRequestCounter( "3" );var
wm = org.eclipse.swt.WidgetManager.getInstance();wm.dispose( "w15"
);wm.dispose( "w14" );wm.dispose( "w13"
);qx.ui.core.Widget.flushGlobalQueues();org.eclipse.swt.Even tUtil.resumeEventHandling();
Maybe a qooxdoo problem?
In Jetty/Eclipse console nothing happen...
Enrico
> Hi Enrico,
> XP SP3.
> Best,
> Ivan
>> Hi Ivan,
>> please?
>> Thanks,
>> Enrico
>>> Hi Enrico,
>>> @Override
>>> Best,
>>> Ivan
>>>> Hi all,
>>>> Thanks,
>>>> Enrico
Re: Popup menu doesn't work on ToolBar in CTabFolder top-right [message #93004 is a reply to message #92916] |
Thu, 12 June 2008 03:07   |
Hi Enrico,
please attach your complete file to have a look at it.
Ivan
> Hi Ivan,
> Enrico
>> Hi Enrico,
>> Windows XP SP3.
>> Best,
>> Ivan
>>> Hi Ivan,
>>> you?
>>> please?
>>> Thanks,
>>> Enrico
>>>> Hi Enrico,
>>>> the snippet bellow). Hope that it's working for you.
>>>> @Override
>>>> Best,
>>>> Ivan
>>>>> Hi all,
>>>>> menu.
>>>>> ToolItem?
>>>>> Thanks,
>>>>> Enrico
Re: Popup menu doesn't work on ToolBar in CTabFolder top-right [message #93105 is a reply to message #93045] |
Thu, 12 June 2008 08:19  |
Hi Ivan,
it works! Many thanks!
The code in widgetSelected comes from an old version of SWT, and it
continues to work in SWT 3.3 e 3.4 (RCP mode).
Because my application runs both in RCP and RAP the sources are shared,
except a little compatibility library.
I tested the code in both two modes and it works, so this is the final
solution.
Enrico
> Hi Enrico,
> here is the reworked complete code... please test it. You don't need
> this in widgetSelected:
> while (!m.isDisposed() && m.getVisible()) {
> if (!d.readAndDispatch())
> d.sleep();
> m.dispose();
> Hope this will help.
> Best,
> Ivan
>> Hi Ivan,
>> I've attached the class I use to reproduce the problem.
>> Thanks,
>> Enrico
>>> Hi Enrico,
>>> Thanks,
>>> Ivan
>>>> Hi Ivan,
>>>> );var wm = org.eclipse.swt.WidgetManager.getInstance();wm.dispose(
>>>> "w15" );wm.dispose( "w14" );wm.dispose( "w13"
>>>> Thanks,
>>>> Enrico
>>>>> Hi Enrico,
>>>>> Windows XP SP3.
>>>>> the exact snippet from my previous post?
>>>>> Best,
>>>>> Ivan
>>>>>> Hi Ivan,
>>>>>> for you?
>>>>>> please?
>>>>>> Thanks,
>>>>>> Enrico
>>>>>>> Hi Enrico,
>>>>>>> @Override
>>>>>>> Best,
>>>>>>> Ivan
>>>>>>>> Hi all,
>>>>>>>> SWT.DROP_DOWN,
>>>>>>>> CTabFolder
>>>>>>>> menu.
>>>>>>>> (both IE7 and Firefox2.0) dumps a javascript error.
>>>>>>>> ToolItem?
>>>>>>>> Thanks,
>>>>>>>> Enrico
Current Time: Tue Jul 22 13:58:02 EDT 2025
Powered by FUDForum. Page generated in 0.04167 seconds
