Home » Archived » Test and Performance Tools Platform (TPTP) » cant deploy a rule based GLA
cant deploy a rule based GLA [message #8322] Sun, 06 March 2005 08:00 Go to next message
Hi all,
I have a rule based generic log adapter file that works fine in the
adapter file editor (I can scroll through the log file and see output
from FormatterResult etc). But when I run this in a run-time workbench
it complains that the file adapters\My.adapter can not be found (the
file is there and I triple checked the spelling) - error code is IWAT0369E
Probably there is something wrong with the plugin.xml, especially is the
StaticParserWrapper the right class for a rule-based GLA?
Is there any example of a rule-based GLA somewhere?
I'm using hyades release 3.2.0, eclipse 3.0.1, jdk 1.5.0
Thanks a lot for any pointers,
Andreas
<extension
point="org.eclipse.hyades.logging.parsers.logParser">
<parser
name="My Parser"
icon="./icons/full/obj16/apache_access.gif"
description="My Parser"
class=" org.eclipse.hyades.logging.adapter.config.StaticParserWrappe r "
ui_name="My Parser UI"
id="com.tonbeller.tdilog.TdiLogParser">
<field
useBrowse="true"
name="Path"
id="file_path"
browseType="*.log">
</field>
<parserParameter
name="Default"
value="./adapters/My.adapter">
</parserParameter>
</parser>
</extension>
Re: cant deploy a rule based GLA [message #11283 is a reply to message #8322] Mon, 21 March 2005 10:05 Go to previous messageGo to next message
Hi Andreas,
The documentation and samples for creating log file parsers is somewhat
dated. This will be fixed under
https://bugs.eclipse.org/bugs/show_bug.cgi?id=87302. This defect contains an
attachment with some existing parsers that you may find helpful.
In the meantime, might I suggest you consult the product documentation
(Help >> Help Contents). I would suggest including a version filed in your
parser extension point declaration. For example:
<field
useBrowse="false"
defaultValue="v1"
name="Version"
helpContextId=""
tooltip="This is the version"
ui_type="combobox"
id="version">
</field>
Paul
"Andreas Voss" <eclipse@a-voss.de> wrote in message
news:d0eut2$vf1$1@www.eclipse.org...
> Hi all,
> Andreas
> <extension
> <parser
> name="My Parser"
> <field
> useBrowse="true"
> name="Path"
> id="file_path"
> browseType="*.log">
> </field>
> <parserParameter
> name="Default"
> </parserParameter>
> </parser>
> </extension>
Re: cant deploy a rule based GLA [message #1454536 is a reply to message #8322] Tue, 28 October 2014 10:01 Go to previous message
Andreas, I know this is years after this post, but I was wondering if this ever worked for you. If so would you mind sharing some inside?
Arturo
Previous Topic:Open source for performance tools - video
Next Topic:JMeter - Bonita compatibility
Current Time: Sat Jul 26 23:05:30 EDT 2025
Powered by FUDForum. Page generated in 0.19098 seconds
