Home » Eclipse Projects » Eclipse 4 » Perspective and UI Questions
Perspective and UI Questions [message #735] Thu, 28 May 2009 18:43 Go to next message
Hi all,
Only just a few hours into the E4 docs and examples so hopefully my
questions make sense.
In E4 are/will there be support for Perspectives? If not, could somewhat
similar behavior be implemented by having a Handler that manages the
visibility of Parts? If so, is there a way to get a handle to the UI
Model from within a Handler?
Please feel free to just point me in the direction of existing docs if
that is appropriate.
Exciting stuff!
Jesse
Re: Perspective and UI Questions [message #739 is a reply to message #735] Thu, 28 May 2009 19:15 Go to previous messageGo to next message
Yes there are perspectives. They are part of the Workbench-Model.
Tom
Jesse Riggins schrieb:
> Hi all,
> somewhat similar behavior be implemented by having a Handler that
> manages the visibility of Parts? If so, is there a way to get a handle
> to the UI Model from within a Handler?
> Exciting stuff!
> Jesse
Re: Perspective and UI Questions [message #744 is a reply to message #739] Thu, 28 May 2009 20:42 Go to previous messageGo to next message
Ahh I see it there in the Workbench. Thanks!
How about the other question. How does one get a handle to the UI model
when working in the context of a Handler?
Re: Perspective and UI Questions [message #749 is a reply to message #744] Fri, 29 May 2009 14:58 Go to previous messageGo to next message
A lot of this is still up in the air, but ...
If your execute method takes an MWindow as an argument, or an
MContributedPart (depending on where you expect your handler to be
executed) you should get that model part.
You can also ask for MApplication to get the root model object.
PW
Paul Webster
Re: Perspective and UI Questions [message #754 is a reply to message #749] Fri, 29 May 2009 21:30 Go to previous messageGo to next message
Thanks. It's good to know what's still up in the air and what's more
concrete. This is really neat stuff, by the way.
Yet another question. Tom showed me where the Workbench was in the model,
but now I have a few more follow up questions:
How do I create an RCP Application that makes use of the Workbench model?
In particular, I'm looking for the Perspectives. I realize that
MWorkbench contains MWorkbenchWindows which are themselves MWindows. So I
believe that means that they may somehow be able to be incorporated into
the MApplication container, but I can't figure out how my *.xmi file
should look (especially when trying to use the *.xmi editor).
Also, how do you create an *.xmi from scratch? I ended up bringing in the
org.eclipse.e4.ui.model.workbench code into my workspace and generating
and running the editor from it, but is there a better way?
Jesse
Re: Perspective and UI Questions [message #759 is a reply to message #754] Mon, 01 June 2009 09:38 Go to previous message
As for to set it up in the editor, I'm not sure. You should be able to
create an .xmi file that references both Application and Workbench Ecore
to get access to all of the model elements.
But what you would want is and MApplication that contains an
MWorkbenchWindow which contains one or more* MPerspectives.
* only one perspective is supported at the moment.
If you are feeling adventurous you can figure out how to change the
MPerspective processing code to work more like the StackModelFactory.
Multiple perspectives would then be "contained" within a CTabFolder ...
not pretty, perhaps, but it would provide multiple perspectives with
code similar to existing code.
PW
Paul Webster
Re: Perspective and UI Questions [message #561298 is a reply to message #735] Thu, 28 May 2009 19:15 Go to previous message
Tom
> Hi all,
> Exciting stuff!
> Jesse
Re: Perspective and UI Questions [message #561313 is a reply to message #739] Thu, 28 May 2009 20:42 Go to previous message
Re: Perspective and UI Questions [message #561328 is a reply to message #744] Fri, 29 May 2009 14:58 Go to previous message
PW
Paul Webster
Re: Perspective and UI Questions [message #561345 is a reply to message #749] Fri, 29 May 2009 21:30 Go to previous message
Jesse
Re: Perspective and UI Questions [message #561364 is a reply to message #754] Mon, 01 June 2009 09:38 Go to previous message
PW
Paul Webster
Previous Topic:Perspective and UI Questions
Next Topic:news
Current Time: Sun May 25 23:39:55 EDT 2025
Powered by FUDForum. Page generated in 0.04992 seconds
