Home » Language IDEs » C / C++ IDE (CDT) » Problem with make dependencies (subdir.mk files)
Problem with make dependencies (subdir.mk files) [message #92285] Wed, 21 January 2004 06:14 Go to next message
Originally posted by: dpdscell.skypro.be
I'm using Eclipse 3.0M5 and CDT 2.0M5
I've created a Managed make C Project that contains two subdirectories,
sdir1 and sdir2, each with its own src and inc directories. So the view in
the nagigator is something like:
Test
-----sdir1
| ------ inc
| ------ src
-----sdir2
| ------ inc
| ------ src
----- Release
| ----- dir1
| ------ subdir.dep
| ------- subdir.mk
I can build the system fine, but the generated "subdir.dep" files are _NOT_
updated, they are always empty. Then ... should I update these files
manually? Should I modify the top makefile or the subdir.mk files? Any help?
Thank you very much
Joaquin Morcate
Re: Problem with make dependencies (subdir.mk files) [message #92485 is a reply to message #92285] Thu, 22 January 2004 15:16 Go to previous messageGo to next message
Joaquin,
The managed make system does not support manually overriding the
makefiles (it will just overwrite your changes). I will check it out on
M6, but if I were you, I would close and reopen the project to kick the
indexing. The managed make feature relies on the index to calculate the
dependencies so if the index is out-of-date and the indexer unaware that
it has to run again, then the dep file will be empty.
Sean Evoy
DPDS-Cell wrote:
> Test
> -----sdir1
> | ------ inc
> | ------ src
> -----sdir2
> | ------ inc
> | ------ src
> ----- Release
> | ----- dir1
> | ------ subdir.dep
> | ------- subdir.mk
> Thank you very much
> Joaquin Morcate
Re: Problem with make dependencies (subdir.mk files) [message #92514 is a reply to message #92485] Fri, 23 January 2004 08:16 Go to previous messageGo to next message
I tried that also but didn't work. I wonder if the problem is that I didn't
create the sources in the IDE but I imported them. At the end I've moved
to an unmanaged project since the managed make is not really flexible,
it'd be nice to have the possibility of adding a custom segment in
the generated makefiles
Any way, thanks a lot for your advice
Joaquin Morcate
"Sean Evoy" <sevoy@ca.ibm.com> wrote in message
news:bupb8r$pmr$1@eclipse.org...
> Joaquin,
> Sean Evoy
> DPDS-Cell wrote:
> > Hi,
in
> > Test
> > -----sdir1
> > | ------ inc
> > | ------ src
> > -----sdir2
> > | ------ inc
> > | ------ src
> > ----- Release
> > | ----- dir1
> > | ------ subdir.dep
> > | ------- subdir.mk
_NOT_
help?
> > Thank you very much
> > Joaquin Morcate
Re: Problem with make dependencies (subdir.mk files) [message #92529 is a reply to message #92514] Fri, 23 January 2004 10:28 Go to previous message
Hmm,
I still should be able to find the resources in the project, even if
they are imported. Your point about setting aside sections to add
user-supplied make intructions is well taken and is something we are
working towards.
Sean
> Joaquin Morcate
>>Joaquin,
>>Sean Evoy
>>DPDS-Cell wrote:
>>>Hi,
> in
>>>Test
>>>-----sdir1
>>>| ------ inc
>>>| ------ src
>>>-----sdir2
>>>| ------ inc
>>>| ------ src
>>>----- Release
>>>| ----- dir1
>>>| ------ subdir.dep
>>>| ------- subdir.mk
> _NOT_
> help?
>>>Thank you very much
>>>Joaquin Morcate
Previous Topic:No C++ Project menu
Next Topic:How to install and use libsigc++ with CDT?
Current Time: Sat Jul 26 09:14:52 EDT 2025
Powered by FUDForum. Page generated in 0.04221 seconds
