Home » Modeling » GMF (Graphical Modeling Framework) » Nested Rectangles and Layout
Nested Rectangles and Layout [message #92275] Fri, 12 January 2007 15:50 Go to next message
Originally posted by: me.you.com
I have 2 Rectangles in my .gmfgraph, one nested inside the other:
+Rectangle rect1
--+GridLayout
--+Rectangle rect2 (nested)
-----+GridLayoutData
And there are two Nodes:
-Node node1 (Figure rect1)
-Node node2 (Figure rect2)
This doesn't seem to work and causes an error, when generating diagram
code (although it validates without errors).
The reason why I want the Rectangles nested is because I want to use a
GridLayout on rect1 and GridLayoutData on rect2 (I have the GridLayout
patch).
Is it possible at all to use GridLayout on Nodes nested in a Node?
If not how do I go around this problem?
Re: Nested Rectangles and Layout [message #92943 is a reply to message #92275] Mon, 15 January 2007 13:55 Go to previous messageGo to next message
Could you please describe what's the error you get and which GMF version do
you use? With GMF 1.0, node2 might not work because we ensured parent figure
has GridLayout installed, and with node2 this is not true.
Artem
"exquisitus" <me@you.com> wrote in message
news:bfd7b27b23a61ca9c5e484913abf5c44$1@www.eclipse.org...
> Hi
> +Rectangle rect1
> --+GridLayout
> patch).
Re: Nested Rectangles and Layout [message #93215 is a reply to message #92943] Tue, 16 January 2007 07:28 Go to previous messageGo to next message
hello Artem
My GMF is version 2.0 (all plugins are M4).
The error is on Generate Diagram Editor:
Exception occurred while generating code
Unknown viewmap:
org.eclipse.gmf.codegen.gmfgen.impl.ParentAssignedViewmapImp l @18501fd
(requiredPluginIDs: null, layoutType: UNKNOWN) (getterName:
getFigureRect2, setterName: null, figureQualifiedClassName:
org.eclipse.draw2d.RectangleFigure)
I had another idea to try to use FigureRef and nest that into Rect1 and
set GridLayoutData on that FigureRef. Like in this screenshot:
http://img145.imageshack.us/img145/6734/scr2qc7.gif
This generates diagram code without errors, but on runtime when I try to
add Box2 inside Box1 (with GridLayout) I get this error:
Unhandled event loop exception.
in Error Log.
What are FigureRefs useful for (am I using them wrong here)?
Re: Nested Rectangles and Layout [message #95231 is a reply to message #93215] Mon, 22 January 2007 12:49 Go to previous messageGo to next message
This appears to be a bug. Looks like support for child nodes with
parent-assigned viewmaps has been overlooked. Could you please file a
bugzilla?
To workaround the issue, try to pull rect2 (with associated gridlayout data)
out from rect1.
Artem
news:88274b89b65de4123c440759da4fc0ea$1@www.eclipse.org...
> hello Artem
> Unknown viewmap:
> in Error Log.
Re: Nested Rectangles and Layout [message #95351 is a reply to message #95231] Tue, 23 January 2007 04:19 Go to previous messageGo to next message
I tried to put Rect2 outside Rect1 but that couses an error when running
the generated code:
http://img250.imageshack.us/img250/1705/scr43qz.gif
And here's the .gmfmap:
http://img201.imageshack.us/img201/7378/scr54wy.gif
What I'm trying to do is to create a box that has more boxes inside
arranged in GridLayout and I wan't to use just one tool to create that box
with all boxes inside. All boxes should have assigned nodes.
Maybe I will file a bug later.
Re: Nested Rectangles and Layout [message #96211 is a reply to message #95351] Wed, 24 January 2007 13:50 Go to previous messageGo to next message
Guess, I do not understand your usecase and reason you need explicitly
defined child nodes if you merely use them as figures (iow, "All boxes
should have assigned nodes" makes me puzzled). As you .gmfmap screenshot
suggests, you expect to get Box1 with all nested nodes/figures using
Box1Creation tool. If all the nodes/figures are right there at the creation
time (moreover, they need GridLayoutData assigned), what's the purpose of
Rect2Node?
If your usecase is about creating Box2 inside Box1 on demand, than you might
need to tweak Box2's EditPart class, refreshBounds method. Alternatively,
you may use intermediate comparments for each child node (layout constraints
should be attached to compartment in this case).
I've just ran simple GMF sample similar to what you described (two nested
boxes, layout), see attached screenshots. The only change I had to made was
Rect2NodeEditPart#refreshBounds to enforce proper layout data (not
XYLayout's Rectangle which is default for shape-kind children). However, I'm
not sure this is what you are trying to achieve.
Artem
news:24278037413b9fd3217ceadca93b38bd$1@www.eclipse.org...
> the generated code:
Re: Nested Rectangles and Layout [message #96575 is a reply to message #96211] Thu, 25 January 2007 05:19 Go to previous messageGo to next message
hello Artem,
Of course this is just a simple example that highlights my problem, not
really useful by itself.
What I want to do, is to add next nested elements inside Box2 (but this
time on user demand - not on creation). And for that Box2 needs to be a
Node so that I can map a ChildReference in .gmfmap.
Your suggestion to use intermediate compartments is exactly what I'm doing
now! And that works fine, using just Nodes was an alternative solution
that I wanted to try. The problem with using Compartments is that by
default they only support XYLayout and ListLayout with 1 column. I need
other Layouts (preferably GridLayout).
Here's a picture:
http://img407.imageshack.us/img407/6127/scr65wj.gif
I know, not your typical UML diagram :)
Unfortunately I can't see your attachments (I'm using the Web interface to
read this newsgroup and all I get is a column of text characters...). I
appreciate your help though.
> Rect2Node?
> Artem
>> the generated code:
> MB5!.1PT*&@H````-24A$4@```>8```#'" ,```#[R@#:```#`%!,5$4`````
> M`%4``*H``/`) ``)%4`)*H`)/`20``254`2:H`2?`;0``;54`;:H`;?`
> MD@``DE4`DJH`DO`M@``ME4`MJH`MO`VP``VU4`VZH`V_`_P``_U4`_ZH`
> M__D```D`%4D`*HD`/D) `D)%4D)*HD)/D20`D254D2:HD2?D;0`D;54D
> M;:HD;?DD@`DDE4DDJHDDODM@`DME4DMJHDMODVP`DVU4DVZHDV_D_P`D
> M_U4D_ZHD__])``!)`%5)`*I)`/])) !))%5))*I))/])20!)255)2:I)2?])
> M;0!);55);:I);?])D@!)DE5)DJI)DO])M@!)ME5)MJI)MO])VP!)VU5)VZI )
> MV_])_P!)_U5)_ZI)__]M``!M`%5M`*IM`/]M) !M)%5M)*IM)/]M20!M255M
> M2:IM2?]M;0!M;55M;:IM;?]MD@!MDE5MDJIMDO]MM@!MME5MMJIMMO]MVP! M
> MVU5MVZIMV_]M_P!M_U5M_ZIM__^2``"2`%62`*J2`/^2) "2)%62)*J2)/^2
> M20"225622:J22?^2;0"2;562;:J2;?^2D@"2DE62DJJ2DO^2M@"2ME62MJJ2
> MMO^2VP"2VU62VZJ2V_^2_P"2_U62_ZJ2__^V``"V`%6V`*JV`/^V) "V)%6V
> M)*JV)/^V20"V256V2:JV2?^V;0"V;56V;:JV;?^VD@"VDE6VDJJVDO^VM@ "V
> MME6VMJJVMO^VVP"VVU6VVZJVV_^V_P"V_U6V_ZJV___;``#;`%7;`*K;`/_;
> M) #;)%7;)*K;)/_;20#;257;2:K;2?_;;0#;;57;;:K;;?_;D@#;DE7;DJK;
> MDO_;M@#;ME7;MJK;MO_;VP#;VU7;VZK;V__;_P#;_U7;_ZK;____``#_`%7 _
> M`*K_`/__) #_)%7_)*K_)/__20#_257_2:K_2?__;0#_;57_;:K_;?__D@#_
> MDE7_DJK_DO__M@#_ME7_MJK_MO__VP#_VU7_VZK_V____P#__U7__ZK____ J
> MFVXN````"7!(67,``!)T```2= '>9A]X```@`$E$051XG.U]W8X;R;%FW8P!
> M[S/XUL9*P/%3>(!I`>H+O<4!EK5H"IYY"A*GJ1TV,'J)HP&<A <EZ#F=B,R^T
> M+W$NQ@9<&]_W11;9W1P?6:+19)M9XD_]-E51$1D_7T1TY3+^!497^MX]F/=
> M+;[Z[?-<;I^:@TYI=+_]U6^_^MU7S^_]5U^M:FEILM[+;5[3]>O'R&+WM;
> ME).XQ4_^CL_NM[^SI__YO7[WVY=]C>6RQ!2*<?-+//@O__.#%GQ_)HMQ<T[Y
> M7^3?UU=??ZW7;JNOEUJ#D=G&BY<?)HX_?WAJXAQM>?ER;?+*'N=_A7_Q:O+Q
> M8K?QQ1468V=PLWU]]>+5?TX?IS_^<?GG/W^X>OGJI5Z3;7^IU]2VO7IIE]IM
> M?[CO_IY?>NV=4NO3[S2_NO*!LZ^NL*Z_:>6)=B37/E7C.9K]*^9NV/AB9
> M7UV_M.46F_[/,AF=7[ZV#:^GZU?3J]]/KU_]_M6_O;JVKZ]^?X77].H5CGQ
> MOWC8-??QL'_[;U_[5[O67WOXLHM.>W_C4UZO[']Z]?*UO7_SOJ5+2_ S2%A
> M;GKN[R5<O6A+1U?O_CZZ@]7T_],L20C[7=D:OKU50_?OS^)DX?;VW#:[M-
> MD]%X>J7OU]-K.P;'X5O[KA>VV'';E_]C+_WVK_:+QQOA_Q^[V]RNL%'N@K
> MOKUZ_=(>INME@2GQ_!?[ETJR?UJTI5Q]`Z)_?:6#C,P8_S']]:?X_2).?[U]
> M]5J;[(;9^^^O*0M>^?K4WD$B'F5/VGK-1Z+U_O[YJO<6[]_M7:YW=#6W<GS
> MAFG_@CIQ_[P_2&S]P5>O%B6-MM1GOMC4-)8::XGV?30R!R-V+K_%O?BF&/T'
> M8V@G^ICO/FC<?/'^A_M9E_[K78"3?<^?*=_3O,Y#_;MG[7[F#[[CF8'X;=
> M97<'3?L'-R+?H_,+ZB#SZA*/<4FP*9[SJ]:40.V<C-;V,H4KV#MGZZ#Z+_C
> MYM5/Z^^#D?FOTZK?(D]8NX1[)?)?)B#S^O'UQMCUSW#WUT[OWKWR?SU3XS
> MV__)'G2(,)@4S_95H56/)>98(X5VSL;*)65,S:9G&_W+4$K7]]=]O[S]Z >:/
> M$-KUXVW_IL>VZW[J];;LW[A@GOKK"8=+B,(GSMO?<R,.OEY>M/ZGA]+6_Q8
> M?MJZO;_IY-L`[^WP4W7.H4[_!B_UGSBTE^[8WKFKZZ7$+?'*&"X+$/ >/B?
> MX6?*E-T%BA9I;0M9&/1/=M (LG=OELOEFWX5Q<U3N;7[@VUXM_)WNTFVX*[
> M;.M:<L;[,>6::ES;(=][7G,FXE[K]]<^[%O/GFFE=;^F&3;2;]&? >X,5-
> MNNP;_SLX1I_7;][,)_*<'CMYVILWX.4_X.T%5NU7+^PVX/&F1I+E]GM^GY&4
> M+)#=$=[=7'/*)L=(_)%**$(7(M_JIYOOX_>W:=ZN^26:[[W)*D3T^X=;O?U
> MM&SD%1GL[0T.NO:-V/0:]6_MW.6.F<I:O?M%(W>GR<<,CTXM_=+\2^/7'S
> M@$&U?/,UWGFAY=(DU@BA%I+?DN?W&8LX>2QP:6:H8.#BPDDZ@/HI!6/R;OG6
> MEN7B8US<;'L8UUQ`S?R;;*W:?+/Y5O]PQ:[X_[)+=HSX<NDT2EMZ>U<A
> MN=].TXY2^/Z_<;WEWB%MQ[Q!5WV[]VN6?EYO[U^_('VOOOD:V^S8-1[CQ* <^
> MTL2,S^X3=#2]"W*YFH8-'=NT;INIQ-_9:#W2H@*9[=:M:HTQ_O13_;C ZK*]
> M
Re: Nested Rectangles and Layout [message #96823 is a reply to message #96575] Thu, 25 January 2007 10:19 Go to previous message
Well, if Box2 is merely a grouping for other nodes, compartments are the
right choice.
XYLayout and ListLayout are most common use cases, hence the support.
Bugzilla is the forum to get some more ;)
Artem
news:98efeb3c7340eeaf057ce48ac68d1294$1@www.eclipse.org...
> hello Artem,
> Here's a picture:
>> creation time (moreover, they need GridLayoutData assigned), what's the
>> purpose of Rect2Node?
>> might need to tweak Box2's EditPart class, refreshBounds method.
>> Alternatively, you may use intermediate comparments for each child node
>> (layout constraints should be attached to compartment in this case).
>> was Rect2NodeEditPart#refreshBounds to enforce proper layout data (not
>> I'm not sure this is what you are trying to achieve.
>> Artem
>>> the generated code:
>>> box
>> M
Previous Topic:two (maybe a little bit wider) problems with a custom layout
Next Topic:Links for references?
Current Time: Thu Jul 17 22:42:37 EDT 2025
Powered by FUDForum. Page generated in 0.28872 seconds
