Home » Archived » Test and Performance Tools Platform (TPTP) » Executing test suite outside eclipse
Executing test suite outside eclipse [message #92187] Tue, 06 February 2007 03:29 Go to next message
Originally posted by: emilnowak1980.o2.pl
I'm trying to execute tptp test suite outside eclipse using .bat script
from org.eclipse.hyades.execution directory placed in eclipse\plugins
folder.
I try to execute test suite in this way (from command line):
automation-client-adapter.bat -eclipse pathToEclipse -workspace
pathToWorkspace -project pathToProject -suite pathAndNameOfSuiteFile
And running this i get an exception:
org.eclipse.core.runtime.CoreException: Plug-in
org.eclipse.hyades.test.tools.core was unable to load class
org.eclipse.hyades.test.tools.core.services
..TestExecutionService.
org.eclipse.core.internal.registry.osgi.RegistryStrategyOSGI .throwException(RegistryStrategyOSGI.java:165)
org.eclipse.core.internal.registry.osgi.RegistryStrategyOSGI .createExecutableExtension(RegistryStrategyOSGI.java:149)
org.eclipse.core.internal.registry.ExtensionRegistry.createE xecutableExtension(ExtensionRegistry.java:759)
org.eclipse.core.internal.registry.ConfigurationElement.crea teExecutableExtension(ConfigurationElement.java:243)
org.eclipse.core.internal.registry.ConfigurationElementHandl e.createExecutableExtension(ConfigurationElementHandle.java: 51)
org.eclipse.hyades.automation.server.ServiceProxy.<init>(ServiceProxy.java:81)
org.eclipse.hyades.automation.server.AutomationServer.run(Au tomationServer.java:254)
org.eclipse.core.internal.runtime.PlatformActivator$1.run(Pl atformActivator.java:78)
org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher .runApplication(EclipseAppLauncher.java:92)
org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher .start(EclipseAppLauncher.java:68)
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:400)
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:177)
at org.eclipse.core.launcher.Main.invokeFramework(Main.java:336 )
at org.eclipse.core.launcher.Main.basicRun(Main.java:280)
at org.eclipse.core.launcher.Main.run(Main.java:977)
at org.eclipse.core.launcher.Main.main(Main.java:952)
org.eclipse.core.runtime.CoreException[1]:
java.lang.ClassNotFoundException:
org.eclipse.hyades.test.tools.core.services.TestExecutionSer vice
org.eclipse.osgi.framework.internal.core.BundleLoader.findCl ass(BundleLoader.java:402)
org.eclipse.osgi.framework.internal.core.BundleLoader.findCl ass(BundleLoader.java:347)
org.eclipse.osgi.internal.baseadaptor.DefaultClassLoader.loa dClass(DefaultClassLoader.java:83)
org.eclipse.osgi.framework.internal.core.BundleLoader.loadCl ass(BundleLoader.java:278)
org.eclipse.osgi.framework.internal.core.BundleHost.loadClas s(BundleHost.java:227)
org.eclipse.osgi.framework.internal.core.AbstractBundle.load Class(AbstractBundle.java:1245)
org.eclipse.core.internal.registry.osgi.RegistryStrategyOSGI .createExecutableExtension(RegistryStrategyOSGI.java:147)
Any ideas ?
Thanks in advance,
EN
Re: Executing test suite outside eclipse [message #98588 is a reply to message #92187] Mon, 14 May 2007 08:04 Go to previous messageGo to next message
Hi enowak,
You need to add the follow JARs to the classpath (e.g. append to the -cp
VM parameter) for test execution to the automation-client-adapter.bat
script:
<Eclipse installation
directory> /plugins/org.eclipse.hyades.test.tools.core/common.runner.ja r
directory> /plugins/org.eclipse.hyades.test.tools.core/http.hexrecr.jar
directory> /plugins/org.eclipse.hyades.test.tools.core/http.hextgen.jar
directory>/plugins/org.eclipse.hyades.test.tools.core/http.runner.jar
directory>/plugins/org.eclipse.hyades.test.tools.core/java.runner.jar
directory> /plugins/org.eclipse.hyades.test.tools.core/manual.runner.ja r
directory>/plugins/org.eclipse.hyades.test.tools.core/tools-core.jar
Paul
"enowak" <emilnowak1980@o2.pl> wrote in message
news:eq9e8p$o0$1@utils.eclipse.org...
> folder.
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at java.lang.ClassLoader.loadClass(Unknown Source)
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> Any ideas ?
> Thanks in advance,
> EN
Re: Executing test suite outside eclipse [message #99105 is a reply to message #92187] Wed, 23 May 2007 09:09 Go to previous message
Hi EN,
The command line you describe should work - there should be no need to
add additional jar files to the classpath. If that workaround fixed
your problem, then this is a bug.
Can you please tell us what version of TPTP you are using and how you
installed it? Does the Test perspective load properly in your
workbench, and are you able to run this same test from within the
workbench (using the same workspace and project)?
Here is an example I just tried using TPTP 4.4 i3 and the resulting output:
C:\TPTP_TestPass\4.4i3_testpass1c\eclipse\plugins\org.eclips e.hyades.execution_4.4.0.200705151029 >automation-client-adapter.bat
-eclipse C:\TPTP_TestPass\4.4i3_testpass1c\eclipse -workspace
C:\TPTP_TestPass\4.4i3_testpass1c\eclipse\workspace -project
org.eclipse.tptp.test.testservices.tests -suite
junit\Test.RemoteTestServices.testsuite
C:\TPTP_TestPass\4.4i3_testpass1c\eclipse\plugins\org.eclips e.hyades.execution_4.4.0.200705151029 >java
-cp ./bin;tptp-automation-client.jar
org.eclipse.hyades.automation.client.adapters.shell.Automati onClientAdapter
Test started!
Test 'junit\Test.RemoteTestServices.testsuite' executing
Waiting.....
Collected results:
'org.eclipse.hyades.models.common.testprofile.impl.TPFExecut ionResultImpl @62ec62ec
(eProxyURI:
platform:/resource/org.eclipse.tptp.test.testservices.tests/ Test.RemoteTestServices_1179925549105.execution#D000D7D12307 6D820C4FA300A73211DA)'
Test 'junit\Test.RemoteTestServices.testsuite' completed
Test completed!
--Joe
Previous Topic:Ant - ResourceException: Resource does not exist - incorrectly creating filepath
Next Topic:running tptp:publication getting java.lang.Exception
Current Time: Mon Jul 21 20:03:16 EDT 2025
Powered by FUDForum. Page generated in 0.04813 seconds
