Home » Modeling » BPEL Designer » Does BPEL validator require Java 6.0?
Does BPEL validator require Java 6.0? [message #8297] Fri, 22 June 2007 12:50 Go to next message
After updating bpel validator source code the project failed to build
complaining about "The method getCharacterOffset() is undefined for the
type XMLLocator" in
org.eclipse.bpel.validator.helpers.LocationCapturingDOMParse r.java.
Upgrading my jdk from 1.5.0.11 to 1.6.0.01 fixed the issue. Is 1.6 now
required?
Re: Does BPEL validator require Java 6.0? [message #8362 is a reply to message #8297] Fri, 22 June 2007 17:59 Go to previous message
Les,
This was a snafu on my part.
It should be fixed now. 1.5 is what the dependency is on.
-m
> type XMLLocator" in
> required?
Previous Topic:any chance to edit BPEL 1.1 processes?
Next Topic:Code on tip is Europa and WTP 2.0 dependent.
Current Time: Sun Jun 01 07:25:15 EDT 2025
Powered by FUDForum. Page generated in 0.06515 seconds
