Extending IAnalysisResultView [message #92109] |
Thu, 01 February 2007 10:52  |
Originally posted by: junk.gianfagna.net
I'm looking for some pointers on extending IAnalysisResultView. I'd like to
create a custom result view to display more detailed result information. I
spent some time pouring through plug-in config files and source code and I'm
a little lost...
I tried adding a plug-in extension of
org.eclipse.tptp.platform.analysis.core.ui.analysisResultVie w, but it just
seemed to call the ResultViewDefault implementation. Any thoughts about
what I'm missing?
Is it possible to do this without also creating a new CodeReviewProvider?
I'd like to leverage what is already in the C code review plug-in, but
provide a different UI to view results.
Any help would be much appreciated.
Thanks.
--Andy
Re: Extending IAnalysisResultView [message #92352 is a reply to message #92336] |
Wed, 07 February 2007 23:24  |
Steve,
Nice, that's exactly what I was looking for. I was developing with the 4.3
branch before, I've since switched to HEAD and picked up the change your
talked about. My new placeholder view renders in there as expected. Thanks
so much for the info.
--Andy
"Steve Gutz" <sgutz@ca.ibm.com> wrote in message
news:eqdb6h$f8l$1@utils.eclipse.org...
> For TPTP 4.4 there is a new extension point that will allow you to poke
> your own renderer into the result view. This will permit you to use the
> current default tree view or to insert something like a table view. Using
> the org.eclipse.tptp.platform.analysis.core.ui.analysisResultVie w
> extension point is the right thing to do, so you're already on your way.
> Give your extension an id and refer to a class that implements
> IAnalysisResultView (you probably also want to implement
> AnalysisHistoryListener to catch history events too). Also in the
> extension assign a provider id (i.e. codereview.java.analysisProvider is
> the id for Java code review provider) so the framework knows which
> provider your renderer is for. Give your exntesion a label - this will
> appear in the UI in a combobox in the result view.
> You can model your rendering class after
> org.eclipse.tptp.platform.analysis.core.ui.views.ResultViewD efault, which
> you can find in the TPTP source.
> Steve
> "Andy Gianfagna" <junk@gianfagna.net> wrote in message
> news:ept2be$m9u$1@utils.eclipse.org...
>> to create a custom result view to display more detailed result
>> information. I spent some time pouring through plug-in config files and
>> source code and I'm a little lost...
>> just seemed to call the ResultViewDefault implementation. Any thoughts
>> about what I'm missing?
>> Thanks.
>> --Andy
FUDForum. Page generated in 0.29418 seconds
