folding in the editor? [message #92067] |
Fri, 11 July 2003 14:35  |
Originally posted by: robinson.cs.stanford.edu
We're writing an Eclipse plugin to display the results of some program
analysis research. It would be very useful if the Eclipse Java editor and
CDT's C/C++ editor supported folding. By "folding," I mean the ability to
selectively hide parts of the source code, with a visual indication that
some of it is not being shown. In this way, we could effectively display
program slices (specific lines of code that are relevant to certain parts
of the analysis results).
For example, we'd ideally like to be able to take code that looks like this:
int foo(int a)
int someVar;
int someOtherVar;
someVar = a;
someOtherVar = globalV;
if (someVar == 10) {
someOtherVar++;
for (int i = 0; i < 5; i++) {
cout << i << endl;
someVar -= 5;
return someVar;
And then if we wanted to focus only on lines that affected "someVar," for
instance, we could use folding to display this in the editor:
int foo(int a) {
int someVar;
someVar -= 5;
return someVar;
But when this is displayed in the editor, the line numbers reflect the
real line numbers in the full source code, etc. The plus signs might be
clickable to allow the user to reveal the elided code.
I know that Emacs has this functionality, but I haven't seen anything like
this in Eclipse. Does support for this exist?
Will Robinson
Re: folding in the editor? [message #92168 is a reply to message #92067] |
Fri, 11 July 2003 16:22   |
Will Robinson wrote:
> Hello,
Danger, Will Robinson! (Yes, I'm an ass, I'm sure you probably get that
a lot, but I couldn't resist. :-))
There is no support for this in the Java editor, but you might wish to
add your comments to the following bug:
https://bugs.eclipse.org/bugs/show_bug.cgi?id=9355
I don't know if there is a similar bug for the C/C++ editor.
Jeff
FUDForum. Page generated in 0.04030 seconds
