Home » Archived » BIRT » Images problems with PDF Output
Images problems with PDF Output [message #91935] Thu, 17 November 2005 09:02 Go to next message
Originally posted by: nicolasmondon.gmail.com
When I try to put an image, i obtain this :
embedded way : no problem for the HTML output, but no Image with the PDF
URI way : the image appears in the HTML output but I got an error, the
same for the PDF but the image doesn't appears ...
here is the kind of error i got :
There are errors in Image:null
Unexpected end of file (#1) ...
If somebody can help me ...
Re: Images problems with PDF Output [message #92061 is a reply to message #91935] Thu, 17 November 2005 10:17 Go to previous messageGo to next message
In fact, now I can have image on the PDF output - but only .bmp ...
But i still have an error when I try the URI way ...
Re: Images problems with PDF Output [message #92520 is a reply to message #92061] Fri, 18 November 2005 07:49 Go to previous message
Originally posted by: mlorenz.nc.rr.com
I had problems when using .BMP files. I recommend (as others did for me
here) to use .JPG files. This helped greatly. Also, are your problems
when running the report or in Preview?
HTH, Mark
Previous Topic:Date Format
Next Topic:How to put Synopsis in the report ?
Current Time: Tue Jul 22 02:29:05 EDT 2025
Powered by FUDForum. Page generated in 0.06521 seconds
