Home » Language IDEs » Java Development Tools (JDT) » Two programmers sharing the same project?
Two programmers sharing the same project? [message #91923] Wed, 03 September 2003 15:32 Go to next message
Is it possible to enable some kind of file locking when two programmers are
using the same project on a network share? CVS does not seem an option
because we want to lock the file while it is being edited, much like
SourceSafe checkin/checkout. Any ideas?
Best Regards,
Martin Cordova
http://java.megaserv.com
Re: Two programmers sharing the same project? [message #92078 is a reply to message #91923] Thu, 04 September 2003 03:39 Go to previous messageGo to next message
> programmers are using the same project on a network share? CVS does
> not seem an option because we want to lock the file while it is being
> edited, much like SourceSafe checkin/checkout. Any ideas?
I haven't used it, but as far as I know, you can do this in CVS using
watches.
But why would you want to do this???
Curious, Ilja
Re: Two programmers sharing the same project? [message #92165 is a reply to message #91923] Thu, 04 September 2003 08:38 Go to previous message
There are plugins available for most Version control software that
allow one to checkin/out/lock files.
On Wed, 3 Sep 2003 15:32:14 -0400, "Martin Cordova"
>Best Regards,
>Martin Cordova
Previous Topic:Can't convince Eclipse to build with non-default JRE
Next Topic:Field cannont be resolved!
Current Time: Sat Aug 30 22:55:00 EDT 2025
Powered by FUDForum. Page generated in 0.08651 seconds
