Home » Archived » COSMOS » Failed trying to regenerate the samples - some handholding required...
Re: Failed trying to regenerate the samples - some handholding required... [message #9338 is a reply to message #9270] |
Wed, 08 August 2007 09:32   |
------=_NextPart_000_0009_01C7D9D1.4DB2BC60
Content-Type: text/plain;
charset="iso-8859-1"
"David Whiteman" <david_whiteman@us.ibm.com> wrote in message =
news:f98aa9$uiq$1@build.eclipse.org...
> Try setting the value of derby.system.home on the command line of the=20
> Ant launch script to the location of your derby database directory. =
For=20
> example:
>=20
> -Dderby.system.home=3DC:\apache-tomcat-5.5.23\webapps\databa se
I was actually trying to run these scripts from within eclipse (i.e. =
right-clicking on them in the Package explorer and then Run as... =3D> =
ANT build), not on the command line.
So I first tried the corresponding equivalent of the above definition =
and added "derby.system.home" as an additional ANT property (using =
Windows =3D> Preferences =3D> Ant =3D> Runtime =3D> Properties tab). =
Alas, that didn't change anything.
However, analyzing the script a bit further I figured out, that the =
failing operation is actually the very last anyway. I.e. after the =
creation of the DB its content is for some reason zip-ed up as a jar =
which is placed into the project's home directory. I don't quite =
understand what that's good for (backup of the virgin DB?) but if I =
understand this correct, then this line shouldn't change anything anyway =
with respect to the later running tomcat, serving data from that DB, =
should it?
What I thus did was prefixing the basedir-value with the above property, =
i.e.:
<target name=3D"jarup">=20
<zip destfile=3D"cosmosdb.jar"
basedir=3D"${derby.system.home}/cosmosdb"/>
<echo message=3D"Finished building cosmosdb"/>
</target>
And after that change I indeed got:
Buildfile: =
C:\JavaDevt\org.eclipse.cosmos\data-collection\org.eclipse.c osmos.dc.loca=
l.registry\persistence_setup\build.xml
buildschema:
jarup:
[zip] Building zip: =
l.registry\persistence_setup\cosmosdb.jar
[echo] Finished building cosmosdb
cosmosdb:
BUILD SUCCESSFUL
Total time: 4 seconds
So, can you confirm that I didn't modify the semantic here, i.e. that =
this script still does what the original script has been intended to do?
Why is the freshly created DB zipped up and copied over to the project's =
directory? Who or what tool is supposed to use it there?
Michael
Content-Type: text/html;
<HTML><HEAD>
charset=3Diso-8859-1">
<META content=3D"MSHTML 6.00.6000.16481" name=3DGENERATOR>
<STYLE></STYLE>
</HEAD>
<BODY bgColor=3D#ffffff background=3D"">
<DIV><BR><FONT face=3DArial size=3D2>"David Whiteman"=20
<david_whiteman@us.ibm.com> wrote in message=20
news:f98aa9$uiq$1@build.eclipse.org...<BR>>...<BR>> Try setting =
the value=20
of derby.system.home on the command line of the <BR>> Ant launch =
script to=20
the location of your derby database directory. For <BR>>=20
example:<BR>> <BR>>=20
-Dderby.system.home=3DC:\apache-tomcat-5.5.23\webapps\databa se <BR><BR>I =
was=20
right-clicking on=20
them in the Package explorer and then Run as... =3D> ANT build), not =
on the=20
command line.</FONT></DIV>
<DIV><FONT face=3DArial size=3D2>So I first tried the corresponding =
equivalent of=20
the above definition and </FONT><FONT face=3DArial size=3D2>added=20
"derby.system.home" as an additional ANT property (using Windows =3D> =
Preferences =3D> Ant =3D> Runtime =3D> Properties tab). Alas, =
that didn't=20
change anything.<BR><BR>However, analyzing the script a bit further I =
figured=20
out, that the failing operation is actually the very last anyway. I.e. =
after the=20
which is=20
placed into the project's home directory. </FONT><FONT face=3DArial =
size=3D2>I=20
don't quite understand what that's good for (backup of the virgin DB?) =
but if I=20
understand this correct, then this line shouldn't change =
anything=20
anyway with respect to the later running tomcat, serving data from that =
DB,=20
should it?</FONT></DIV>
<DIV><FONT face=3DArial size=3D2></FONT> </DIV>
<DIV><FONT face=3DArial size=3D2>What I thus did was prefixing the=20
basedir-value with the above property, i.e.:<BR><BR><target =
name=3D"jarup">=20
<BR><zip destfile=3D"cosmosdb.jar"<BR>basedir=3D"<FONT=20
color=3D#ff0000>${derby.system.home}/</FONT>cosmosdb"/> <BR><echo=20
message=3D"Finished building =
cosmosdb"/><BR></target></FONT></DIV >
<DIV><FONT face=3DArial size=3D2></FONT><BR><FONT face=3DArial =
size=3D2>And after that=20
change I indeed got:<BR></FONT></DIV>
<DIV><FONT face=3DArial size=3D2>Buildfile:=20
l.registry\persistence_setup\build.xml<BR>buildschema:<BR >jarup:<BR>[zip]=
=20
Building zip:=20
l.registry\persistence_setup\cosmosdb.jar<BR>[echo]=20
Finished building cosmosdb<BR>cosmosdb:<BR>BUILD SUCCESSFUL<BR>Total =
time: 4=20
seconds<BR><BR>So, can you confirm that I didn't modify the =
semantic here,=20
i.e. that </FONT><FONT face=3DArial size=3D2>this script still =
does what the=20
original script has been intended to do?</FONT></DIV>
<DIV><FONT face=3DArial size=3D2>Why is the freshly created DB zipped up =
and copied=20
over to the project's directory? Who or what tool is supposed to use it=20
there?</FONT></DIV><FONT face=3DArial size=3D2>
<DIV><BR>Regards,<BR>Michael</DIV>
<DIV></FONT> </DIV></BODY></HTML>
------=_NextPart_000_0009_01C7D9D1.4DB2BC60--
Re: Failed trying to regenerate the samples - some handholding required... [message #9361 is a reply to message #9338] |
Wed, 08 August 2007 11:43   |
> > Ant launch script to the location of your derby database directory. For
> > example:
> > -Dderby.system.home=C:\apache-tomcat-5.5.23\webapps\database
> right-clicking on them in the Package explorer and then Run as... => ANT
> Windows => Preferences => Ant => Runtime => Properties tab). Alas, that
I run them within Eclipse too, but when you run an Ant script there, it
shows up as a launch configuration. So I edit the launch configuration
on the Run... menu to set any command line arguments. I'm not convinced
setting it as an Ant property is the same as setting a command line
argument.
> should it?
> i.e.:
> <target name="jarup">
> <zip destfile="cosmosdb.jar"
> basedir="${derby.system.home}/cosmosdb"/>
> <echo message="Finished building cosmosdb"/>
> </target>
> Buildfile:
> C:\JavaDevt\org.eclipse.cosmos\data-collection\org.eclipse.c osmos.dc.local.registry\persistence_setup\build.xml
> buildschema:
> jarup:
> [zip] Building zip:
> C:\JavaDevt\org.eclipse.cosmos\data-collection\org.eclipse.c osmos.dc.local.registry\persistence_setup\cosmosdb.jar
> cosmosdb:
> BUILD SUCCESSFUL
I'll have to defer to one of the data collection experts on these
questions...
David
Re: Failed trying to regenerate the samples - some handholding required... [message #9384 is a reply to message #9361] |
Wed, 08 August 2007 14:22   |
In response to the question about jarring up the database directory, I have
always been using the derby database without making the database a jar file.
Since I wasn't the creator of this script, I'm not sure what is the purpose
of this step. There may be a derby feature that allows the database
directory to be jarred up. But it is safe to ignore that error, or remove
the step for jarring up the database directory. I will open a bug to
address this problem.
Hubert
news:f9coan$3ob$1@build.eclipse.org...
>> For
>> > example:
>> So I first tried the corresponding equivalent of the above definition and
>> added "derby.system.home" as an additional ANT property (using Windows =>
>> Preferences => Ant => Runtime => Properties tab). Alas, that didn't
>> change anything.
> shows up as a launch configuration. So I edit the launch configuration on
> argument.
>> should it?
>> i.e.:
>> </target>
>> Buildfile:
>> buildschema:
>> jarup:
>> [zip] Building zip:
>> cosmosdb:
>> BUILD SUCCESSFUL
> questions...
> David
Re: Failed trying to regenerate the samples - some handholding required... [message #9434 is a reply to message #9408] |
Fri, 10 August 2007 16:06  |
> Where exactly do you enter these?
> To test your suggestion I removed my prior modification in the
> build.xml and then entered
> "-Dderby.system.home=C:\Tomcat_5.5\webapps\database" (which is the path
> on my system)
> first, on the ant launch config's Main tab (under Arguments) - that did
> not work - and
> then I tried on the JRE tab (under VM arguments) - that did not work
> either - and
> lastly I tried on the Environment tab and added the above as an
> environment variable. No success either.
> So where whould this be entered???
> Michael
Since it's an Ant script referring to a variable, I would expect you
could enter it in the Arguments field on the Main tab. I created a
simple Ant script where I echo'd a variable "foo" and in the launch
config passed its value in the Arguments field as "-dfoo=bar" and the
value printed was "bar". So I was expecting something similar to work
for you, since the Ant script you're running uses ${derby.system.home}.
I know that I needed to do that when I created the OSG debug environment
launch configuration described in the End-to-End scenario
documentation on the wiki.
David
Re: Failed trying to regenerate the samples - some handholding required... [message #569878 is a reply to message #8270] |
Fri, 03 August 2007 08:33  |
I just detected, that for some strange reason my ant-home (Window =>
Preferences => Ant => Runtime => Classpath => Ant Home Entries) was
still set to a very old, no more existing eclipse version. Fixing that
solved the ".. .Could not find main..." bug.
The ant-script now starts but fails with another strange error:
---------- console ----------
Buildfile:
buildschema:
BUILD FAILED
C:\JavaDevt\org.eclipse.cosmos\data-collection\org.eclipse.c osmos.dc.local.registry\persistence_setup\build.xml:16:
Java returned: 1
Total time: 1 second
The error location given is in line 16 of the build.xml is in a java -
element):
<target name="buildschema">
<java classname="org.apache.derby.tools.ij"
output="registrySchema.out"
failonerror="true"
dir="." fork="true"> <<<<<<<<<<<<<<<<< the script fails
here
<classpath>
<pathelement path="${lib.dir}/derby.jar"/>
Again: any clue what's wrong?
Michael
Re: Failed trying to regenerate the samples - some handholding required... [message #569962 is a reply to message #8300] |
Fri, 03 August 2007 11:55  |
Hi Michael,
Please make one change in the build.xml to make it work. The 5th line of
the ant currently looks like:
<property name="lib.dir" value="../../org.eclipse.cosmos.dc.tests/lib"/>
Please change the value to the lib directory of the derby install. The lib
directory contains derby.jar and derbytools.jar which are used by the ant
script to create database.
Hubert
"Michael Moser" <mmo@zurich.ibm.com> wrote in message
news:f8v7bc$tq3$1@build.eclipse.org...
>Preferences => Ant => Runtime => Classpath => Ant Home Entries) was still
>set to a very old, no more existing eclipse version. Fixing that solved the
> Buildfile:
> buildschema:
> BUILD FAILED
> Java returned: 1
> element):
> failonerror="true"
> dir="." fork="true"> <<<<<<<<<<<<<<<<< the script fails here
> <classpath>
> Michael
Re: Failed trying to regenerate the samples - some handholding required... [message #570081 is a reply to message #8397] |
Mon, 06 August 2007 08:57  |
I changed that line to
value=" C:/JavaDevt/org.eclipse.cosmos/tests/data-collection/org.ecl ipse.cosmos.dc.tests/lib "/>
(which is, where the derby stuff got checked out to) and then tried
again to run the build.xml, but no difference. I still get this "Java
returned 1" error decribed in my first append.
Michael
"Hubert Leung" <hkyleung@ca.ibm.com> wrote in message
news:f8vj50$n6a$1@build.eclipse.org...
> Hi Michael,
> of the ant currently looks like:
> The lib directory contains derby.jar and derbytools.jar which are used
> by the ant script to create database.
> Hubert
>> Buildfile:
>> buildschema:
>> BUILD FAILED
>> Java returned: 1
>> java - element):
>> failonerror="true"
>> here
>> <classpath>
>> Michael
Re: Failed trying to regenerate the samples - some handholding required... [message #570123 is a reply to message #8491] |
Mon, 06 August 2007 10:59  |
I created a junction (Window's version of a hard link) called
"C:\Tomcat_5.5" pointing to my "C:\Program Files\Apache Software
Foundation\Tomcat 5.5" directory and then changed the path in the apache
..conf directory as well as in the build.xml directory to the new path
"C:\Tomcat_5.5\webapps\database". The DB creation now properly starts
and continues for a while (and also creates and starts populating a
directory "C:\Tomcat_5.5\webapps\database\cosmosdb") but eventually
fails with an error:
Buildfile:
buildschema:
jarup:
BUILD FAILED
C:\JavaDevt\org.eclipse.cosmos\data-collection\org.eclipse.c osmos.dc.local.registry\persistence_setup\build.xml:59:
not found.
Total time: 6 seconds
So,
1.) the build seems to require paths without blank and
2.) apparently, some part of the build-file assumes the DB to be created
in a subdirectory of the project, that contains the build.xml file, not
where the "lib.dir" property points to (which, in my case, is in a
subdirectory of the tomcat-webapp).
Michael
Re: Failed trying to regenerate the samples - some handholding required... [message #570228 is a reply to message #8572] |
Mon, 06 August 2007 19:19  |
example:
Re: Failed trying to regenerate the samples - some handholding required... [message #570326 is a reply to message #9270] |
For=20
> example:
>=20
should it?
i.e.:
</target>
Buildfile: =
buildschema:
jarup:
cosmosdb:
BUILD SUCCESSFUL
Michael
<HTML><HEAD>
<STYLE></STYLE>
</HEAD>
the value=20
script to=20
was=20
on the=20
equivalent of=20
that didn't=20
figured=20
after the=20
which is=20
size=3D2>I=20
but if I=20
anything=20
DB,=20
name=3D"jarup">=20
=20
Building zip:=20
time: 4=20
semantic here,=20
does what the=20
and copied=20
Re: Failed trying to regenerate the samples - some handholding required... [message #570396 is a reply to message #9338] |
> > example:
argument.
> should it?
> i.e.:
> </target>
> Buildfile:
> buildschema:
> jarup:
> [zip] Building zip:
> cosmosdb:
> BUILD SUCCESSFUL
questions...
David
Re: Failed trying to regenerate the samples - some handholding required... [message #570416 is a reply to message #9361] |
Hubert
>> For
>> > example:
>> change anything.
> argument.
>> should it?
>> i.e.:
>> </target>
>> Buildfile:
>> buildschema:
>> jarup:
>> [zip] Building zip:
>> cosmosdb:
>> BUILD SUCCESSFUL
> questions...
> David
Re: Failed trying to regenerate the samples - some handholding required... [message #570429 is a reply to message #9361] |
Fri, 10 August 2007 06:18  |
>> the
>> directory. For
>> > example:
> it shows up as a launch configuration. So I edit the launch
> configuration on the Run... menu to set any command line arguments.
> I'm not convinced setting it as an Ant property is the same as setting
> a command line argument.
on my system)
not work - and
either - and
Michael
Re: Failed trying to regenerate the samples - some handholding required... [message #570496 is a reply to message #9408] |
> on my system)
> not work - and
> either - and
> Michael
David
Current Time: Sat Jun 07 06:57:24 EDT 2025
Powered by FUDForum. Page generated in 0.06897 seconds
