Home » Eclipse Projects » Dynamic Languages Toolkit (DLTK) » JRuby debugging?
JRuby debugging? [message #8268] Mon, 02 July 2007 16:36 Go to next message
Dear All --
I would like to run and debug scripts using JRuby. I understand there is
no "official" support for it yet, but maybe somebody knows a workaround?
Thank you,
-- Sasha
Re: JRuby debugging? [message #8517 is a reply to message #8268] Thu, 19 July 2007 06:21 Go to previous messageGo to next message
Hello Sasha,
The latest version of DLTK (from CVS HEAD) allows to use JRuby as
interpreter for running scripts and supports debugging.
To install JRuby interpreter go to
Window->Preferences->Ruby->Interperters, press 'Add' button and select
jruby.bat (for Windows) as 'Interpreter executable'. Library locations
should be detected automatically.
To start debugging go to Window->Preferences->Debug and selection 'Basic
Ruby Debugging Engine', then start debug launch as usual.
Dmitriy Kovalev
> Dear All --
> Thank you,
> -- Sasha
Re: JRuby debugging? [message #9970 is a reply to message #8517] Thu, 19 July 2007 19:43 Go to previous messageGo to next message
Dmitriy --
That's great news. Do you know when this code will make it into the
integration build? I am not sure I have the courage to build plugin from
sources right now :-)
Today's integration build I-I200707191353-200707191353 didn't work for me.
-- Sasha
Dmitriy Kovalev wrote:
> Hello Sasha,
> Dmitriy Kovalev
>> Dear All --
>> Thank you,
>> -- Sasha
Re: JRuby debugging? [message #9992 is a reply to message #9970] Fri, 20 July 2007 00:44 Go to previous message
I've committed changes for JRuby support after this integration build,
so the next integration will contain required modifications. We'll try
to build next integration on Friday or at the beginning of next week.
Dmitriy Kovalev
> Dmitriy --
> -- Sasha
>> Hello Sasha,
>> Dmitriy Kovalev
>>> Dear All --
>>> Thank you,
>>> -- Sasha
Previous Topic:DLTK Ruby & Watir
Next Topic:Search contribution
Current Time: Sun Jul 06 09:24:36 EDT 2025
Powered by FUDForum. Page generated in 0.03813 seconds
