Home » Archived » Visual Editor (VE) » VE crashes when loading Table
VE crashes when loading Table [message #91747] Thu, 19 May 2005 07:31 Go to next message
--------------000902030506060000010700
unfortunately my visual editor crashes (always !) when I try to load the
JavaTest.java (see attached file). There are no problems when loading
other files. The problem only appears when I try to load a table with
tableitems. When there are no tables on the shell, then there are no
errors with my files.
I'm using Eclipse 3.0.1 and VE 1.0.2.1 on a windows xp pro machine.
Eclipse hangs up on 75% when loading/ building the shell while
"initializing the model" (progress window). Then I can only restart
Eclipse, but I cannot load the Table on the shell.
Could anybody help me?? Please try loading the attached file and please
tell my what happens!
thx
Flik
name="JavaTest.java"
Content-Disposition: inline;
filename="JavaTest.java"
import org.eclipse.swt.widgets.Composite;
import org.eclipse.swt.widgets.TabFolder;
import org.eclipse.swt.widgets.TabItem;
import org.eclipse.swt.widgets.Table;
import org.eclipse.swt.widgets.TableColumn;
import org.eclipse.swt.widgets.Shell;
import org.eclipse.swt.SWT;
import org.eclipse.swt.graphics.Font;
import org.eclipse.swt.widgets.TableItem;
public class JavaTest {
private Shell scrSgridframe = null;
private TabFolder tabFolderscrSgridframe = null;
private TabItem tabItemVisiblescrSgridframe = null;
private Composite CSvisiblescrSgridframe = null;
private TabItem tabItemHiddenscrSgridframe = null;
private Composite CShiddenscrSgridframe = null;
TableItem tabitem;
private TableColumn F1 = null;
private TableColumn F2 = null;
private TableColumn gridList = null;
private TableColumn F4 = null;
private TableColumn F5 = null;
private Composite B1cs = null;
private Table B1 = null;
private void createscrSgridframe() {
scrSgridframe = new Shell (); // @jve:decl-index=0:visual-constraint="10,10"
scrSgridframe.setSize(new org.eclipse.swt.graphics.Point((int) (6*137.00) + 10, (int) (14*37.64) + 35));
createtabFolderscrSgridframe();
private void createtabFolderscrSgridframe() {
tabFolderscrSgridframe = new TabFolder(scrSgridframe,SWT.BOTTOM);
tabFolderscrSgridframe.setBounds(new org.eclipse.swt.graphics.Rectangle(0,0,(int) (6*137.00) + 10, (int) (14*37.64) + 35 ));
TabItem tabItemVisiblescrSgridframe = new TabItem (tabFolderscrSgridframe,SWT.NONE);
TabItem tabItemHiddenscrSgridframe = new TabItem (tabFolderscrSgridframe,SWT.NONE);
createCSvisiblescrSgridframe();
createCShiddenscrSgridframe();
tabItemVisiblescrSgridframe.setText("workplace");
tabItemHiddenscrSgridframe.setText("hidden-always");
tabItemVisiblescrSgridframe.setControl(CSvisiblescrSgridfram e);
tabItemHiddenscrSgridframe.setControl(CShiddenscrSgridframe) ;
private void createCShiddenscrSgridframe() {
CShiddenscrSgridframe = new Composite(tabFolderscrSgridframe,SWT.NONE);
CShiddenscrSgridframe.setBounds(tabFolderscrSgridframe.getBo unds().x,tabFolderscrSgridframe.getBounds().y,tabFolderscrSg ridframe.getBounds().width,tabFolderscrSgridframe.getBounds( ).height);
private void createCSvisiblescrSgridframe() {
CSvisiblescrSgridframe = new Composite(tabFolderscrSgridframe,SWT.NONE);
CSvisiblescrSgridframe.setBounds(tabFolderscrSgridframe.getB ounds().x,tabFolderscrSgridframe.getBounds().y,tabFolderscrS gridframe.getBounds().width,tabFolderscrSgridframe.getBounds ().height);
// END of TabDecks
// END of TabCards
String[][] gridContentB1 = new String[5][16];
B1cs = new Composite (CSvisiblescrSgridframe,SWT.NONE);
B1cs.setBounds(new org.eclipse.swt.graphics.Rectangle(18, 18,(int) (6*117.00), (int) (14*23.71)));
B1 = new Table (B1cs,SWT.SINGLE | SWT.BORDER | SWT.H_SCROLL | SWT.V_SCROLL | SWT.FULL_SELECTION | SWT.HIDE_SELECTION);
B1.setBounds(new org.eclipse.swt.graphics.Rectangle(0, 0,(int) (6*117.00), (int) (14*23.71)));
B1.setLinesVisible(true);
B1.setHeaderVisible(true);
// END of GridFrames
F1 = new TableColumn (B1,SWT.LEFT);
F1.setText("1");
F1.setWidth((int)((6*9.17) -(0.0)));
F2 = new TableColumn (B1,SWT.LEFT);
F2.setText("2");
gridContentB1[1][1-1] = "output";
gridContentB1[1][2-1] = "output";
gridContentB1[1][4-1] = "output";
F2.setWidth((int)((6*19.83) -(55.019999999999996)));
gridList = new TableColumn (B1,SWT.LEFT);
gridList.setText("3");
gridContentB1[2][1-1] = "listbox";
gridContentB1[2][7-1] = "listbox";
gridContentB1[2][8-1] = "listbox";
gridContentB1[2][9-1] = "listbox";
gridContentB1[2][10-1] = "f";
gridContentB1[2][11-1] = "g";
gridContentB1[2][12-1] = "h";
gridContentB1[2][13-1] = "j";
gridList.setWidth((int)((6*41.83) -(174.0)));
F4 = new TableColumn (B1,SWT.LEFT);
F4.setText("4");
F4.setWidth((int)((6*63.83) -(424.98)));
F5 = new TableColumn (B1,SWT.LEFT);
F5.setText("5");
gridContentB1[4][1-1] = "output";
gridContentB1[4][2-1] = "output";
F5.setWidth((int)((6*75.83) -(807.96)));
tabitem = new TableItem(B1,SWT.NULL,0);
tabitem.setText(new String[]{gridContentB1[0][0],gridContentB1[1][0],gridContent B1[2][0],gridContentB1[3][0],gridContentB1[4][0]});
tabitem = new TableItem(B1,SWT.NULL,1);
tabitem.setText(new String[]{gridContentB1[0][1],gridContentB1[1][1],gridContent B1[2][1],gridContentB1[3][1],gridContentB1[4][1]});
tabitem = new TableItem(B1,SWT.NULL,2);
tabitem.setText(new String[]{gridContentB1[0][2],gridContentB1[1][2],gridContent B1[2][2],gridContentB1[3][2],gridContentB1[4][2]});
tabitem = new TableItem(B1,SWT.NULL,3);
tabitem.setText(new String[]{gridContentB1[0][3],gridContentB1[1][3],gridContent B1[2][3],gridContentB1[3][3],gridContentB1[4][3]});
tabitem = new TableItem(B1,SWT.NULL,4);
tabitem.setText(new String[]{gridContentB1[0][4],gridContentB1[1][4],gridContent B1[2][4],gridContentB1[3][4],gridContentB1[4][4]});
tabitem = new TableItem(B1,SWT.NULL,5);
tabitem.setText(new String[]{gridContentB1[0][5],gridContentB1[1][5],gridContent B1[2][5],gridContentB1[3][5],gridContentB1[4][5]});
tabitem = new TableItem(B1,SWT.NULL,6);
tabitem.setText(new String[]{gridContentB1[0][6],gridContentB1[1][6],gridContent B1[2][6],gridContentB1[3][6],gridContentB1[4][6]});
tabitem = new TableItem(B1,SWT.NULL,7);
tabitem.setText(new String[]{gridContentB1[0][7],gridContentB1[1][7],gridContent B1[2][7],gridContentB1[3][7],gridContentB1[4][7]});
tabitem = new TableItem(B1,SWT.NULL,8);
tabitem.setText(new String[]{gridContentB1[0][8],gridContentB1[1][8],gridContent B1[2][8],gridContentB1[3][8],gridContentB1[4][8]});
tabitem = new TableItem(B1,SWT.NULL,9);
tabitem.setText(new String[]{gridContentB1[0][9],gridContentB1[1][9],gridContent B1[2][9],gridContentB1[3][9],gridContentB1[4][9]});
tabitem = new TableItem(B1,SWT.NULL,10);
tabitem.setText(new String[]{gridContentB1[0][10],gridContentB1[1][10],gridConte ntB1[2][10],gridContentB1[3][10],gridContentB1[4][10]});
tabitem = new TableItem(B1,SWT.NULL,11);
tabitem.setText(new String[]{gridContentB1[0][11],gridContentB1[1][11],gridConte ntB1[2][11],gridContentB1[3][11],gridContentB1[4][11]});
tabitem = new TableItem(B1,SWT.NULL,12);
tabitem.setText(new String[]{gridContentB1[0][12],gridContentB1[1][12],gridConte ntB1[2][12],gridContentB1[3][12],gridContentB1[4][12]});
tabitem = new TableItem(B1,SWT.NULL,13);
tabitem.setText(new String[]{gridContentB1[0][13],gridContentB1[1][13],gridConte ntB1[2][13],gridContentB1[3][13],gridContentB1[4][13]});
tabitem = new TableItem(B1,SWT.NULL,14);
tabitem.setText(new String[]{gridContentB1[0][14],gridContentB1[1][14],gridConte ntB1[2][14],gridContentB1[3][14],gridContentB1[4][14]});
tabitem = new TableItem(B1,SWT.NULL,15);
tabitem.setText(new String[]{gridContentB1[0][15],gridContentB1[1][15],gridConte ntB1[2][15],gridContentB1[3][15],gridContentB1[4][15]});
org.eclipse.swt.widgets.Display display = org.eclipse.swt.widgets.Display.getDefault();
JavaTest test = new JavaTest();
test.createscrSgridframe();
test.scrSgridframe.open();
while (!test.scrSgridframe.isDisposed()) {
if (!display.readAndDispatch ()) display.sleep();
display.dispose ();
--------------000902030506060000010700--
Re: VE crashes when loading Table [message #91763 is a reply to message #91747] Thu, 19 May 2005 09:47 Go to previous messageGo to next message
Originally posted by: richkulp.us.NO_SPAM.ibm.com
Could you please attach the .log file so we know what the errors were?
Rich Kulp
Re: VE crashes when loading Table [message #91799 is a reply to message #91763] Thu, 19 May 2005 10:39 Go to previous messageGo to next message
--------------040406050001030403060708
hello,
i'm sorry, but i cannot find any log-file....
But I tested a lot and maybe I have found the problem: I have attached a
new file of the Table.
VE _can_ now display the shell, but only when leaving out the tabitem /
TableItem part (at the end of the file). Then VE shows the screen correctly.
But when I use:
tabitem.setText(..................................
Then VE doesn't show anything! He also doesn't hang up like before, but
the ve-display only shows a blank shell and an icon called 'tabitem'
[see code -> tableitem] (see attached ve.jpg)!
I think VE has a problem with TableItems. I also notice that the
tableitem does not exist in the swt palette?!
Is this maybe the reason for my problem? - HOW can I fix it??
thx
flik
TableItem tabitem;
// END of TabDecks
// END of TabCards
F1.setText("1");
F2.setText("2");
F4.setText("4");
F5.setText("5");
// END of GridFrameColumns
display.dispose ();
Content-Type: image/jpeg;
name="ve.JPG"
filename="ve.JPG"
/9j/4AAQSkZJRgABAQEAYABgAAD/2wBDAAgGBgcGBQgHBwcJCQgKDBQNDAsL DBkSEw8UHRof
Hh0aHBwgJC4nICIsIxwcKDcpLDAxNDQ0Hyc5PTgyPC4zNDL/2wBDAQkJCQwL DBgNDRgyIRwh
MjIyMjIyMjIyMjIyMjIyMjIyMjIyMjIyMjIyMjIyMjIyMjIyMjIyMjIyMjIy MjIyMjL/wAAR
CAQABQADASIAAhEBAxEB/8QAHwAAAQUBAQEBAQEAAAAAAAAAAAECAwQFBgcI CQoL/8QAtRAA
AgEDAwIEAwUFBAQAAAF9AQIDAAQRBRIhMUEGE1FhByJxFDKBkaEII0KxwRVS 0fAkM2JyggkK
FhcYGRolJicoKSo0NTY3ODk6Q0RFRkdISUpTVFVWV1hZWmNkZWZnaGlqc3R1 dnd4eXqDhIWG
h4iJipKTlJWWl5iZmqKjpKWmp6ipqrKztLW2t7i5usLDxMXGx8jJytLT1NXW 19jZ2uHi4+Tl
5ufo6erx8vP09fb3+Pn6/8QAHwEAAwEBAQEBAQEBAQAAAAAAAAECAwQFBgcI CQoL/8QAtREA
AgECBAQDBAcFBAQAAQJ3AAECAxEEBSExBhJBUQdhcRMiMoEIFEKRobHBCSMz UvAVYnLRChYk
NOEl8RcYGRomJygpKjU2Nzg5OkNERUZHSElKU1RVVldYWVpjZGVmZ2hpanN0 dXZ3eHl6goOE
hYaHiImKkpOUlZaXmJmaoqOkpaanqKmqsrO0tba3uLm6wsPExcbHyMnK0tPU 1dbX2Nna4uPk
5ebn6Onq8vP09fb3+Pn6/9oADAMBAAIRAxEAPwDhrPUZ3eKKKCaed13BIk3n HrgVdn8QXWnO
UuLeeN14KsoyKueDrmPTop7uG5eHUFtXSLZ97ZxvK/KSWAyeM9M4GM0X39ky W7GST5COzn/4
ivr6+MqwnKPMtH5f5HnwwGGlFNw382EeuXEsKSByAwyBgUHWrrP+sP5Cs+JE 8hPKyY8fKT6d
uw/lXdnSW1fw14OgbH2aC11K5uWa4EKpGsqfMWKtgAkfwn+o9CVeNKlTnNfF /k3+h431ZTrT
hDpf87HJf21df89D+VH9tXX/AD0P5V1sngnSJ9Sl0/T7m8muJ9Hj1KwBZQJC xb5DlVJztGOF
75xUg8EaMuuTWsk9wthHdQ6f9pe6VWkumXLLGgibdjcvB24w2TgcZ/2hhrfj t/X9XK+o1f6Z
x39tXX/PQ/lR/bV1/wA9D+VMvtOFvrt3p0MgYQ3clsryMEB2uUyScAdOp4qt NB5MzxebBKUI
BaCZJU6Z4ZCQevY13RcJWtbXX5HNKm43v0Ln9tXX/PQ/lR/bV1/z0P5V0+k6 XPrHgHTdNt0M
j3HiTBQSBMqLVi3zEHGACc4PToelWI/B3h2e/wBDiiv7lodXiuVieKYOizRF QMOY13ISSPuj
PGOOa4njqMJOM1qm/PZX/wA/uOlYKcoqUepyH9tXX/PQ/lR/bV1/z0P5V1E3 gzT7CRVvmnjW
zsY7jVZZLpY0gkkbCRrtjcs3DcYOSVweedPw3aS+Hvi6vh601C8awhkctEZS Ectbb8sowrEZ
XnHYUpY+i4ydNXaTfbReev8ATBYKaa59E2l95wn9tXX/AD0P5Uf21df89D+V b3h7R7XXfD8W
veJ9avZPMuY7FZbjUETyhs3li0x5A3H5V568HtIPCujy+GLy+sby41O6tWnE htJotkYRyquV
PJRlBbIJ/GqWNop8slrdLbv5g8FO11sc7/bV1/z0P5Uf21df89D+VbHja30+ 3uNDj0+yNssm
jwXEh3qdxctjOFGW4OW78cDHLtCsJL3wTr8dq9yLk3FlF5KOgSfzJgqA7lyM Ek5DDORnpzp9
Yh7FVuWyvbX1sR9WftPZ31/4FzF/tq6/56H8qP7auv8Anofyrrbnwh4ftFsZ Zru4CNq39l3a
wXAlET7C3DmJBkEDdwQORnIpbvwDbafPb2kxma5/0m5uTJdJDFDaREqrs2xi CxKnoeM8Dtl/
aGG/pf1/TRf1Gqcj/bV1/wA9D+VH9tXX/PQ/lV7xXotjo2o2cWnTyzW91YxX iNJycOWA52r/
AHe4B9qx57NrdYS81sxlXeEiuY5HUYB+ZVYlOo4YD9K6qc6dSKnHrsYToyhJ xfQtf21df89D
+VH9tXX/AD0P5V0etXclv8OPC9vFqGo27TpeqYLVisc6+coPmEOvADHA2tnc elUPEuk6NoV5
d6RGdQl1K1EIacsnkuzKHb5cbgAGGOTzn0ycKWJjOXK463aXydm9vTuazw3L HmT6J/eZf9tX
X/PQ/lR/bV1/z0P5V3njKMNL4/lSa5jaC401WjRk8uVWWIKCChYbSWPDDOR6 c0dU8G6Ba3Ws
QR3V9brpF5ZxXE08iOrxT7PmGFG0rv8Afp78Y0sxoyinKNr2891H/wCSSNJ4 CcW1F3/p/wCR
yP8AbV1/z0P5Uf21df8APQ/lXZS+BNLGrlUe+XTYrKe889riArcrGRjy5OFX IYElwAPXHNcl
4hsNLsdSji0nUI7yCS3SZgk8cxhZsgxs8Z2kgr29R9a3o4uhWmoQ3avsZVMJ UpxcpbIi/tq6
/wCeh/Kj+2rr/nofyr0jxdqQtNS8YW+qajaz200Eaafp7TrJKkxijw6oCTGo bJOQM9frk6vo
8OoXGl3V+3l6ZY+G7F55ftHlbGd5AMfu3LE4IAC8nHI78tLMYSipShZP59L9 lr09TeeAabUZ
Xt/mcb/bV1/z0P5Uf21df89D+VdfqWg6ToWkeN7RbaS6n0+SzSGeR1DL5pUj B2HGC3zY+8OB
t61a1exsdQbTLFmvbbR9O8NjWJbeGZT5h+boNoHmHnLnrngLyTbzClo1HTv/ ANup/qSsBLq9
f+DY4b+2rr/nofyo/tq6/wCeh/KunHhLRo9RuWmnvjYJoH9tIiMgmUf3CcYP Ruw7VPpHhDw/
qQ0ONpNUjm1k3ZgIkjKxLCxxu+XkldvTvmtJY/DxV7fh5N/oyFgqjdv19P8A NHI/21df89D+
VH9tXX/PQ/lV3XNL0y30XQtV0trsRapHM/lXTKzJ5bKvVQBzurC2V1UpQqx5 orv+GhhUpOnL
lkaH9tXX/PQ/lR/bV1/z0P5Vn7KNla8i7EWRof21df8APQ/lR/bV1/z0P5Vn 7KNlHIuwWRof
21df89D+VH9tXX/PQ/lWfso2Uci7BZGh/bV1/wA9D+VH9tXX/PQ/lWfso2Uc i7BZGh/bV1/z
0P5Uf21df89D+VZ+yjZRyLsFkaH9tXX/AD0P5Uf21df89D+VZ+yjZRyLsFka H9tXX/PQ/lR/
bV1/z0P5Vn7KNlHIuwWRof21df8APQ/lR/bV1/z0P5Vn7KNlHIuwWRof21df 89D+VH9tXX/P
Q/lWfso2Uci7BZGh/bV1/wA9D+VH9tXX/PQ/lWfso2Uci7BZGh/bV1/z0NH9 tXX/AD0NZ+w+
lG0+lHs12CyND+2rr/noaP7auv8Anoaz9p9KNp9KPZrsFkaH9tXX/PQ0f21d f89DWftPpRtP
pR7NdgsjQ/tq6/56Gj+2rr/noaz9p9KNp9KPZrsFkaH9tXX/AD0NH9tXX/PQ 1n7T6UbT6Uez
XYLI0P7auv8AnoaP7auv+ehrP2n0o2n0o9muwWRof21df89DR/bV1/z0NZ+0 +lG0+lHs12Cy
ND+2rr/noaP7auv+ehrP2n0o2n0o9muwWRof21df89DR/bV1/wA9DWftPpRt PpR7NdgsjQ/t
q6/56Gj+2rr/AJ6Gs/afSjafSj2a7BZGh/bV1/z0NH9tXX/PQ1n7T6UbT6Ue zXYLI0P7auv+
eho/tq6/56Gs/afSjafSj2a7BZGh/bV1/wA9DR/bV1/z0NZ+0+lG0+lHs12C yND+2rr/AJ6G
j+2rr/noaz9p9KNp9KPZrsFkaH9tXX/PQ0f21df89DWftPpRtPpR7NdgsjQ/ tq6/56Gj+2rr
/noaz9p9KNp9KPZrsFkaH9tXX/PQ0f21df8APQ1n7T6UbT6UezXYLI0P7auv +eho/tq6/wCe
hrP2n0o2n0o9muwWRof21df89DR/bV1/z0NZ+0+lG0+lHs12CyND+2rr/noa P7auv+ehrP2n
0o2n0o9muwWRof21df8APQ0f21df89DWftPpRtPpR7NdgsjQ/tq6/wCeho/t q6/56Gs/afSj
afSj2a7BZGh/bV1/z0NH9tXX/PQ1n7T6UbT6UezXYLI0P7auv+eho/tq6/56 Gs/afSjafSj2
a7BZGh/bV1/z0NH9tXX/AD0NZ+0+lG0+lHs12CyND+2rr/noaT+2rr/nqf0q htPpRtPpR7Nd
gsi//bV1/wA9T+lH9tXX/PU/pVDafSjafSj2a7BZF/8Atq6/56n9KP7auv8A nqf0qhtPpRtP
pR7Ndgsi/wD21df89T+lH9tXX/PU/pVDafSjafSj2a7BZF/+2rr/AJ6n9KP7 auv+ep/SqG0+
lG0+lHs12CyL/wDbV1/z1P6Uf21df89T+lUNp9KNp9KPZrsFkX/7auv+ep/S j+2rr/nqf0qh
tPpRtPpR7Ndgsi//AG1df89T+lH9tXX/AD1P6VQ2n0o2n0o9muwWRf8A7auv +ep/Sj+2rr/n
qf0qhtPpRtPpR7Ndgsi//bV1/wA9T+lH9tXX/PU/pVDafSjafSj2a7BZF/8A tq6/56n9KP7a
uv8Anqf0qhtPpRtPpR7Ndgsi/wD21df89T+lH9tXX/PU/pVDafSjafSj2a7B ZF/+2rr/AJ6n
9KP7auv+ep/SqG0+lG0+lHs12CyL/wDbV1/z1P6Uf21df89T+lUNp9KNp9KP ZrsFkX/7auv+
ep/Sj+2rr/nqf0qhtPpRtPpR7Ndgsi//AG1df89T+lH9tXX/AD1P6VQ2n0o2 n0o9muwWRf8A
7auv+ep/Sj+2rr/nqf0qhtPpRtPpR7Ndgsi//bV1/wA9T+lH9tXX/PU/pVDa fSjafSj2a7BZ
F/8Atq6/56n9KP7auv8Anqf0qhtPpRtPpR7Ndgsi/wD21df89T+lH9tXX/PU /pVDafSjafSj
2a7BZF/+2rr/AJ6n9KP7auv+ep/SqG0+lG0+lHs12CyL/wDbV1/z1P6Uf21d f89T+lUNp9KN
p9KPZrsFkX/7auv+ep/Sj+2rr/nqf0qhtPpRtPpR7Ndgsi//AG1df89T+ldf 4ZWK60k313tn
d5pIkSUsEUIqEn5SCSfMHfjHvxwO0+ldfo0ph8L2g6br25/9At65cXB8iUdL v9GdGGUefXU1
5r21iJ/4l1h/31P/APHaqxX8F7qNrp4sLWIXUyQCaB5t8ZdgoYbnYHBPQjke nWmX2h6usbyv
pl6kaAszNAwCgdSTjiszRDt8UaMCeuoW/wD6MWuRQi6UpRldpdzqfKpqLitf I39FjgOhW13c
JHcTXEbS/vi4CgSOgACMv9wnJ9fbm4ltczRCW28OxzRtna8cV0ynnHUSVQ0A JKnhizlGY5og
rrnGQbqYEVrtrkFzpF7b6bDdaS0EayJMupTMiZlRT8g7fOTwD9M1z1XUVRqN 3r30Su13X4I0
pwp8ibS2/S5z1xdiee4sjYQ2k0cM8gkiMoZGijZyrK7sMHYRjAIP0wdvTdNt /wCzbT/RlvLq
aGKU+YZMkuivgBGXgBsdzxXOXFzFd+LdVnhffFNHqMkbYIypgmIODz0rdtLu 5t5dP+xs4uFs
7Py9gySTbx8Y756Y715me4ith6MOSTjdrrrs/mepkmEo4mtLminZPfbdDD9i aRYo9Ks3kchV
VWuCWJ6ADza5nxRBazaHqrR2MdlPZwiUmF5PnBkSMqwdm/56A5GOh6549au4 Dbi6v9PtLX/h
Jxbq80CPv8rOdzouMFyMZHuOufn8i1eV5/D/AIjeV2eRrAMzMclibqDJJrws HmGMjjKUJVZO
77u1v6+496tgMHPCVKkKUU4rsr3+XTs+pyVlDlY54p5LefYF82I4bbnOAewP fHXp0qafR1vC
xmvp23HJHAH6CvbrvwH4H0yya5vbOC1tYsbpZ7yREXJAGWL4HJAqlHoHw3mh Sa3ezuI3lWFT
b38kuXLogHyuf4pYwfTeucZr6SebZbOTk6ctf6/mPmPYY1aRqJL+vI840q5m 0WW3nsrho54P
uSADI4x346Grp8SawdQS9fUnadImhT92gRY25K+WFCEHvkc4Gegr1D/hXPhT /oFn/wACZf8A
4qj/AIVz4U/6BZ/8CZf/AIqtf7dy92vTbsrbLbtucv8AZuKu37Td367nmD+J 9Zl1K01CXUnk
urRNkEhijGwc9goB696jsPEOq6Ysos9QeMyzefIxRHzJk5fDKQGOTkgDrXoM 3hr4c2+pDTZp
LCO/LKgtX1JhKWbG0bDJnJyMDHORU9x4M8D2l5BaXFmkU06l4w9zMAwDonXd jO6WMAdSWGM0
f25l9uX2Tt6L179w/s7FXv7T8X6Hld3dy393Nd3cxmuJnLu5VVyT7KAP0psE xtriOeFyksTB
0YdVYHINeuwfD/wdc28dxb6eksMqh45I7uVldSMggh8EEd6k/wCFc+FP+gUf /AmX/wCKrVcR
4NR5VCVvRf5mbyiu3zOSv8zzC48Ua1dXtvdzapKZbaQyw7ESMK54LYVQGJHG WzwSO5pt14k1
a9+yC51AutpIZIFEMaCNsg8bVHTHTpXoVt4T+H17fzWFoLOe8g3ebbxag7SR 7Tg7lD5GCQDn
vV//AIVz4U/6BR/8CZf/AIqslneXK1qT08l/mavLsW73qfizy2LxFqsN9e3y ag4ur05nkMaM
HIxtO0rtyMDBxxilPiPVjrY1k6gx1FV2pP5UeVG3b024PBPUGvUf+Fc+FP8A oFH/AMCZf/iq
P+Fc+FP+gUf/AAJl/wDiqP7cy7/n09rbLbtuL+zcV/z8893ueVaPrup6BaG2 0y/eCM7TyiPy
BgMAykA+4FOfxDqz2D2J1F/s8iyJIPLj3Osh3OC+3cAx5IBAr1P/AIVz4U/6 BR/8CZf/AIqq
moeDfAmk263GpQ21lCzbFkub941LYJwCzgZwDx7UPPMvk7uk7+i/zBZbikrK p+Z5uniDU472
yu0vds1jB5Fu/kx5RMEYztywAJwGJAycdalttYt9P8K3WmWn2o317NbySzsV RIVhk3rsIJZm
JA7ADPtz6VB8P/B1zbx3Fvp6SwyqHjkju5WV1IyCCHwQR3qCPwX4Kl1KXT49 Nke4hXdJtkuC
idDtL52h8Mp2Z3YIOMHNKed4CS5eSSWmyXR3799Rxy7Exd+dP7+1vyPOtQ8T axqlo9peagZL
Z5fNaIQxqC3rkKD3znOT3pD4i1VtWOptfu12YRBvZEIMYGNhXGGHJOCDya9R /wCFc+FP+gUf
/AmX/wCKqOH4f+DrhC8OnpIgZkLJdykBlJVhw/UEEEdiCKazzLkrKk7ekeu/ UTy3FN3dT8We
V6lrF/rMkL6letctDH5cZaNFwM5/hUVS+SvZf+Fc+FP+gUf/AAJl/wDiqP8A hXPhT/oFH/wJ
l/8Aiq0hxFg6ceWEJJei/wAyJ5TXm+aU038zyeTV76TTodPN1H9lgR0iRrSB zGHOW2syFlJP
cHsPSpbzxDql/a/Zbm/aSAqiupjTc4T7oZ9u9se5r0z/AIQbwT9v+wfZIftn led9n+2yeZ5e
cb9u/O3PGemafB8P/B1zbx3Fvp6SwyqHjkju5WV1IyCCHwQR3qP7dwF7+ze9 9lv33L/s3FWt
zrt12PLr3XdS1CO9S4viy3zQm6xFGDL5RBTJC54wOepwBnFaXiHxhd6vr13c WU81rp5uoriG
ExxozOiIA7lcl8MpIDE8BeOBjv5vh/4Ot0DzaekaFlQM93KAWYhVHL9SSAB3 JAqT/hXPhT/o
FH/wJl/+KrN5zlzkpeyenkrdPPyRawGLUXH2i19f66nmH/CUayb+K8OpP50I kWMLFGiKJDlx
sVQpyeTkHJFU9Q1K71a6+06jdtczbQgZlVcKOgAUAAfhXq5+H/g5bhLdtPQT OrOsZu5dzKpA
Ygb8kAsuT23D1qT/AIVz4U/6BR/8CZf/AIqtIZ7l8HzRpNP0X+ZEssxUlaVS 6+Z5DfXs+p6j
c6hfXBnurhg0khVVzhQoGFAHAUCr8fifWIdnlagV2W62y/uY2xGpyoOVOdpJ IznGTjGTXp//
AArnwp/0Cj/4Ey//ABVULnwn8PrK/hsLsWcF5Pt8q3l1B1kk3HA2qXyckEDH em8+wEoqDpuy
20X+YllmJUnJT1fqee3fiPV75b4XOoGT7ciJOWgiO4J93gpgEHkHqDznpTIt f1SHUIb5L9xP
DarZxfIm1YVzhCNuGHzH72f0r1T/AIVz4U/6BR/8CZf/AIqj/hXPhT/oFH/w Jl/+KqVnmXJW
9k/uXp37aD/s7FP/AJefizyiXW9Tnlvp5dSlee+tjaTylEyYSACgG3aowP4Q O56nNOt9e1O0
m0+S2v2iOnJKloBGhEXm/fPKnJPvnHavTrjwL4MtZrWGbTisl1KYYR58x3OE ZyOG4+VGPPp9
Kn/4Vz4U/wCgUf8AwJl/+Ko/tzL7W9k7ei9O/ZtD/s7FXv7T8/66Hjz3M0tj p9lLcs9rp8bx
20ZVQEDkFjkDJJKjqfpUfyV7DP8AD/wdbW8lxcaekUMSl5JJLuVVRQMkkl8A Ad6g0/wb4E1a
3a402G2vYVbY0ltfvIobAOCVcjOCOPetY8RYOCtGEl8l/mZyymvJ3lNfieS/ JR8ley/8K58K
f9Ao/wDgTL/8VUcHw/8AB1zbx3Fvp6SwyqHjkju5WV1IyCCHwQR3qv8AWXC/ yy+5f5k/2NW/
mX4nj3yUfJXsMnw/8HRPEkmnojzNsjVruUF2wWwPn5OFY49AT2qT/hXPhT/o FH/wJl/+Ko/1
lwv8svuX+Yf2NW/mX4njXyUfJXrWoeDfAmk263GpQ21lCzbFkub941LYJwCz gZwDx7VPB8P/
AAdc28dxb6eksMqh45I7uVldSMggh8EEd6P9ZcL/ACy+5f5h/Y1b+ZfiePfJ R8ley/8ACufC
n/QKP/gTL/8AFUf8K58Kf9Ao/wDgTL/8VR/rLhf5Zfcv8w/sat/MvxPGvko+ SvYT8P8Awctw
lu2noJnVnWM3cu5lUgMQN+SAWXJ7bh61B/whvgTZbv5NtsuVDwN9vfEqkqoK /P8AMCZEAI7u
o7ij/WXC/wAsvuX+Yf2NW/mX4nkvyUfJXsv/AArnwp/0Cj/4Ey//ABVQW/gX wZdTXUMOnFpL
WUQzDz5htcorgctz8rqePX60f6y4X+WX3L/MP7GrfzL8TyH5KPkr2X/hXPhT /oFH/wACZf8A
4qj/AIVz4U/6BR/8CZf/AIqj/WXC/wAsvuX+Yf2NW/mX4njXyUfJXsM3w/8A B1ugebT0jQsq
Bnu5QCzEKo5fqSQAO5IFA+H/AIOa4e3XT0MyKrtGLuXcqsSFJG/IBKtg99p9 KP8AWXC/yy+5
f5h/Y1b+ZfiePfJR8levJ4F8GPfzWK6cTcwxJNInnzcI5cKc7scmN/y9xU// AArnwp/0Cj/4
Ey//ABVH+suF/ll9y/zD+xq38y/E8a+Sj5K9l/4Vz4U/6BR/8CZf/iqP+Fc+ FP8AoFH/AMCZ
f/iqP9ZcL/LL7l/mH9jVv5l+J4ziOjEdezf8K58Kf9As/wDgTL/8VR/wrnwp /wBAs/8AgTL/
APFUf6zYX+WX4f5h/Y1b+ZfieM4joxHXs3/CufCn/QLP/gTL/wDFUf8ACufC n/QLP/gTL/8A
FUf6zYX+WX4f5h/Y1b+ZfieM4joxHXs3/CufCn/QLP8A4Ey//FUf8K58Kf8A QLP/AIEy/wDx
VH+s2F/ll+H+Yf2NW/mX4njOI6MR17N/wrnwp/0Cz/4Ey/8AxVH/AArnwp/0 Cz/4Ey//ABVH
+s2F/ll+H+Yf2NW/mX4njOI6MR17N/wrnwp/0Cz/AOBMv/xVH/CufCn/AECz /wCBMv8A8VR/
rNhf5Zfh/mH9jVv5l+J4ziOjEdezf8K58Kf9As/+BMv/AMVR/wAK58Kf9As/ +BMv/wAVR/rN
hf5Zfh/mH9jVv5l+J4ziOjEdezf8K58Kf9As/wDgTL/8VR/wrnwp/wBAs/8A gTL/APFUf6zY
X+WX4f5h/Y1b+ZfieM4joxHXs3/CufCn/QLP/gTL/wDFUf8ACufCn/QLP/gT L/8AFUf6zYX+
WX4f5h/Y1b+ZfieM4joxHXs3/CufCn/QLP8A4Ey//FUf8K58Kf8AQLP/AIEy /wDxVH+s2F/l
l+H+Yf2NW/mX4njOI6MR17N/wrnwp/0Cz/4Ey/8AxVH/AArnwp/0Cz/4Ey// ABVH+s2F/ll+
H+Yf2NW/mX4njOI6MR17N/wrnwp/0Cz/AOBMv/xVH/CufCn/AECz/wCBMv8A 8VR/rNhf5Zfh
/mH9jVv5l+J4ziOjEdezf8K58Kf9As/+BMv/AMVR/wAK58Kf9As/+BMv/wAV R/rNhf5Zfh/m
H9jVv5l+J4ziOjEdezf8K58Kf9As/wDgTL/8VR/wrnwp/wBAs/8AgTL/APFU f6zYX+WX4f5h
/Y1b+ZfieM4joxHXs3/CufCn/QLP/gTL/wDFUf8ACufCn/QLP/gTL/8AFUf6 zYX+WX4f5h/Y
1b+ZfieM4joxHXs3/CufCn/QLP8A4Ey//FUf8K58Kf8AQLP/AIEy/wDxVH+s 2F/ll+H+Yf2N
W/mX4njOI6MR17N/wrnwp/0Cz/4Ey/8AxVH/AArnwp/0Cz/4Ey//ABVH+s2F /ll+H+Yf2NW/
mX4njOI6MR17N/wrnwp/0Cz/AOBMv/xVH/CufCn/AECz/wCBMv8A8VR/rNhf 5Zfh/mH9jVv5
l+J4ziOjEdezf8K58Kf9As/+BMv/AMVR/wAK58Kf9As/+BMv/wAVR/rNhf5Z fh/mH9jVv5l+
J4ziOjEdezf8K58Kf9As/wDgTL/8VR/wrnwp/wBAs/8AgTL/APFUf6zYX+WX 4f5h/Y1b+Zfi
eM4joxHXs3/CufCn/QLP/gTL/wDFUf8ACufCn/QLP/gTL/8AFUf6zYX+WX4f 5h/Y1b+ZfieM
4joxHXs3/CufCn/QLP8A4Ey//FUf8K58Kf8AQLP/AIEy/wDxVH+s2F/ll+H+ Yf2NW/mX4njO
I6MR17N/wrnwp/0Cz/4Ey/8AxVH/AArnwp/0Cz/4Ey//ABVH+s2F/ll+H+Yf 2NW/mX4njOI6
MR17N/wrnwp/0Cz/AOBMv/xVH/CufCn/AECz/wCBMv8A8VR/rNhf5Zfh/mH9 jVv5l+J4ziOj
Edezf8K58Kf9As/+BMv/AMVR/wAK58Kf9As/+BMv/wAVR/rNhf5Zfh/mH9jV v5l+J4ziOjEd
ezf8K58Kf9As/wDgTL/8VR/wrnwp/wBAs/8AgTL/APFUf6zYX+WX4f5h/Y1b +ZfieM4jpNqV
7P8A8K58Kf8AQLP/AIEy/wDxVJ/wrjwn/wBAr/yZl/8AiqP9ZsL/ACy/D/MP 7GrfzL8Txnal
G1K9m/4Vx4T/AOgV/wCTMv8A8VR/wrjwn/0Cv/JmX/4qj/WbC/yy+5f5h/Y1 b+ZfieM7Uo2p
Xs3/AArjwn/0Cv8AyZl/+Ko/4Vx4T/6BX/kzL/8AFUf6zYX+WX3L/MP7Grfz L8TxnalG1K9m
/wCFceE/+gV/5My//FUf8K48J/8AQK/8mZf/AIqj/WbC/wAsvuX+Yf2NW/mX 4njO1KNqV7N/
wrjwn/0Cv/JmX/4qj/hXHhP/AKBX/kzL/wDFUf6zYX+WX3L/ADD+xq38y/E8 Z2pRtSvZv+Fc
eE/+gV/5My//ABVH/CuPCf8A0Cv/ACZl/wDiqP8AWbC/yy+5f5h/Y1b+Zfie M7Uo2pXs3/Cu
PCf/AECv/JmX/wCKo/4Vx4T/AOgV/wCTMv8A8VR/rNhf5Zfcv8w/sat/MvxP GdqUbUr2b/hX
HhP/AKBX/kzL/wDFUf8ACuPCf/QK/wDJmX/4qj/WbC/yy+5f5h/Y1b+ZfieM 7Uo2pXs3/CuP
Cf8A0Cv/ACZl/wDiqP8AhXHhP/oFf+TMv/xVH+s2F/ll9y/zD+xq38y/E8Z2 pRtSvZv+FceE
/wDoFf8AkzL/APFUf8K48J/9Ar/yZl/+Ko/1mwv8svuX+Yf2NW/mX4njO1KN qV7N/wAK48J/
9Ar/AMmZf/iqP+FceE/+gV/5My//ABVH+s2F/ll9y/zD+xq38y/E8Z2pRtSv Zv8AhXHhP/oF
f+TMv/xVH/CuPCf/AECv/JmX/wCKo/1mwv8ALL7l/mH9jVv5l+J4ztSjalez f8K48J/9Ar/y
Zl/+Ko/4Vx4T/wCgV/5My/8AxVH+s2F/ll9y/wAw/sat/MvxPGdqUbUr2b/h XHhP/oFf+TMv
/wAVR/wrjwn/ANAr/wAmZf8A4qj/AFmwv8svuX+Yf2NW/mX4njO1KNqV7N/w rjwn/wBAr/yZ
l/8AiqP+FceE/wDoFf8AkzL/APFUf6zYX+WX3L/MP7GrfzL8TxnalG1K9m/4 Vx4T/wCgV/5M
y/8AxVH/AArjwn/0Cv8AyZl/+Ko/1mwv8svuX+Yf2NW/mX4njO1KNqV7N/wr jwn/ANAr/wAm
Zf8A4qj/AIVx4T/6BX/kzL/8VR/rNhf5Zfcv8w/sat/MvxPGdqUbUr2b/hXH hP8A6BX/AJMy
/wDxVH/CuPCf/QK/8mZf/iqP9ZsL/LL7l/mH9jVv5l+J4ztSjalezf8ACuPC f/QK/wDJmX/4
qj/hXHhP/oFf+TMv/wAVR/rNhf5Zfcv8w/sat/MvxPGdqUbUr2b/AIVx4T/6 BX/kzL/8VR/w
rjwn/wBAr/yZl/8AiqP9ZsL/ACy+5f5h/Y1b+ZfieM7Uo2pXs3/CuPCf/QK/ 8mZf/iqP+Fce
E/8AoFf+TMv/AMVR/rNhf5Zfcv8AMP7GrfzL8TxnalG1K9m/4Vx4T/6BX/kz L/8AFUf8K48J
/wDQK/8AJmX/AOKo/wBZsL/LL7l/mH9jVv5l+J4ztSjalezf8K48J/8AQK/8 mZf/AIqj/hXH
hP8A6BX/AJMy/wDxVH+s2F/ll9y/zD+xq38y/E8Z2pW3abrrRbe2tZbdbi3u ZZXSe4SHcrrG
AQzkA4MZyM55Hvj0v/hXHhP/AKBX/kzL/wDFUf8ACuPCf/QK/wDJmX/4qs6v EWFmvhl9y/zN
KeVVoO/Mvx/yOWufE3jC7tZbea/05opUKOv2+xGVIwRw1c/Y2dzZ65p+oXkt jHa2lzHcSFL+
CViEYNgKjliTjA4784HNek/8K48J/wDQK/8AJmX/AOKo/wCFceE/+gV/5My/ /FVywzjCQi4x
i0nvaKX/ALcdEsDWlJSbTa83/kedQvPcWmly6dcWyS2cJidZLuOB0bzZJAwL suRhxyOhB6cV
aubvxJd27QXGowyxN95JNbt2U855Blru/wDhXHhP/oFf+TMv/wAVR/wrjwn/ ANAr/wAmZf8A
4qqlneFcuaz+cV6/zCWArKPK2vvf+R5jbW02nXct7fTWSRLa3EarDewzO7SR PGoCxsx6vkk4
GAe+BWzZ6lcrcWepaVd2aNHbQxfvbyGJ0dIljYFZGGQdpOcEYP1rtf8AhW/h P/oFf+TMv/xV
H/Ct/CX/AECf/JiX/wCKrjzDHYHHwUavOmne6SX6+Z2ZfHEYGblTUWmrWd3v /wAMcTHdapBe
Lew3lgt0r7xL/a1qSW75zJznvnrmsLX53h0fXJr+6tZLi/txEiwXUc7M5mjk Zj5bEKMRnrjk
jHfHqX/CtvCX/QJ/8mJf/iqRvhn4QdSraRweo+0y/wDxVebhqGWUK0aydRuL vb3bX+89Svme
NrUpUpRglJWbV72L/i60uL3QUgtjMsrX9kQ8CBnjAuoiXAII+UAtyCOOeKwv EGm6vFqGkwLe
anqcHmpLK8kaYUre2JGREirwqysCRkDfzgHHe7F/56p+R/wo2L/z1T8j/hXG jmOC8ERa4l+X
1W9vZZTa/wCnRS2k8caXGV+68sjI2P3gHkKIyOTgeWK7qn7F/wCeqfkf8KNi /wDPVPyP+FDA
4myley8b6wZ7jWoo7i/jMVvFpzSWswNtCm9pRCcYYEH94oGznvnn4oNSbU9G uEi106skESar
JKtz5ayteWRlEZb92EIWbIi+Qqp/hAr1bYv/AD1T8j/hRsX/AJ6p+R/wpgcx 4Esxp3hKxsWj
vY7m2ijhukujKdsyxqHCGTgpkcbPk67a6Sn7F/56p+R/wo2L/wA9U/I/4UgP O1e+hsjY6E+t
SaPDFGsqXNk9vJawrNEPLgJjSR8wefyN7gomCGI3T6dd3unaqt7IutP4fH2i K2WSC5nm+ZbY
qXjIab76XWGccA4BCsue92L/AM9U/I/4UbF/56p+R/wpgeaaJbeID4Yubu9n 1o3I+wRtDI8g
ZYPItDdMi/fLnEwyMsGDbMOW3GrRanLc239kXutW1gLUfYPMtL2eZrjzJN+/ dImP+WWPtOYy
DxhQ+fS9i/8APVPyP+FGxf8Anqn5H/Ci4DK57xPbahc3fh86ayRzRaiztNLb tNHEv2adcsqs
pwSwXO4csOvQ9JsX/nqn5H/CjYv/AD1T8j/hSA80vrTWIdO0+1aW9soklu5N Ra3tbqYNdySL
KPL+zOkhiPmTFTuKgYVx5gAFqw0/U7Sw8Q39xFqEupzNBC7M8kYZTa2yyzCG J9pdSJD+6O4l
Civ0r0HYv/PVPyP+FGxf+eqfkf8ACncDzDTX1EjytXl12bRIp5kjktra+gmZ vLt2jyNzXBTL
XQyzFcjthALcdnLYQ3EMketJG2sXE2pi3Nyf9Hke4eEw7PVmhLeRzz8/8Vei bF/56p+R/wAK
Ni/89U/I/wCFFwOJ8MW2rTa5LPqE+prZwWqm0imd1R1M90EL5+ZnEPk5DHPI LguFI7On7F/5
6p+R/wAKNi/89U/I/wCFJgcTrFldw+Lb7XrW1meWwsLR08uMk3EYkufPhXH3 2KMrBMgeYIie
BXP2H9u2lv4XjSLULOa2g022+zra3UiyxERiZnKt5EZAaVSJELjy92RlCPVt i/8APVPyP+FG
xf8Anqn5H/CmBwTW3iBI1jee9ZdMurSyiaN5C13GbqFnmkP8eIBGrMMDcbkE bcVk293qENzb
wAa1Jqsujz/2pHO935Ym8y2WSWJchW2b5WAtyMjCqRuWvU9i/wDPVPyP+FVL TSNNsLi5uLO1
s7ea6bfcSQwhGmbJOXIGWOSeT6mgDzvQra+k12xudTbV57K0nuLe0nW3vIGJ kFo6B1dmlMe5
Z8mUsny4JA2gaXgiLXEvy+q3t7LKbX/TopbSeONLjK/deWRkbH7wDyFEZHJw PLFd7sX/AJ6p
+R/wo2L/AM9U/I/4UXAZXKXrvaeJW/sh9TF3cXULXVqbJjaSghEkkMzR4DLC vAWQDdGBgkkN
12xf+eqfkf8ACjYv/PVPyP8AhSA8w0dfEsFjeSXU+oXV09nsvoWtLqNYpmZA zozSneUBmYLa
hVbbgFSYqn8MQ61d67bw3d5q50y1a5aN2huLZZgBaMiuJi0hG9psbmJO1lB2 ZSvSNi/89U/I
/wCFGxf+eqfkf8KdwPN7bTX1SPQIb1NdOoJeI+rO8t3Escv2S4DGJ8hVTzDj MJCHKjoVFdf4
c+1jSDHeed5kV1cxRmfO8xJO6xEk8t+7CfMclupJzmtnYv8Az1T8j/hRsX/n qn5H/CkwMPxf
BLc+Ctet7eJ5ZpdOuEjjjUszsY2AAA5JJ7Vi3+g6s+r6dc3OpzNNd3SW95Jp kT2yC2jguWVW
+dyMvJgtuHVNu1gGrtti/wDPVPyP+FGxf+eqfkf8KAOGt4b+411YZjq4upLy 6S/O+dLcWREo
h8tsiIP/AMe3MREgO7PO+sLw6fEN5Lod3PqWoZeCxeELbTyrLAYYjKXk80QA ljPkyK0ndcny
xXqU9rBc28lvceTLDKpSSORSyupGCCCMEEdqk2L/AM9U/I/4UwPNBZm603SJ tRj8QNeWt1HN
rJU3gZZDbzIxg29V81wD9n+XBH8FekU/Yv8Az1T8j/hRsX/nqn5H/CkwOb8T 22oXN34fOmsk
c0Wos7TS27TRxL9mnXLKrKcEsFzuHLDr0OVp0t5oc2nyXsGoCGNb1b9La2lm Q3c00UwZEjDF
ozmbY+DtB2sQ+RXc7F/56p+R/wAKNi/89U/I/wCFAHmmgWmuLo8WpXTa1/ak d1pkQSaecqYm
itFnJiJ2H70+5ipIIY5BXI9Ip+xf+eqfkf8ACjYv/PVPyP8AhQ9QOY8XWmpG O11DRTs1KLzL
VZNm/ak67AduCNqzCCRjjhY268q2FFpGrWZKqkwj0u6tNPsPJDgrbNeRySYI ALp9n+zozHPM
Mue5b0TYv/PVPyP+FGxf+eqfkf8ACgDzS3tNcsdD0Xym1pmu9Mjl1bzZ55pF YS2vmBdxLRv5
b3OFj2sSOAWVcR2MCxahfPJF4jTw/NeSuGVb4XLy+RaLGTj9+U+W4GT8nAB6 JXp+xf8Anqn5
H/CjYv8Az1T8j/hTuB53a/8ACYWifab7zppbSKDUriJdzGZjBHFJAgT5Gb5L p9g48x4DnBYV
2eiW13ZaDp1pfz+feQWsUc828t5kiqAzbjyckE5PNaOxf+eqfkf8KNi/89U/ I/4UgOf8XWlx
e6CkFsZlla/siHgQM8YF1ES4BBHygFuQRxzxXKa3pWu2mtXZi1PU57aWKzFz evas7iNftZ2K
tqInbEhhJ2HcN+WymRXpexf+eqfkf8KNi/8APVPyP+FCA8llS9tNV0xtWn1p rW4+zwvNbw3M
M0yKuouibYmaU4HkkgsXxtMmDmvQfDf2v+w4vtnnbvNm8nz8+Z5Hmt5O7d82 7y9md3zZ+982
a1ZLWCV4nk8l3hbfGzKSUbBXI44OGYZ9CR3qTYv/AD1T8j/hQ9QGUU/Yv/PV PyP+FGxf+eqf
kf8AClYYyin7F/56p+R/wo2L/wA9U/I/4UWAZRT9i/8APVPyP+FGxf8Anqn5 H/CiwDKKfsX/
AJ6p+R/wo2L/AM9U/I/4UWAZRT9i/wDPVPyP+FGxf+eqfkf8KLAMop+xf+eq fkf8KNi/89U/
I/4UWAZRT9i/89U/I/4UbF/56p+R/wAKLAMop+xf+eqfkf8ACjYv/PVPyP8A hRYBlFP2L/z1
T8j/AIUbF/56p+R/wosAyin7F/56p+R/wo2L/wA9U/I/4UWAZRT9i/8APVPy P+FGxf8Anqn5
H/CiwDKKfsX/AJ6p+R/wo2L/AM9U/I/4UWAZRT9i/wDPVPyP+FGxf+eqfkf8 KLAMop+xf+eq
fkf8KNi/89U/I/4UWAZRT9i/89U/I/4UbF/56p+R/wAKLAMop+xf+eqfkf8A CjYv/PVPyP8A
hRYBlFP2L/z1T8j/AIUbF/56p+R/wosAyin7F/56p+R/wo2L/wA9U/I/4UWA ZRT9i/8APVPy
P+FGxf8Anqn5H/CiwDKKfsX/AJ6p+R/wo2L/AM9U/I/4UWAZRT9i/wDPVPyP +FGxf+eqfkf8
KLAMop+xf+eqfkf8KNi/89U/I/4UWAZRT9i/89U/I/4UbF/56p+R/wAKLAMo p+xf+eqfkf8A
CjYv/PVPyP8AhRYBlFP2L/z1T8j/AIUbF/56p+R/wosAyin7F/56p+R/wo2L /wA9U/I/4UWA
ZRT9i/8APVPyP+FGxf8Anqn5H/CiwDKKfsX/AJ6p+R/wo2L/AM9U/I/4UWAZ RT9i/wDPVPyP
+FGxf+eqfkf8KLAMop+xf+eqfkf8KNi/89U/I/4UWAZRT9i/89U/I/4UbF/5 6p+R/wAKLAMo
p+xf+eqfkf8ACjYv/PVPyP8AhRYBlFP2L/z1T8j/AIUbF/56p+R/wosAyin7 F/56p+R/wo2L
/wA9U/I/4UWAZRT9i/8APVPyP+FGxf8Anqn5H/CiwDKKfsX/AJ6p+R/wo2L/ AM9U/I/4UWAZ
RT9i/wDPVPyP+FGxf+eqfkf8KLAMop+xf+eqfkf8KNi/89U/I/4UWAZRT9i/ 89U/I/4UbF/5
6p+R/wAKLAMop+xf+eqfkf8ACjYv/PVPyP8AhRYBlFP2L/z1T8j/AIUbF/56 p+R/wosAyin7
F/56p+R/wo2L/wA9U/I/4UWAZRT9i/8APVPyP+FGxf8Anqn5H/CiwDKKfsX/ AJ6p+R/wp/2c
4yXQD/ayP5inYRDRU32f/prF/wB9UfZ/+msX/fVFmBDRU32f/prF/wB9UfZ/ +msX/fVFmBDR
U32f/prF/wB9UfZ/+msX/fVFmBDRU32f/prF/wB9UfZ/+msX/fVFmBDRU32f /prF/wB9UfZ/
+msX/fVFmBDRU32f/prF/wB9UfZ/+msX/fVFmBDRU32f/prF/wB9UfZ/+msX /fVFmBDRU32f
/prF/wB9UfZ/+msX/fVFmBDRU32f/prF/wB9UfZ/+msX/fVFmBDRU32f/prF /wB9UfZ/+msX
/fVFmBXdwk8UWMmRGfPpggf1p1RTf8f9r/1wk/8AQ1qhrWnRaqtlZzsyo9x1 UKTwjn+IEU4p
OSTFJtJtGmzKiM7sFVRkknAApI5FlQOhyD6jBB7gjsfaqEPhO2gsZLaGdwTy rPFGQGGcZXaA
w56H9Dg1JYxeVNeFpA7tNuYhAgGQGAwOpw3LHk9+2Iq3hVUFqn1HTfNDmejL tFYXifVta0e0
gn0bQP7ZZ5RHJEt0IXTcQFYZUgrk8nI29emSNmAytbxtcIkcxUGRI3LqrY5A YgEjPfAz6CmM
BKpOFWRuv3Y2PQ4PahplQEskqgAnmJhwO/So1uGt1SYKCqGVTlguMv7/AEpJ Ls3cUsoUBFhk
TIcNknHp9K1UETcs00uAxUK7EDJCoWx+Q9qdWJHf3hhE4lw1xFFIhhiICghi VJ2vkgnrgdR+
Kp03PYJSUTYjljmQPG4ZT3Bp9YdtPcQ7ZCUAzGkoeI5kLSFQQwCDgEfw+npk 7lKUJQ3BST2G
lwLlocfdjR8/72eP0p1RN/yE5v8ArhF/7NWH4wikOi3FwFufLggld3trt4nQ bc5CAhZBxyGI
wAcZJxU21sNuyubVve213FbywzKy3EXnRDoXTj5gDzj5l+mRU9eeZXTdHi1G xvp7d/sxVYAQ
626Btzxx7w2HG3Bz12ngYGztdJvRf2CSmdJpASHKwPBg9QDG5LLwQeeoIPQi h26EQqKReorn
tf1jxBp2pafb6V4cTU7e7by3uDe+SLduSS42NhMDO4Z5GMZKhuhpGhQvNa0+ wl8qef8Aed0j
RpGHpkKCR+NTWWoWmoxl7WdZAvDDoy/UHkfjXIfD64GrXerrqMIw0e6UyDGS Wyx9ug+mB6VB
pF7AvjkQadNJPakvH5rJt3LtZvxAZV546n15zUpXV9mckcQ3Z9Gd/RUc5lW3 ka3RJJgpMaSO
UVmxwCwBIGe+Dj0NY3hjVta1i0nn1nQP7GZJTHHE10JnfaSGY4UALkcHJ3de mCdDrNW7vrax
RWuJQm44VQCWY+wHJ/CmWWp2eobvs0wcr95SpVh+BANc/rMlxaeONHupXVNO ClWdjwrDcT+m
364rPsdTivPGv2qwtZYbDD8KjMzgDkhAMgbmTjtkZxkVDk0zn9rJ1ORK+u3X 1O7oqOCeK5t4
riBxJFKgdHXoykZBH4Vha/rHiDTtS0+30rw4mp2923lvcG98kW7cklxsbCYG dwzyMYyVDWdD
03OhpruEniixkyIz59MED+tOqKb/AI/7X/rhJ/6GtAEjuqIzuwVVGSxOABUc d1bywtNHPE8S
53OrggY5OTUN46rcWAcZU3HIPQ4R2H5EA/UCsa5uf7U8U3liLlfJFijAhFk2 yB2HzAj5gMn5
TxzkYPNZObvK3RXKsklfqdFHIsqB0OQfUYIPcEdj7U6s/S1Ie8MjK0xn/ebA AuSobAAAzjdj
cRk4yewFXxBKynT4hZPdLJcHKgrjIRsA5I69fwPTjLjUvDnHye9ymqbmECQ+ YpMTBHCnJViA
QuBzkhhgdTketSKyuiujBlYZBByCK4ezupIXvpRpj24troSCRhGUGFU4brjO PvAErnjuK67T
bY2ljHGxO8gM+VVcMeuFX5V+g/UkkqE5Sla2g501FblmSRIo2kkdURRksxwA PrVZNUsJULRX
kEqqcExyBsdeuPYE+wBPasjUSl/4xsNKukaS1EDXAjBwJHG7APrjHH1rD/ty V7b7UNF/s+NW
kgEhiDISVI27SCd3JORgHG08cipuSjeKucvtoqdpaI76io7eFbeBIVJKqMAn /OB9BgDoABWF
d6x4gh8WW2l2/hxJ9MmXzG1P7btWJRjcGTYTvyeFz82c5GG22rtGx0NNLgXL Q4+7Gj5/3s8f
pTqib/kJzf8AXCL/ANmoESEhVJJAA5JPaqVpq9hfTGG3uA74yBtI3D1GRyPp UOoeXdy3dncX
DQwLahiyttxv3gsTkdAvQ8cnIPGPOzoeoacirbxveB2bfm2mORgYyHUDHXjJ 5x6ZCjVo8suZ
2a2Xcc4zjHmSb9D1iiuf8HfbDoZa84zM4iXptUcYx2+YNx2/StTUL77HGAqF pHBIO0lUA6s2
OgGf/wBXULmVriheS1VmTT3MVsF8wtljhVRC7H8ACadDNHcRLLE25G6HGPau dt7w3d+1vLEt
xdE+bHIMhFCkcEZ6AkEdecHqAa6C1txa24iDFuWYse5JJP6k1EZzc3GStY1l FKKaZJK4igMm
M/OiY/3mxTqivP8Ajy/7bw/+hiotRguLiwlitZfKnbGyTcRsOR83HXHXaeGx g8E1sZFqiua8
P6ZI3h2BLu4AuEMbQhsyLBsK/KV4ww27Dg9ieCzZ2DNPBcW6TTwzLO5jASEx lTtZs5LHP3cY
9653iIc/KnfzNFBuNy7TPOj87yfMTzdu/ZuG7b0zj0pl3JLDbO8Kb3GOMFsD PJwOTgZOBycY
HWqdwdMhS2mOq/ZmKuVm82PM27aSSWBB+6vToMAcYFOrWUNAhDmNKiqFhcrP cTpDd/bLdFQr
PlT8xLblyoA4AU46/N7ioPEeo6lpOizX2laT/as8PzNarP5bsncp8rbmH93v zjJwDpCanHmR
MouLszWoqppk17c6bbzajZpZXbruktkm80RH+7vwATjGcDGc4JHJlMsQkcTX DREH5QNoyMDn
kHvn8qtK5JKrK2drA4ODg9DS1FvtxbqYJDJICdrZB35JJBx75+n51LQ1YAoq CKS5e7kja2VI
UGfOMn3s9ABjr/L8sz0hjQ4M88YH+qfZn1+UH+tJLNFBH5k0iRpkDc7ADJ+t NT/j9v8A/rv/
AOyLWJ4yjtf7AluLiVY3g+eHcMh3xwmO+ent1olpsaUYKpUjB9TdlmihCmWR IwzBQXYDJPQf
Wn15HaajHqV/ZWV/dstru8tmkfcIRj7oz0yQF3HpmvW1UIgVegGBzUQlzHTj cE8I1GT1YtQ/
aoDbfaFlV4ezxncDzjjHXnjioXdZ742s4xCq79h/5bjv/wABHGR1ORnA+9Bc iCyLSmaaUtI0
kFqduGlLFh2ycE55OBjJ6ZrGeJUZcpzRp3VzRjkSWNJI2DI4DKR3B6UiSpIz KpyV68Ef56Gm
2sP2a0hgH/LONU49hioVYB3iZzHKrEqVx8yk57jnHNdMU2tdzN76FpWV1DKw YHuDmlqFmSJI
xGDkAJg9XwMfnx/ntNTasIKKxJxCZryVokNwl/bokpUblU+TkA9QPmP5mjSh CG0tookR5bBn
lZVAMjfuuWPc8n8zXL9Y9/lt/V7G3svdubEj7AnGd0iJ/wB9MBn9aiEctxfS RLcSRKkSsAiq
cklh3B9BT5+kP/XeL/0YtLbf8hSf/rjH/wChP/n/AB6V1IxIxCpvGtBqkv2g RiXy9qZ2kkA/
d5GR2/qMzfYJf+f+f/vlP/ifp/nGYDbR3evXiuzIy2sDRyKfmRt83I6+p68E Eg5BOZbHU4bq
4msmnge8g4kWJwQRnG4DJI54IPIPBzkF6stguF5MljZyzybmSGHzGxjccLk+ gzUQuZisJ+w3
AMhww3R/u+erfN+PGafqjSJYXLwzRwSrbkpLKQEQ7OGYnsOpqaoadxplaC8E 13PbGCWJ4QrZ
fbh1YsARgn+6euDVmqkMhk1S7CrCY4440MikF9/zMUbnIwrIQCP4/em6nffY bdCoUyyv5cYY
4BbBP8gcdMnAyOomT5I3kG+xCmvWT6ibLc6vv8tXYAKzcjA5z1BGSMEggEni tOvPJ/s9/fi7
Cub2NzLCIVIUyr98GIkkOAu7aGwxTkZHPR+F9an1ZbyOZGb7LIEE5HDkjJGQ ACRweg4YZAOa
56Ndylyy67A1Y6CisLxPq2taPaQT6NoH9ss8ojkiW6ELpuICsMqQVyeTkbev TJGzAZWt42uE
SOYqDIkbl1VscgMQCRnvgZ9BXUAsT+bBFLjHmRq+PTIBx+tRm8gDld53A4IC k/0p1p/x4Wv/
AFwj/wDQBWdqTx21gki28PmSyyDzXRSchjhckYyRnr6fiKSWtxNmiLiM4+/g kDJjYDn8KlrJ
0u9t9QsZSLaFLiCSPLogXILYBx2PBBHt74rWokktgTMlPEmly/clmbPpay// ABNWodTtZ5Uj
QzBnOF3wOgJwT1IA6A1zlvZTSukNlpOmuiW0chZtPhkbmPIyftCtlmBAJQDP fALVesUP9pZk
023szHdBEVIIkdAYpG2sUlfJxtPIX1wc8dM6VJU+dP8AFHPCpUc+Vo6Giiiu Q6QooooAKKKK
ACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooA KKKKACiiigAo
oooAKKKKACiiigAooooAKKKKACiiigAooooAKUAkgAZJpKlGYk3EYdvu8dB6 0AJkR8ABm7k8
gfSmEkkknJNJRQAUjMqIzuwVVGSScACsrxJbw3eiSW9w+yGSaFXb5eB5qc/M CPzFZOn6Bplu
L2O0upZMOEjlisY5U+4Dzsjw3LHg+3Q4NWopwbT17f8ABIcmpJW0OqjkWVA6 HIPqMEHuCOx9
qgs7ae4soJ3vpg0iBiAqY5H+79f85xX0bMltLcyf62aaTeoXaAQ7DGMD06kb j37APmvo9N8J
C6kkkjCW6gPHt3BiAARuGM5I65H5cZ023G8i52jfsQRalpc919mi8RxvKQuA rxfNuJAAOME5
HQcjIzjNWJWhg1G3sJNUuFurhWaJPKX5gv3udmBj3x/PHn9gDcXCRw6vKhjN ruPnxbI4o3A3
Asg5XdkA+o+927N7PUL/AMZ2OotaLDZWUcqrN5ysJgwwCoHI/HHTrxxdFc93 LQmc4tJ03e5s
fYJf+f8An/75T/4n6/5zg+wS/wDP/P8A98p/8T9f85xzd3rV9oWua1C95JqA Fvaz2drcLtIe
SS4DRp5ELSMAkIONrsAhJIAJVYvHiyaeZzpzRzSQN9khkdkNxcpcG3eH5kBj AlMADOF4lBKr
sYLXKO50f2CX/n/n/wC+U/8Aifr/AJzhyWrQ72e5ll+XgMFAHI54APr/AJ6Y q+LR/wAJbHo5
tN9tNK0EN5EJmUyqjOysTEsQx5cinbIzBlwVGG2dHJ91v93+o/z/AJwE1YCh LOyTpDHbyTSO
rMAhUYAIB+8R/eFJb3SXJkUBkkjbbJG+Nyn8CR+IqvcgPqtvERkPbyjpn+OL tg/yqK0gu7iC
11SGSB5Z497Ry4QBGAIAKpnd93JOQcHAGRjCpNU7NvcuMea5qUVyHiq7uJm0 m18i+kf+1DBc
W+m3hheUfZZZAFk3x8D5GOSPu9+M0IvEGuR6Xo9ppdu93dXa3c4MqLNJBDHK qrFIrzRfvFEq
I5Llg0bAhiSw0i1JXRLVnZnfUVwt3401KygGpXlnDa2bWDXNtAq/aBeutsZ2 VLmN9keMMPmQ
7ghZS2cLfTXtWs/E1noV81lcyTSxl7iCB4R5bxXTBQhdvmDWw+bOCHxgYyXY R1dFcKnjLVt+
uXDW1k1npFrcXMijeskvlz3cSoOoGRboS3OCCNp3Apb1bVfE+m3FlptulrqF /crNcGW2sgqp
FGYl2mOS5XJJlzu8zjGNpzkFgOvoqppd42oaRZXrxpG9xAkrJHKsqqWUHAde GAz94cHrVukM
hfe99EfLYJHEylyRgksp45z2Pam3MEsr28kMqRyQS+YN6FgflZcEAj+961YJ AGTwKjSSWZd8
FpPLH2cbVB+m4jI9xxT1YiWee6eILE8KP3LxllP4bgf1qtbQzRvcS3Escks8 gcmOMoowqrgA
k/3fXvU2Lv8A6B8//fcf/wAVRi7/AOgfP/33H/8AFUuV7hcdRTcXf/QPn/77 j/8AiqMXf/QP
n/77j/8AiqdmBWMNwHUoUGyRnB3kHnPoPeo/s10TOzMjGVduS5OOvqPeruLv /oHz/wDfcf8A
8VRi7/6B8/8A33H/APFVfNIVkOrkjoXiCD91bajCYE+WPe207R0yNh/nXV4u /wDoHz/99x//
ABVGLv8A6B8//fcf/wAVTp1J09hSipbnNWmi6213C19fxG3SRZGVDuLFSCB9 wdwO9dPTcXf/
AED5/wDvuP8A+Koxd/8AQPn/AO+4/wD4qipOdR3YRio7Ea73vppTGyJ5aIpY j5iu7JGD05HW
lubaK7t2gnTfE+NyZIDDPQ+oPQjoRkHINPxd/wDQPn/77j/+KqrJqHlSCOW1 uI3JIAk2pk5x
wSwB/DPUVnZlGRF4Q09768uruEMs9x5q2ySMIVACgZUYDE7dxyMZYjnGT0dV /tMv/PlP/wB9
J/8AFUfaZf8Anyn/AO+k/wDiqG29xKKWyLFFV/tMv/PlP/30n/xVH2mX/nyn /wC+k/8AiqRR
h6h4SW4kunsb17Rbz/j4j2blfnPYgjJ5POKsaD4ZtdDLSrI01wy7C5G0Aeij t0HUnpWp9pl/
58p/++k/+Ko+0y/8+U//AH0n/wAVS5Ve5kqNNS5ktSxRVf7TL/z5T/8AfSf/ ABVH2mX/AJ8p
/wDvpP8A4qmaks0MVxEYpokkjbqjqCD+BridZ8Galc6vLcaZdWttbMBshwAF 4Gfl2MOSM/ie
mTnr5Lx4o2keznCqCxOU4A/4FTvtMv8Az5T/APfSf/FVMoqW5rRrSoy54b7G Z4W0e70TSWtb
ydZpDKXBUkgDAAGSBnp/+s81t1X+0y/8+U//AH0n/wAVR9pl/wCfKf8A76T/ AOKppWViak3U
k5S3ZYqF9730R8tgkcTKXJGCSynjnPY9qb9pl/58p/8AvpP/AIqpIZ0nUlCc jgqwIIPuDTII
7u0W7jRS7xsjb0dMZU4I7gjoSOR3rPh8Px27yvBe3EbStukKJCCx9T8nJqzq us2Gi23n39ws
S87QerHGcAdzXP8A/Cy/Df8Az3uP+/Bq44GpXTlCm5LyTf5EvERpu0pJetjp 7S0W0jdQ7yM7
b3d8ZY4A7ADoAOB2pmoaemoRRq00sLRP5iPEQGBwR3BHQntXN/8ACy/Df/Pe 4/78Gj/hZfhv
/nvcf9+DWyy7EpcqpSt/hf8AkR9bpXvzq/qi+vhZT9qSbVL2SKd8snyDI2gE E7eeh5GOMDtk
9BXIf8LL8N/897j/AL8Gj/hZfhv/AJ73H/fg0LL8StqUvuf+QSxdKW8196Nz WNEh1dImMjwX
MB3QzxnDIf6jgce1U7fw3K95Fc6rqk+omA7oo3BCq3qQSc1n/wDCy/Df/Pe4 /wC/Bo/4WX4b
/wCe9x/34NP6hiv+fUvuZk6mGb5nJfedfRXIf8LL8N/897j/AL8Gj/hZfhv/ AJ73H/fg0/qG
K/59S+5/5F/WaP8AOvvR19Qrve+mlMbInloiliPmK7skYPTkda5b/hZfhv8A 573H/fg0f8LL
8N/897j/AL8Gj6jiv+fUvuf+QfWaP86+9GzqGjy3WoLdwXaxnYqtHLEZEO0k qcBlOQWbqSOh
xkZoXTL52C3F/E0J++sMDRsR6Bt5x+WfTB5rKh+I3hyeZY1uZFLd3jKgfUmt y11WO9iWS2he
VGUMCjxng9D96uOtgOSXNVg033ujop4rmVoSTXyLqIkUaxxqqIoCqqjAAHQA VLbutu0jhMyP
j5iegA4H06/maqfaZf8Anyn/AO+k/wDiqPtMv/PlP/30n/xVDinuK5W07R4N OlmmXDyyuxDb
cBEJyEUdgOPrgegA0ar/AGmX/nyn/wC+k/8AiqPtMv8Az5T/APfSf/FU0raA 3cddb3hWJI2Y
tLGxYEYUKwJzk/yqaq/2mX/nyn/76T/4qj7TL/z5T/8AfSf/ABVAFXUNIjvW BDqivIjTxsm5
ZQrA8j1+UDPpwQcDFm306xtJDJbWdvC5G0tHEqkj0yBS/aZf+fKf/vpP/iqP tMv/AD5T/wDf
Sf8AxVQqcE3JLUpzk1a5YqpHp0MWoG8RnVijL5YI2AsQWYDGQSVHfHU4ySS/ 7TL/AM+U/wD3
0n/xVH2mX/nyn/76T/4qqcU9xJtbFiiq/wBpl/58p/8AvpP/AIqj7TL/AM+U /wD30n/xVMRY
oqv9pl/58p/++k/+Ko+0y/8APlP/AN9J/wDFUASRwpGzMMksScntk5wKkqv9 pl/58p/++k/+
Ko+0y/8APlP/AN9J/wDFUAWKKr/aZf8Anyn/AO+k/wDiqPtMv/PlP/30n/xV ADoN7TXUrxtG
JZdyqxGcbVHYn0NUtb0Kz161SC88wCNw6PE21lPQ8+4JH4+tW/tMv/PlP/30 n/xVH2mX/nyn
/wC+k/8AiqHqVCcqclKDs0ZWoeD9F1G2t7d7XyUt8BfIOwlO6E9wfz981uKq oioowqjAHoKg
+0y/8+U//fSf/FUfaZf+fKf/AL6T/wCKosOdWc0oybaX6jrm2S6i2MWVlO5H Xhkb1H+cEEg5
BIqDTdOSwhbPlPcSO7ySpHsLFmLepPGcdT0qX7TL/wA+U/8A30n/AMVR9pl/ 58p/++k/+Kqe
SPNzW1J5nbl6FimuiSDDqrDrgjNQ/aZf+fKf/vpP/iqPtMv/AD5T/wDfSf8A xVUIdb24gRRn
cQNoOMYHoBU1V/tMv/PlP/30n/xVH2mX/nyn/wC+k/8AiqAIZNMWS4eT7TOq PKkzwjbtZ124
OSu7+Beh7UWemLZvEwuZ5RDEYYlk24RDt4GFBP3V656VN9pl/wCfKf8A76T/ AOKo+0y/8+U/
/fSf/FVHs43vYrnlaxJMpYR4GcTRsfoHBP6CnW0b/wBoTPsYoYkUNtJGctkf r/npUP2mX/ny
n/76T/4qj7TL/wA+U/8A30n/AMVWiZAXuiJqF3LNNNcqjxIgSIshVlZmD5HO QW4HTIycnFLp
MV7GZ/tMBiVyrbAMjzMfOUxnCE4IzzkuSOcFPtMv/PlP/wB9J/8AFUfaZf8A nyn/AO+k/wDi
qdwsSanZpfWdxZTF1SeAxOV4YBlwcZ781WFlcBbcHVLsmJiXJWLMwznDfJwO 3y7Tj35qX7TL
/wA+U/8A30n/AMVR9pl/58p/++k/+Ko5mLlRQ0nw/BpF9e3MVxdSG5kDBZbm WQKNiLghmIY5
TO484OOgq9qFhDqVm9tPu2tyGU4ZGHRgfUf54pftMv8Az5T/APfSf/FUfaZf +fKf/vpP/iqm
XvfENK2xiaZ4U+xasuo3N79pljz5e2Ly/wCHaC3zHcQpIB44PsMdHVf7TL/z 5T/99J/8VR9p
l/58p/8AvpP/AIqphCMFaIyxRVf7TL/z5T/99J/8VR9pl/58p/8AvpP/AIqq Akt1KWlujDDJ
CisPQhQDSNG72z2ziCSBySVkiJ6nPr60z7TL/wA+U/8A30n/AMVR9pl/58p/ ++k/+KpptCsN
trJLO2NvbpDHEzq7bVYsSCD1LE9qtVX+0y/8+U//AH0n/wAVR9pl/wCfKf8A 76T/AOKobbAy
YvDNujb5LXSZ5TGkbST2BcsFGAeXxn1IAzx6CprPQYrO8FxDDYQZk8xxbWpj 3EIUA++QBznA
HXnvWh9pl/58p/8AvpP/AIqj7TL/AM+U/wD30n/xVF3awWLFFV/tMv8Az5T/ APfSf/FUfaZf
+fKf/vpP/iqQyxRVf7TL/wA+U/8A30n/AMVR9pl/58p/++k/+KoAsUVX+0y/ 8+U//fSf/FUf
aZf+fKf/AL6T/wCKoAsUVX+0y/8APlP/AN9J/wDFUfaZf+fKf/vpP/iqALFF V/tMv/PlP/30
n/xVH2mX/nyn/wC+k/8AiqALFFV/tMv/AD5T/wDfSf8AxVH2mX/nyn/76T/4 qgCxRVf7TL/z
5T/99J/8VR9pl/58p/8AvpP/AIqgCxRVf7TL/wA+U/8A30n/AMVR9pl/58p/ ++k/+KoAsUVX
+0y/8+U//fSf/FUfaZf+fKf/AL6T/wCKoAsUVX+0y/8APlP/AN9J/wDFUfaZ f+fKf/vpP/iq
ALFFV/tMv/PlP/30n/xVH2mX/nyn/wC+k/8AiqALFFV/tMv/AD5T/wDfSf8A xVH2mX/nxn/7
6T/4qgCxRVf7TL/z4z/99J/8VS/aZf8Anxn/AO+k/wDiqAJ6Kg+0y/8APjN/ 30n/AMVR9qk/
58Zv++k/+KoAnoqD7VJ/z4Tf99J/8VR9qk/58Jv++k/+KoAnoqD7VJ/z4Tf9 9J/8VR9qk/58
Jv8AvpP/AIugCeioPtUn/PhN/wB9J/8AF0v2qT/oHzf99J/8XQBNRUP2qT/o Hzf99J/8XR9r
k/6B83/fSf8AxdAE1FQ/a5P+gfL/AN9J/wDF0fa5P+gfL/30n/xdAE1FQ/a5 P+gfL/30v/xd
H2uT/oHS/wDfS/8AxdAE1FQ/a3/6B0v/AH0v/wAXR9rf/oHS/wDfS/8AxdAE 1FRfa3/6B0v/
AH0v/wAXR9rf/oHS/wDfS/8AxdAEtFRfbH/6B0v/AH0v/wAXR9tmH3bCVfp5 f9WpiLITy/mk
HPZe9MZizFj1NVjdOvL2lwq9zhWx+Ckn9KmR1kRXRgysMgjvSGOoqMSs8jJB DLMy/e2AYX2J
JAzyOM5p2Lv/AKB8/wD33H/8VTsxFfULWS8tPKilWKQSRyK7JvAKOrcjIyPl x1FRRJrUMs8i
3+nkzOJGzYvwdqrx+99FFXcXf/QPn/77j/8AiqMXf/QPn/77j/8Aiqa5lsGh BYW0lpamOWVZ
ZGlklZ0TYCXdnOBk4A3Y6mnDTY77w/HYXsEhjeFVddpBBGD+YIB/AfhLi7/6 B8//AH3H/wDF
UYu/+gfP/wB9x/8AxVCT7CaTVmcPrHgjULCNV0AXE3m5E0khQSgZBCjIUBeM nucD6V2Xh2wu
tL8P2dndkvPEh3lVOMkk4/DgfgPwmxd/9A+f/vuP/wCKoxd/9A+f/vuP/wCK rT2j5FBLRCjC
MVaJRXwlpCwPGYL13Z1f7S95cPcKVBC7Zi/mKAGcYVgMO/8AfarFp4e02xt7 KCC1l2WU8lzA
ZJJJGWVxIHcsxJYnzZPvE/e7cbY5NQ8qQRy2txG5JAEm1MnOOCWAP4Z6ipPt Mv8Az5T/APfS
f/FVnzFWI18MaXHq8eppb3K3EUrzxoLibyUkZWVnWHd5YYhmyQoJLE9Tkasg OxvlYDb3GO4/
z/nAzvtMv/PlP/30n/xVH2mX/nyn/wC+k/8AiqOYLDp7S2umRri3hlMZyhkQ Nt+menQVmw6Z
qdrBHb2+o2wgiUJGJLVmYKBgZIkAJx3wPoK0PtMv/PlP/wB9J/8AFUfaZf8A nyn/AO+k/wDi
qxqUoVPiRcZyjsQWmmrFmW6MdxcmbzxJ5WAj7PLygJJX5OOvduxxS3miaTqM bx32mWV1HJKJ
nWe3Rw0gXaHII5baAueuBipvtMv/AD5T/wDfSf8AxVH2mX/nyn/76T/4qrjF RVkJtt3YyPS9
Pi1KXUo7C1S/mXZJdLColdeOC+MkfKvGew9Kgj8O6JFpsumx6Pp6WEzb5LVb ZBE7cclMYJ+V
ecdh6Va+0y/8+U//AH0n/wAVR9pl/wCfKf8A76T/AOKpiGWOl6fpibLCwtbR NoTbBCsY2gsw
HA6Zdzj1Ynuaqf8ACL+H/sH2D+wtM+x+b532f7JH5fmYxv24xuxxnrir32mX /nyn/wC+k/8A
iqPtMv8Az5T/APfSf/FUAWKKrG72czW80Sd3YAgfXaTj69KsggjI5FAEMyLL NbQv/q5JcMPU
BS2PodoB9qsapfT2kth5Eckvm3BR4o9u518tzgbiAOQD1HSq8hxd2Z/6an/0 W9N1VbmWbTja
lVdLksXeMuqjypBkgEeuOo5IrSDJZlab4vvb3xR/ZksEUcRkdNp271x5vBxI ef3a/wAPfsNp
OxqHirStL1A2N3NOkqxLPIy2srxwxsWAeSRVKRrlH5YgAKSeBmsLTrbxDH4l 867eRrPzG3EO
QhH73BC+acDmPjb27YyztR8OT6v4o1KW4urqDSrrTbe1lihMW26Ae48yN9yl 1G2RRlSp+c4O
RxlRcrPm7mtZRuuXsdnvqnJqkMWsW2mMr+fcW8twjADaFjaNWB5znMq447H8 fNtY8O+Ib3xJ
c3djDPZ39x9qibUIPs0Nv5TW8qQZdf8ASWYN5BYNlQykqMKmLcnht729sn0z w5HollDb3Sz2
MqwRxXTM9sQkggZvkcRsCRn7mGVlOx9rmR6Vvo315NqOg+I9S1yW/tLO603U btLlJLtDaRRJ
G1tKkIaSMm4Z1YwbgSyh0JXIVCMyLTrPxLd6hN4c0X7Jo6/Y/tVtp4sXF0VF 3lQAz27sGkgY
q5yAoOM7MlwPYNT1a00ewa9vXdYFdE/dxPKxZ2CKAqAsSWYDAHejTtVg1S3a e3S6RFcoRc2k
tu2cA8LIqkjnrjHX0Ncbd6HeL8OrfS47W9nljureb7OLqNZxEt2kpRXTy0Rl jGAEIVMBVYgA
l89he3+mWkFjpWo6fcwPIFuNQ1HMoiO0vH5qSSORLnZ1+TbvGGjjDFwsd3vo 31z6Xd5a6fNH
Y6D5cdvYRvaW3nRx7pMP/o+FyqbdsY3ZK/PxwtX0uLg6hNC1tttkijaO48wH e5Lhk29RtCoc
99/saLhYde6hcW95bQQWqzecrsS0uw/Lg7VyMM5BYgEj7p5wCREdUknu7eAW JNpclkLTZSTA
UksYiudmcLkkcsOMEEw6i1w9xaolo1xbgmRgrqmJFZTHuJOQmck7QT8o4IyC wNfrqsEjwK7u
PLuLiLCxNGAzL8pYsrhjjjIIYknoFLhYsz2jWmZLbc0OctAB90eqf4fl6FEd ZEV0YMrDII71
c31RniaCRp4FLIxzJEP/AEJff1Hf69YaGMu7y3sIVmuZNkbSxwg4J+eRwiDj 1ZlH481GdStR
qR07e7XQVHZFiYhVfzNpLAYAPlOMk9QB1YZzvElk2u6Cltakyh7y0djFN5ZC JcRu5DAgghVY
8HPHHOK5bWfBmp/21M+ivdIkkCLHd3OoSStFL9nv49wZ2ZwA08P3f72QODSS QHotFeb6d4Kc
3Fkj6bexaaL9ZZ7a6e1iG0W9wpbyrUBCrGSNWyWLj5WXavNfxJ4Z13UNT1Ke 206b7VdRXkMk
0ItI4JoWtpUhQvxOzZ8jIclAwJHCqQWA9QqppeoRatpFlqVurrDdwJPGsgAY K6hgDgkZwfWu
fk0CGz8R2sh0L+0bFIoUtWPlyGymEkjSzMZWDbn3xsXXc7GMluQM4UPhRNF8 Nae0lvDpEdto
TSalcwRqfLvIjbyRSuqH98yNHKw6g/MP4uSwHoF//wAg66/65P8AyNM1Kee3 smkt1zJvQf6p
pNqlwGbavJwCTgelZmnWdxbeH725vo/L1C/D3V0mQfLdkAWPI4OxFSPcMbtm 7qTW9SGYVxqN
5HbSyQXXnSqhKRf2JcrvYDhcluMnjNaOqXE9rYmS2UNMZY41BXdnc6r03Lk8 +o+tXKq6hDNP
bKIAhlSaKUCRioOyRWxkA4zt9DTEZl7ceIbOxuLprQ7YYmkO62jA4GecXJOO OwP0Nak6hby2
kHDMxjb3G0t+hH6mo9RudXv9Mu7P7BYx/aIXi3/bHO3cpGceVz1qW5/19p/1 1P8A6A1OVugI
8c8czz3vim6SViUgby41ycAdfz/wrqpfBHhm30vS5pY75rjUdkcYjkG0SMm4 Zz0XioYrK1uv
iBqP2qIS/fKIyhlLYAOQQc4UsR7gVsC5F5a+Hftl1ZWS2pS7cOxTPy/KqK+D jJYc8gBepr2M
VjlH2GGhJxtC7s2tWk+no38zgoYZyVStJJ+9ZXV9meYa5oMmiatNYynLJgjn sRkZ/CoL7R7j
TniW4Ef71PMRopkkVlyVyGUkdVI/Cuq8WNBqXi24liuImhcxqJgdyAbVBOVz kD2zVqyvLWya
BIL5FuLa28gTlriOF1MskjY8vEmfmTGQBw3+ya+iwuLqvDQm/efXz8+x5Fal BVpRWiOB+z1L
b6e91OsMZjVmzgyyrGvTPLMQB+Jrs77ULIm+e2RRIkk0FkVUqBbysxOFxgAA uMHn9922Cnaz
dWVzoSW0U8cpimj+zKzTNLHEFcENv+RT9zIjwCR6AY6frM3b3Xr+H9f5mXso 6+9scfqGj3Gm
XTW10I1mX7yxzJJtOSCCVJAOQeDzUVtp8t5dQ20Cb5pnWONcgZYnAGTx1rvL bVbaHWNbuIJo
Ynursyw3EpnQeXuckZiw4zuQ4PHy88gU621izgWGZpvLijvBOtrYh4t4E28+ bGcxnCjC7WyM
KDkDKx9aqpW5NdPy/Qr2VO/xaHnn2eny2bRSvG20sjFSUYMMj0I4I9xxXSTQ zTXzTrqct5qI
miEMkYkZ5Tg/MGYBsqQoAxnnjpXR3N/p4k1mIXULQ3Et27xyPM2+Rt/ltGq/ uiv+rOW5BBPZ
a0nipRtaNyI0k73djzX7PR9nruDqNrLc20jFo3nl+13bqWH+kKCqEkchd25z swcSkDlRVXxJ
LBf3drLHJDLKLfbPJF5pDPvfHzS/Ox27Rk56YHAFOOIk5KLjYTpxSbUjPtvB OqX+l2d/p8aX
kdxIYikLZaFgf4x/CO+egGM4yKjmgvvCOvyQW97G89u43tA5MbHH3T0zjJB9 Dmun8P8AiiDw
xpkaWFi0t5NLuvHmbClFJ2qmDwcHqRwc8HjHP6pFYSanO+mRTR2bNmNJsFl4 5HBPGc45PGK8
+hVxFWq6ddN09d0tdevby7nXVjRhTU6T97Trt6fr2PRvCfi2PXYBBclY79B8 y9A/uP8ACuor
wmAS206TQuySIcqy9Qa9R8NeKItUgEF2yx3aDnJwH9xXh5rlf1d+1pfB+X/A PRwWNVVck/i/
M6WiiivEPSCiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACi iigAooooAKKK
KACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAoooo AKKKKACiiigA
ooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACi iigAooooAKKK
KACiiigAooooAKKKKACiiigAooooAKzdQuNQW+trWwiEjSRSSP8Au1cjaUH8 UiDHz+p7cVpV
UmF3DqdveWsME2yGSJklmMf3mQgghW/uH86atfURTW41iC+s47y32QzymMlo ET+BmGCsz8/L
6evNWJGNsb8x9ohMB2DENn/0HP1Jp9xJqN/c2RntbWGK3mMpMdy0hP7t1xgx r/e9e1R3n/MQ
/wCvQf8As9N2voCDxAjWmn6ZFAt81ulziYWZkEjL5UnJ8r5vv7SfeqGnate2 ayxwiNRcXhW2
j1m8mhkYeXEMR71ZmG8t+J461e8SakbCGwY37WMUt15csy7MhfLkYDLggfMq 9qxredNVc3Rt
73XRZ3ZW3nhnij2gLDJhsNGrjeAeh+7zXfTT9ldrT+vl+JxVGva2T1/r5/gd c2pNYaUbzV/J
t2T76wM0oyWwqr8oZmYlQFC5JIABOMv07VrTVbdprR3IRyjpLE8UkbYBw6OA ynBBwQMhgehB
rAurGR7HSLux0sWr6ZdNdLpw8tC4McsbKpUlAxEpcc4JABK5LLmXVhqlzrtt 4o/sydWgliH9
m+ZEbho0iuk3Z3+XuLXWdu/G1M53HYORvVnXHZHVan4isdLt9UlmZ3fTbL7d cRRr83lYkxjO
ASfKcYz25xkVoQ3KzoXQOAHZPnjZDlWKnggHGRwehGCMgg15M/hTUZ7LW7if w75l/qVhfQ2b
O0DSWTvNeSAM2/5fMW4jX5C3IO7AGTYbwbeSx+JbqXSYH1FrW4/smdjGZIp2 ur2VGjfOY2xL
A27IwSOcqcK4z1XfVC91C4t7y2ggtVm85XYlpdh+XB2rkYZyCxAJH3TzgEji NH8NX1p42k1O
4jvTN9quJZLvfbLDLC5fy49yp9ok2q0Y2OQgMeQSEQHrNRa4e4tUS0a4twTI wV1TEispj3En
ITOSdoJ+UcEZBLhYmOqST3dvALEm0uSyFpspJgKSWMRXOzOFySOWHGCCSe0a 0zJbbmhzloAP
uj1T/D8vQ1g1+uqwSPAru48u4uIsLE0YDMvyliyuGOOMghiSegXU30nZgU0d ZEV0YMrDII70
6o54mgkaeBSyMcyRD/0Jff1Hf69VjljmQPE6up6FTkVmyh9FFFABRRRQAVl3 l5cxag0KyeTA
IkZX/s+a43sSwIyhAGAF6+talFAGXZ3lzLqCwtJ50Bidmf8As+a32MCoAy5I OQW6elF1cao+
qSWthD5iRwxyMRCrnLM453Sp/c7Z79K1KqA31pqk91a29vOk0McZEs7RlSjO eyNnO/8ASqVr
6iK1rcaomqR2t/D5aSQySKTCqHKsg42yv/f747dat2aiMzxL9yOXCj0BUNj6 c00m+u9Ugurq
3t4EhhkjAinaQsXZD3RcY2frT7b/AF93/wBdR/6AtJ2voAXBxcWn/XU/+gPV rdVW5/19p/11
P/oDVYpDHbqN1NooAduo3U2igB26jdTaKAHbqN1NpGYKMmgB+6jdVf7QiSPH KyRuhAKlxnkA
/wBalBDAEEEHkEU9UA/dRuqN5Y48b3Vc9NxxTI5hJuZcGMPs3q2RnAPPp1/z xRqIn3UbqbTM
s8hRDgqoYkrnrnAxkehoWoxklsryGVHkikP3mQj5vqDkfjjPFMH21OMQS/7W TH+mGp4mYK5a
MlUJDspXAx14zn8KmoaaEV995/zwg/7/AB/+Io33n/PCD/v8f/iKfbEtZWzE kkwxkk9ztFVp
9QaKdohEGIJAxvYnAUk4VTgfMKcYuTshOSWrJt95/wA8IP8Av8f/AIijfef8 8IP+/wAf/iKg
j1L96qzQSRqxAD+XJjcSAAcoMZzV52CIznJCjJ2gk/gByaJRcdxpqWxUuFvJ 7aWHyYF3oVz5
xOMjH92pN95/zwg/7/H/AOIqhcambSS2upp4vs9xGxWITRLj7pU7mYbjgtnB I5A56m5YajDq
CO0OcIcEhlcf99KSM+2cjjjkZwhWhJ8q3NHTklcfvvP+eEH/AH+P/wARRvvP +eEH/f4//EVY
orUgr77z/nhB/wB/j/8AEVFI1wbm082KJV808rIWOdjf7Iq7Ve5/19p/11P/ AKA1AHnmp2F7
d6/qRsoLiXEpD+SjNgZ4zj6fpVVtB1l1Ctp1+ygkgGByAT17ewr0Dwn/AMh3 xB/11j/9nrrK
+gWY+w5IqCbUY69fhR5P1P2vM3JpNvTpuzxH/hHdW/6Bd7/4Dv8A4Uf8I7q3 /QLvf/Ad/wDC
vbqKv+26n8qJ/sqH8zPEf+Ed1b/oF3v/AIDv/hR/wjurf9Au9/8AAd/8K9uo o/tup/Kg/sqH
8zPEf+Ed1b/oF3v/AIDv/hR/wjurf9Au9/8AAd/8K9uoo/tup/Kg/sqH8zPE f+Ed1b/oF3v/
AIDv/hR/wjurf9Au9/8AAd/8K9uoo/tup/Kg/sqH8zPEf+Ed1b/oF3v/AIDv /hR/wjurf9Au
9/8AAd/8K9uoo/tup/Kg/sqH8zPEf+Ed1b/oF3v/AIDv/hR/wjurf9Au9/8A Ad/8K9uoo/tu
p/Kg/sqH8zPEf+Ed1b/oF3v/AIDv/hSjw9q6kEaZfAjkEW78fpXttFH9t1P5 UP8AsuH8zPMr
LUPFVooV9Ou50A4Els+fzxWwNd1HHPh3Uc/9c2/+JrtaK82pVoVHf2SXo2js hSqwVue/qji/
7d1D/oXdR/79t/8AE0f27qH/AELuo/8Aftv/AImu0orO9H+T8WXy1P5vwOL/ ALd1D/oXdR/7
9t/8TR/buof9C7qP/ftv/ia7Sii9H+T8WHLU/m/A4v8At3UP+hd1H/v23/xN H9u6h/0Luo/9
+2/+JrtKKL0f5PxYctT+b8Di/wC3dQ/6F3Uf+/bf/E0f27qH/Qu6j/37b/4m u0oovR/k/Fhy
1P5vwOL/ALd1D/oXdR/79t/8TR/buof9C7qP/ftv/ia7Sii9H+T8WHLU/m/A 4v8At3UP+hd1
H/v23/xNH9u6h/0Luo/9+2/+JrtKKL0f5PxYctT+b8Di/wC3dQ/6F3Uf+/bf /E0f27qH/Qu6
j/37b/4mu0oovR/k/Fhy1P5vwOL/ALd1D/oXdR/79t/8TR/buof9C7qP/ftv /ia7Sii9H+T8
WHLU/m/A4v8At3UP+hd1H/v23/xNH9u6h/0Luo/9+2/+JrtKKL0f5PxYctT+ b8Di/wC3dQ/6
F3Uf+/bf/E0f27qH/Qu6j/37b/4mu0oovR/k/Fhy1P5vwOL/ALd1D/oXdR/7 9t/8TR/buof9
C7qP/ftv/ia7Sii9H+T8WHLU/m/A4v8At3UP+hd1H/v23/xNH9u6h/0Luo/9 +2/+JrtKKL0f
5PxYctT+b8Di/wC3dQ/6F3Uf+/bf/E0f27qH/Qu6j/37b/4mu0oovR/k/Fhy 1P5vwOL/ALd1
D/oXdR/79t/8TR/buof9C7qP/ftv/ia7Sii9H+T8WHLU/m/A4v8At3UP+hd1 H/v23/xNH9u6
h/0Luo/9+2/+JrtKKL0f5PxYctT+b8Di/wC3dQ/6F3Uf+/bf/E0f27qH/Qu6 j/37b/4mu0oo
vR/k/Fhy1P5vwOL/ALd1D/oXdR/79t/8TR/buof9C7qP/ftv/ia7Sii9H+T8 WHLU/m/A4v8A
t3UP+hd1H/v23/xNH9u6h/0Luo/9+2/+JrtKKL0f5PxYctT+b8Di/wC3dQ/6 F3Uf+/bf/E0f
27qH/Qu6j/37b/4mu0oovR/k/Fhy1P5vwOL/ALd1D/oXdR/79t/8TR/buof9 C7qP/ftv/ia7
Sii9H+T8WHLU/m/A4v8At3UP+hd1H/v23/xNH9u6h/0Luo/9+2/+JrtKKL0f 5PxYctT+b8Di
/wC3dQ/6F3Uf+/bf/E0f27qH/Qu6j/37b/4mu0oovR/k/Fhy1P5vwOL/ALd1 D/oXdR/79t/8
TR/buof9C7qP/ftv/ia7Sii9H+T8WHLU/m/A4v8At3UP+hd1H/v23/xNH9u6 h/0Luo/9+2/+
JrtKKL0f5PxYctT+b8Di/wC3dQ/6F3Uf+/bf/E0f27qH/Qu6j/37b/4mu0oo vR/k/Fhy1P5v
wOL/ALd1D/oXdR/79t/8TR/buof9C7qP/ftv/ia7Sii9H+T8WHLU/m/A4v8A t3UP+hd1H/v2
3/xNH9u6h/0Luo/9+2/+JrtKKL0f5PxYctT+b8Di/wC3dQ/6F3Uf+/bf/E0f 27qH/Qu6j/37
b/4mu0oovR/k/Fhy1P5vwOL/ALd1D/oXdR/79t/8TR/buof9C7qP/ftv/ia7 Sii9H+T8WHLU
/m/A4v8At3UP+hd1H/v23/xNH9u6h/0Luo/9+2/+JrtKKL0f5PxYctT+b8Di /wC3dQ/6F3Uf
+/bf/E0f27qH/Qu6j/37b/4mu0oovR/k/Fhy1P5vwOL/ALd1D/oXdR/79t/8 TR/buof9C7qP
/ftv/ia7Sii9H+T8WHLU/m/A4v8At3UP+hd1H/v23/xNH9u6h/0Luo/9+2/+ JrtKKL0f5PxY
ctT+b8Di/wC3dQ/6F3Uf+/bf/E0f27qH/Qu6j/37b/4mu0oovR/k/Fhy1P5v wOL/ALd1D/oX
dR/79t/8TR/buof9C7qP/ftv/ia7Sii9H+T8WHLU/m/A4v8At3UP+hd1H/v2 3/xNH9u6h/0L
uo/9+2/+JrtKKL0f5PxYctT+b8Di/wC3dQ/6F3Uf+/bf/E0f27qH/Qu6j/37 b/4mu0oovR/k
/Fhy1P5vwOK/t7UP+hd1H/v23/xNL/buof8AQu6j/wB+2/8Aia3dXnSAbpWV YwGZmc4AAC8m
uPsPE1jqt7JbRoYycmBpFx56Dgsv4g8eg+oG9OjRmr8v4szk6kXbm/A0v7e1 D/oXdR/79t/8
TTF8S3bqGXQr0qRkEKcEflW/E5eHk52lR/5DQ/1qGxWVtLthCqlvKTlkLADb 6AiuaU6MZW5P
xZoo1Gr834GP/wAJHef9AG+/74P+FH/CR3n/AEAb7/vg/wCFb3lX/pB/34f/ AOLo8q/9IP8A
vw//AMXS56P8n4sfJU/n/Awf+EjvP+gDff8AfB/wo/4SO8/6AN9/3wf8KwvG Wu6hp3iXwnp8
Gq3lvZ363X2qSwtFnlk2RqyFV8uQ9TzhehPpkVF8e6zofhDTJda0+GfXjYS3 l3ZlpY5ViQ4W
RljikCbhjJfYobI4wQpz0v8An3+LDkqfz/gdR/wkd5/0Ab7/AL4P+FH/AAkd 5/0Ab7/vg/4V
wNt8RnsvEXiDUFjvb22vpdIi06zkkbbCbi3Ln5VDleASQisScDBzmtKXxv4j vfEfhi2tNLew
e7nv4biyvt0MdyIo1ZHWRovMCYbIOxSSCpHGaOel/wA+/wAWHJU/n/A6z/hI 7z/oA33/AHwf
8KP+EjvP+gDff98H/CuTsvHuq6Zo3jLWNVhS9sNJ1a4tbfZIEl4dEji2hMbP nyXLFuvymur8
MeIrzXXvorzRbrT3tWQJJJHKIp1YZyhljjYkEEEFRjjk5o56X/Pv8WHJU/n/ AAF/4SO8/wCg
Dff98H/Cj/hI7z/oA33/AHwf8K33ju2bMSxBMDG6JmPT1DD+VJ5V/wCkH/fh /wD4uj2lH+T8
WHJU/n/Awf8AhI7z/oA33/fB/wAKP+EjvP8AoA33/fB/wrbZLpHjMzxIpbGF iZS/B4yWP1/C
paXtKP8AJ+LDkqfz/gc//wAJHef9AG+/74P+FLa6n/alvqkpgeBo4fKZHPII D/41n/De+17U
PCsM2uR+gtp3Y+bNHjhnH8mzlhyR/E0+l/8AMyf9dZP/AGatKkKfJO0bONut yISnzRu7p+R1
W6jdTaK4jqHbqN1NooAduo3Vj6jq5tba52GKOZJ0t4jKruHZlVvuoMk4Y4A6 ke9GganNqltd
POqB4Ll4AURk3BcclWJIPPQ9KrlaVzP2kebk6mxuo3U2uftdcvRftpF1awvq i5ZTG5SO4jGP
nTOSCMjchyVyOSCCXCEp/CVKSjqzot1G6qNrfGa4ltpoTBcxgFoy2eD3B/L8 6uUpRcXZhGSk
roduqvJbK8hlR5IpD95kI+b6g5H44zxTLDULXU7UXFpL5ke4ocqVZWBwVZSA VYHgggEVm6bf
XM2tXFvPPlf3pjRVRk2q4XhlOQRkBlYdTx0NPket+gOS0NIfbU4xBL/tZMf6 Yal33n/PCD/v
8f8A4irFUbjWLC0uhbz3AWTjPykqmem5gML+JFQDko6tk2+8/wCeEH/f4/8A xFG+8/54Qf8A
f4//ABFWKr317b6dZS3l05S3iGZHCFtoz1OAcAdSegGScAE00m3ZDDfef88I P+/x/wDiKN95
/wA8IP8Av8f/AIiotSvTaaJeX0BR2it3mjzyrYUkdOoqzBIJoUfIJIGcdjRZ 2uF1exHvvP8A
nhB/3+P/AMRRvvP+eEH/AH+P/wARViikMr77z/nhB/3+P/xFNsy5kujIqq3m jIVsj7i98CrV
V7b/AF93/wBdR/6AtABc/wCvtP8Arqf/AEBqsVXuf9faf9dT/wCgNT/PH/PG 6/8AAaT/AOJo
AloqLzx/zxuv/AaT/wCJo88f88br/wABpP8A4mnZgS0VF54/543X/gNJ/wDE 0yO8imUtEk7q
GKkrbuRkEgjp1BBB9xRZiLFFReeP+eN1/wCA0n/xNHnj/njdf+A0n/xNFmMl pjhgyyIMsufl
Pf6e/wD9f1pvnj/njdf+A0n/AMTR54/543X/AIDSf/E0K6EEd5PKX8tE2q23 LOQeg7Y96dGp
VPmIySWOPc5/rTfPH/PG6/8AAaT/AOJo88f88br/AMBpP/iabbYDszRSs8O0 7lAIY46Z9vem
C8uJWkgZEyODzuGCByePfpS+eP8Anjdf+A0n/wATR54/543X/gNJ/wDE0JsC RV2oFyTgYyep
qrdJcHf5BKl1Vd64JXB54yOxx1qbzx/zxuv/AAGk/wDiaPPH/PG6/wDAaT/4 mkroDGt5p5Jl
i8tYMwhHQAAFiCMHnsSCOCevNb1Vy0RfebScv13G0fP/AKDT/PH/ADxuv/Aa T/4mqk2wSsFp
/wAeFr/1wj/9AFUdl0+sslpJHDcGORkknhaRMfuewZc9CODx+lXI5VjijjEN 1hEVBm2k6AY/
u+1MmW3udvn2Usu3pvs3bH5rThLllcmUeZWGXVvrMVtu1C8sJ4fNhAW3tHiY N5qc5MjcdeMf
jV2qK21ijq6aYyspyCLFgQf++as+eP8Anjdf+A0n/wATRUlzhCPKjHumNhq5 nhtZm/dsAoWQ
plyCzDZG2CSozyOcnHOS/TbmQFJPtLT/AGqWTMBDZiw7AlSwBCr8oIIHPQ5I U6vnj/njdf8A
gNJ/8TVe3itrRpWhtbpWlcu5NvKSSST3HAyScDjJPrXH7CammnodHtIuNmtS 7XGeNfAcXiUC
7snitdSGFMjqSki9PmA5yB0PfGD2I67zx/zxuv8AwGk/+Jo88f8APG6/8BpP /ia64ylB3RiZ
fhnwzYeFtKWyslLOx3Tzv9+Z/wC839B0A4FaNz/r7T/rqf8A0Bqf54/543X/ AIDSf/E1FM++
a0O2Rf3x4dCh+43YgVLvuwKnhP8A5DviD/rrH/7PXWVyfhP/AJDviD/rrH/7 PXWV3Yj4l/hj
/wCko56Pwv1l+bCvGZPHupQ6w090862zysDbiQhUxnfEP4llTDdSQ+04C5Oz 2avFbvTUm0aD
VLdRJrc0kT+bNOshEgOEkYHrkqowTxsHqK4aybtZno4ah7VSb6frf/I0nm8W QeMJtkl09q5L
Fmnk8gQjoRyQDg9OHMi5yYyQvrFfOiarLY3RubUOJZJCE2jE3mZwYJs4Mmcb Qz/NkAEhgrN9
F1OGk5JtmFSPK0FFFFdJmFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABR RRQAUUUUAFFF
FABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUU AFFFFABRRRQA
UUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABR RRQAUUUUAFFF
FABRRRQAUUUUAFFFFABRRRQAUUUUAc/4jt7e8j+z3PktC24OkrhAQQuMEken bkcViT2dhObY
t/Z5Nscwfv4/3fGOOfp+Q9BXT6lPJE6qjEBi2cEjoF9PrWXJdz44mlH/AG0b /Gu6g5cisc9R
K5dgUrBnIIZhhgeDiNBke2QazLeZ5NCSea2t2tYY9zGWQnAQEE42n0P5+9a0 czzRZc5IKjP1
jQ/zJrHi/wCRDvP+vaf+Tf5/zg+dUV5u50x2LSWPmxrJHp2nujAMrLICGB6E HZz/APXHrTv7
Of8A6Bdj/wB9/wD2H+eKnvZoNEUXbzRx2kjfvY3YDax5LJnqTySvfkjnIddX guNS0WWPTroR
yShWSRZCokTcCyh1yU3rld65K79wyQN0JJjuZ9xoS3ep6dqU2m27XenCQWji 5cCMOu1sALg5
AA5B7Y61V1jwla69cfaL/TI2m8hrZpIb+WFpIWOTGxj2l0J/hORz784q65rG nzLoOjaZO+pL
LO135l0+oqmxIGwjXE0JKkXMfO4YIYBGDFjTsvE2uPqd7Ho+mxyXmpT/AG2Q R+XdLEq2VjlQ
TNCrgmYfOHOccKQ2RXKFzcX4f6QkciJokC+Z9m+db6UOpt12wsjdUZV43KQT nknPM8vg62nj
t1ms5pJLaVpYLhtXuWniZl2sFlzvCkYyobB44rM1HxDrWr+EPEWo28tpp8Fl pr744iZpTK1k
s4eO4RwoAMygEK2dhIPzirdxrGtWniddGNxYyX93FbRrdeRL5KFvtshPkGY5 +WALwwJLZJYA
LRYCxN4MsLj+01k0eBotTybuD7bL5MrHbl/LA2B/lU7wA2cHOTV7TdGm0rzf s8c0nmY3fadU
nuOmcY8zdjr2xnj2rnm8Y628WsXSHThBolk9xdRNbuzXTRz3UThG8zEQb7Nk ZEm3fzux83oP
X/P+fX9e+fmVgMiSynmcvJp9nI56s0mSf/HPp+lN/s5/+gXY/wDff/2H+eK2 ev8An/Pr+vfP
zHX/AD/n1/Xvn5jlC5kJZTROHj06yVh0ZZMH/wBA/wA596m23/8Az7Qf9/z/ APE/54rR6/5/
z6/r3z8x1/z/AJ9f175+Y5UFzNIvwMm3t8f9dz/8T/niue05dr+JlznE0o/9 CrsX+430/wA/
z/X354+x/wBd4n/67y/+zVvTVqM/l+ZjP+JD5nTUVG0wViPKnbHdIHYfmBik 88f88br/AMBp
P/ia5bG5LRUXnj/njdf+A0n/AMTR54/543X/AIDSf/E07MDCs5dL1681G2O+ UxXSzABZIzGV
RVBzwVYMrDHXg+lZbzXmh6xc6ZokVkA5WXZK8j7E2jfJIxfCDJ7DJ/LPXK8a M7JbXCtI25yL
WQFjgDJ+Xk4AH4Cs+50fTbue4mls77fc7fO2LcIH2jC5AwOK1hNJ+8tBU4wU uaS1NiuT1vQx
carPczR3LxyR7oXtwS8EwUBXGOhGPcEEg5BIPT+eP+eN1/4DSf8AxNHnj/nj df8AgNJ/8TRR
qypS5kZ1aUaqszkPCsclprcsOoD7PeSRM0aeWUjnXI3PGD93GBlOq57qVJ7S qswt7hommspp
DE/mRl7RzsbBG4ZXg4JGfc1L54/543X/AIDSf/E0V6rqy52FGlGlHljscV4i 0vUYfEE2oWNm
8zS7MxxpxKAoHX+CQY4YkAjCk4AK9JoElnd6dHe26RfaJVC3LrFscyrwwcEA hgQQQeRWj54/
543X/gNJ/wDE1FGLeKaaaOymSWYhpXW0cGQgAAsdvOAAOewpOblGzK5dblqu NvdC1Zb+5S2H
mw3MrSCQuoVNxyQ4PJxnsDwB0rrfPH/PG6/8BpP/AImjzx/zxuv/AAGk/wDi aycb7k1KUai1
G2Vt9jsLe18xpPJiWPe3VsADJ/Kp6i88f88br/wGk/8AiaPPH/PG6/8AAaT/ AOJp2ZokkrI8
5gtbzw7dDz7Rl0xWH2lvJJS3TOHwQMGEqT8vOz02/c9DsrWztLfbYwQQwud+ IECq2R144PGO
af54/wCeN1/4DSf/ABNRW4t7S3jt7aymhgjG1I47R1VR6ABcCtJzc1ruSopM sSxRzRPFKiyR
upV0YZDA9QR3Fect8JbF/Ev2h592ij5/sZzuZs/cLd0/U9D3J9D88f8APG6/ 8BpP/iaPPH/P
G6/8BpP/AImpjKUU0upQ9EWNFRFCooAVVGAB6Cobb/X3f/XUf+gLT/PH/PG6 /wDAaT/4mmW3
+vu/+uo/9AWoGFz/AK+0/wCup/8AQGq5q2px6ZtkuL6zsbURs8txdnCLhkUA ksoGS+OT6VTu
f9faf9dT/wCgNWrcW80lzFPBNHGyIyEPGXBDFT2I/u1pAlmfpeu2upSq9pq2 m6hasHUzWbBl
WQFBtLB2GfnHHXketV9T1+K31eG0bUbGG0lgMjMZP3mQRxncAoIYEHqcNjHW teK2uPtiTzzx
PsjZFWOIr94qcnLH+7XMeIY5U8UidrK6ngNnGgMVmZhvEjHOccFchsd+neid +VpG+GpxqTtI
sN4jtLVXa21awnHynyHuRuPzDdhmfrt3YBIGcdOc6XhmWObSGeOWJ91zPIRH KsmzfK0gUlSR
uAcZwTXK6LpHiF7OOOMWcEZdj/pDOkqKXb5jFs+pA3DPqO3cWFhDp1sIYdzE ndJI5y8jd2Y+
vA9gAAAAAK2jCMKKV7t6mFVNV5K2ibXrqcrB4l1LSRr954jv9New0q4S0H2W zaBpJHjgdCWe
ZlUEzbPmwBwxZRmpLT4jaTqMVqunQT3t9cyyxJZQT27PmNVd8P5vlPhZIzhH Y/N0+V9uxP4b
s7iLU0aSdWv7uO9Z1YZimjWJY2TjHymCNsMGBIOQQcVTv/B8Wq6X/ZupavqV 5ayuWvI5/JYX
Y+XCsPLxGAFGPK8sg5bO75qkRTs/FmozLFNcad5FmmtzafNdNtKPH5s0MRjA cvu81YEYsoHz
kgbeVy7XxhrmqavFa201pawXNvHdWsn9jXN4JYpp51hd2jkURAxRxMd+OWbO 3BA6h/C9s9hq
dh9ru1tL52lSNSn+iSs7SNLE23cH8xvMBYttYDbtAxUdx4VX+0ftmmatfaR/ okNn5NjHb+X5
cRcoAskT7ceYw4wMY44oA6CiiigAooooAKKKKACiiigAooooAKKKKACiiigA ooooAKydV/4/
bL/rof8A0B61qydV/wCP2y/66H/0B6mew0ZPhP8A5DviD/rrH/7PXUTTw2yB 55Y4kLqgZ2Cg
szBVHPcsQAO5IFcv4T/5DviD/rrH/wCz1c8aWL6h4aeFI55FW7tJpRbswkEU dxHJIU2fNuCK
xG35iR8vOK6cR8S/wx/9JRhR+F+svzZ0FYdlb+GZbCy1e2s9OjtrgRS21wbd Y8+YV8vGQCCS
ygDrkgda5PVbjVV8Q6XJpv8AasEMUtlDBG1tfT/abZnTzJJWL+VGwV5VYTIZ B5e7IJQrl+H4
NUtdC8P2+lReIIRFb2CarHdLdLsmFzajEYm6II/tQYRfJt+9xtrCx0RnKOzP TIrDR724h1iG
0sbieRA8V6kaOzKQMFXAyQQByD0xWhXkcOm6lY+FfD2nQz6zY29rbtDqe631 C4YXipCqqghk
STysCbBjYwcdCSpGpZaXrdzqUX9pz64zXGoRW124uJYFMA05JGYLE+yLNyvL Rn7xZNxBIISe
kUVl+Gpr658K6RPqgkGoSWUL3Qkj2MJSgL5XA2ndnjAxWpQAUUUUAFFFFABR RRQAUUUUAFFF
FABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQBj6t/ rY/+BfyWsmXp
Wtq/+uj/AOBfyWsqXpXfh/gRz1N2aNv/AKpv95f/AEVHVWwsnn8LNZuyxm4h dQ24HAcHBxn0
PT/6+bVv/qW/3l/9FR1mwxWk0+kieLzJ0tGki3KCq4MWTzyGyVwR715lVtTd jpjsPudKnt5D
JZF5pJSHZ5J1JEy42uQTgKRlXC/w4AGM1rXtnZ6laPaX9rb3dtJjfDOqOjYO RlWyDyAfr+tQ
6dZFZlNnbkTndKPKX94c5y3HPPPNc5q2sXmh6D4fOkRpfLNIkbgxMXlgS3kl by1BB8xliwoP
GSAfUQm77Dsjo5PD2hS6ZFpkmjaa+nwtvitWt4jEjc8hDwD8zc4/iPqcyXui 6RqUckd9pdhd
RySid1nhjcPIF2hyDnLbQFyeccfXkbfxrItzrt1dww/2RaxW81kyyJE8sckk sRdnldY9rNEW
QggFGU8k4q3a+PdHvEeWJbpreKzN7cXCxh4oYlMqtllJDENCy4XduyCu5QzC rsDp5NM06bU4
tTksLR9QhQpFdNGhlRTnIDnkD5jxn+I+pzXHh7QlsHsF0bTRZuqo1uLeLy2V WZ1BXpgMzMB2
LE9Sc49t4sjk1mLSrrStQsbuVkVFn8lgQ6TuGzHIwxi3kHrnHGDkUb/4kaDp swjuXeMq0ol3
yRIY1jmeIvtZw0gLROQIw7YAyoJUEuwOuXTNOS3e3WwtBA8C2rRiNArQqGCx kdNgDMAvQbj6
nNvd9P8Avof4/wCc/XPI2njjRr3xK2hxS5ufNkgVvNiO+SMHeuwOZFxsf5mR VO3gncu7pKVw
LW76f99D/H/Ofrk3fT/vof4/5z9c1aKOYLFrd9P++h/j/nP1ybvp/wB9D/H/ ADn65q0UcwWL
LHKkZHP+0P8AH/OfrnkLAgy+JyOR58v/ALNXTVy+l/8AMyf9dZP/AGauim70 Z/L8zGf8SHzO
5tf+PZPx/nXNap4ysNHvbW21HWtMs5LqeSNI5yqmNF8zEj7pFwp8orux94gV 0tr/AMeyfj/O
s2fTHNzZs0sDGC7kuLYvE2Y3ZZATxIN3yu4xg9c44yM1sjUuWt6rW5NzNCsi u6tg7RhWYZwS
ccIT+B9Kg1pLi70mWGx1WLT5ZD5f2lk8zbzggDcuG7dePrVy0ga2t/Ldw7F3 csF2jLMW6ZPr
61z/AIr+1yGKKKO4MSNFITCrYI8wFwSoPGwEEHGQxHfiKtV0oc6V2VCCm+Vl u3e50TTLTTlj
N2bW3jhMxWUGQqoG7Co3XHqa1rWc3NrHMUZCw5VlZcHvwwB6+oGa5a3aDXYl EU9hcT4wVaSI
yEDgMymJyMgA8+vbpXU2onFrGLnb5wGGKvuz752r169BWykpxUl1M7Wdl0Ku s6h/ZljHcZxv
u7a3/wBXv/1syR9Ny/3+ueOuGxtOHp3j6y1BLORtM1K1iukt5BJOIiI47htt u7BJGOJHyoAB
KlSXCjBPQanpsOq2qW87SKiXEFwChAO6KVZVHIPG5AD7Z6dax7fwVptta29u k92Ugt9Pt1Jd
clbOUyxE/L1LHDeo6Y60hle08fWVxYW93NpmpWgvLdLiwjmERa7V3jRQmyRg pLTQr+8Kf6wH
oGK2IPGVtPqltpX9m6kmoyvIklsY0Y25TyWbzGVygGyeN8hiCPl+/hDn6L4B Fv4f0601fU7u
7vLOyht4ZFMYW0ZDE+YsRruAkhiYeYH/ANWAeCwbY03wvbafqi6obu7ur8pM ss85QGYyeSCz
BFVQQtvEo2gDAOQSSaAK/h7xQ194Fg8R6zaSaegslu52YKylPKDtIgRnOzk4 B+bjkeuPc+P/
AOyNZ1E61ZXen26W9mtraXUtqjPLI1yWYSeb5YBWH+Nx9wgDLAN0lr4bs7fw 9PoEsk91pkkT
WywTMB5VuU2CFWQK20LwCxL88saz/wDhC1e8kv59e1WfUj5Xk3ji3D2/liUD aqxBDlbiUHcr
fe4wQCACTTfGdlrRtBpFnd34mRXmaFottqpkePLsZAHG6KUZj352EjIKlsvS PH1rDp3ha11i
XN/qun2krT+bAu6WUBR+6DiQ5fjKxlRnkgBsbkXhoW97BeQatqUdwqIlzIWj kN4quzgSb0O0
bpJOI9mA+BgKoXPt/ANlaW9naWup6lDZ272kklspiK3ElsIxG7loywOIYgQh UHb0BJJAB/H+
np4VtPETWV3FZXbosAupbe1Zwyb9w86VBjgjrk4JUMmGNe08cNfPfSwW0jaa l7Yw2l+sSlJE
uFtSFZTIrhz9oJztAUYOGIKnUHhOCDTtJtrHUb6ym0u0FlBdw+U0hhwgKsHR kOTFGSdoOV4I
BINez8C2FjZw2Vve3y2kf2RmhLRkSS2xh8uVjs3bisEakAhSAcKGO6gCNvH1 ktrHcf2ZqRS6
SOTTwBFm+jeWKJXj/efKN08RxJsOH6cMBI/je1WeGxXTb5tXllki/szfAsyl ESRvmaURthJY
2wrscP0+V9pF4FsI1to3vb6WGy8pbGN2jAtIo5YpREpCAspMEQJcs2E4YEkm TVPBllq4v4bi
8u/seo3AnvbQLE0c+I4owpLRllAEKkFGVgSSCDtwAdJRRRQAVgW3+vu/+uo/ 9AWt+sC2/wBf
d/8AXUf+gLWdQaC5/wBfaf8AXU/+gNW/WBc/6+0/66n/ANAat+imDCoL2Zra xuJ0ALRxM4B6
ZAzU9RXUH2mzmg3bfNjZN2M4yMZrQRzz+JbEXdzaweI9Fn1GJXBskkBl3Rhi y7BKSCMHPGeO
elbs2oWVtG0k95bxIpwWklCgHJHUn1BH4Gq08N7dJPaPdWwDRYYiA5w2R/z0 9j1GP1qt4uhm
n8M3McEckkheIhY4y7cSKThR1wATUt2VzSlFTnGL6tHKap4oLLIV8Q+WBfbV WMxgCMS8EEDJ
G0c84I65BNdD4b1r7fqd7aNqaXeyOOSIHYGxlgxwoGR936ZHrXLXWnX+oapD JZae8aIF3C7t
zbLu85PmDEYJJ+bHUDIGcAHstC0u/s72+ur4Wym4WNVS3csBt35Jyo/vfpXL CM1UWrsdmJjT
hGy/S5HqOt/ZNcnSW4+zabpWnnUNQfZuLq29YwOCSoEUzMAA2RHgkFhWHc+P /wCyNZ1E61ZX
en26W9mtraXUtqjPLI1yWYSeb5YBWH+Nx9wgDLAN0Gp6AuoapJMyxyWd/ZPp +pQMzKZYvmMZ
UjkFS8q4G3ImJJyig0/+ELV7yS/n17VZ9SPleTeOLcPb+WJQNqrEEOVuJQdy t97jBAI7Dzyn
pHiuTxL4qthppu20hLJJ2aDyDH5jPcRsszElmAaDCmHIJySWUqasaL8QtG1y 6htLYSfaJbgQ
bFmgmCbopZFZnhkdMEQSDGdwIGQAQToJ4VsSl+l3Nd3o1CyWxu/tEuTKgaVi cjBUkzvwuABt
Ch
Re: VE crashes when loading Table [message #91816 is a reply to message #91799] Thu, 19 May 2005 12:45 Go to previous messageGo to next message
We don't support TableItems in 1.0.2.1 because these are normally data
that is computed at run time and not known about at design time.
Never the less, we shouldn't of barfed on them.
We've opened a bug:
https://bugs.eclipse.org/bugs/show_bug.cgi?id=95970
Rich Kulp
Re: VE crashes when loading Table [message #91831 is a reply to message #91816] Fri, 20 May 2005 02:55 Go to previous message
Thank you Rich for your help!
It's good to know that the tableitems had been the problem - so I know
that the other things are ok.
thanks a lot
Flik
> We've opened a bug:
Re: VE crashes when loading Table [message #607808 is a reply to message #91747] Thu, 19 May 2005 09:47 Go to previous message
Rich Kulp
Re: VE crashes when loading Table [message #607809 is a reply to message #91763] Thu, 19 May 2005 10:39 Go to previous message
hello,
But when I use:
thx
flik
TableItem tabitem;
// END of TabDecks
// END of TabCards
F1.setText("1");
F2.setText("2");
F4.setText("4");
F5.setText("5");
display.dispose ();
name="ve.JPG"
filename="ve.JPG"
Ch
Re: VE crashes when loading Table [message #607810 is a reply to message #91799] Thu, 19 May 2005 12:45 Go to previous message
We've opened a bug:
Rich Kulp
Re: VE crashes when loading Table [message #607811 is a reply to message #91816] Fri, 20 May 2005 02:55 Go to previous message
thanks a lot
Flik
> We've opened a bug:
Previous Topic:VE crashes when loading Table
Next Topic:ve gridBagLayout mechanism
Current Time: Mon Jul 14 11:06:47 EDT 2025
Powered by FUDForum. Page generated in 0.06477 seconds
