Home » Language IDEs » ServerTools (WTP) » Problem installing WTP
Problem installing WTP [message #91664] |
Tue, 12 April 2005 19:20  |
Originally posted by: jbailo.vestcom.com
Starting with a working Eclipse 3.0 I downloaded and installed:
1. The Eclipse 3.1 WTP version ( includes all the prerequisites ).
2. I copied everything from the WTP version into the existing c:\eclipse
folder.
3. I downloaded all required *.jar files and added in accordingly. (
Note, in several instances the documentation refered to the lib
directory of another directory, and that lib directory did not exist, so
I created it and then copied in the *.jar(s) )
4. When I do an "eclipse -clean" or an "eclipse", eclipse fails to
launch and a log (shown at bottom of post) is generated.
5. Here are the instructions I followed:
http://www.eclipse.org/webtools/index.html
!SESSION 2005-04-12 16:08:53.50
eclipse.buildId=I20050219-1500
java.version=1.4.2_04
Command-line arguments: -os win32 -ws win32 -arch x86 -clean
!ENTRY org.eclipse.osgi 2005-04-12 16:08:53.50
!MESSAGE Application error
!STACK 1
java.lang.NoSuchMethodError:
org.eclipse.swt.custom.CBanner.setRightMinimumSize(Lorg/ecli pse/swt/graphics/Point;)V
org.eclipse.ui.internal.PerspectiveSwitcher.updateBarParent( PerspectiveSwitcher.java:1199)
org.eclipse.ui.internal.PerspectiveSwitcher.setPerspectiveBa rLocation(PerspectiveSwitcher.java:277)
org.eclipse.ui.internal.PerspectiveSwitcher.createControl(Pe rspectiveSwitcher.java:202)
org.eclipse.ui.internal.WorkbenchWindow.createDefaultContent s(WorkbenchWindow.java:864)
org.eclipse.ui.internal.WorkbenchWindowConfigurer.createDefa ultContents(WorkbenchWindowConfigurer.java:573)
org.eclipse.ui.application.WorkbenchWindowAdvisor.createWind owContents(WorkbenchWindowAdvisor.java:352)
org.eclipse.ui.internal.WorkbenchWindow.createContents(Workb enchWindow.java:778)
at org.eclipse.jface.window.Window.create(Window.java:375)
org.eclipse.ui.internal.Workbench.busyOpenWorkbenchWindow(Wo rkbench.java:581)
org.eclipse.ui.internal.Workbench.openFirstTimeWindow(Workbe nch.java:1209)
org.eclipse.ui.internal.WorkbenchConfigurer.openFirstTimeWin dow(WorkbenchConfigurer.java:178)
org.eclipse.ui.application.WorkbenchAdvisor.openWindows(Work benchAdvisor.java:717)
at org.eclipse.ui.internal.Workbench.init(Workbench.java:918)
at org.eclipse.ui.internal.Workbench.runUI(Workbench.java:1554)
org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Work bench.java:293)
at org.eclipse.ui.PlatformUI.createAndRunWorkbench(PlatformUI.j ava:144)
at org.eclipse.ui.internal.ide.IDEApplication.run(IDEApplicatio n.java:102)
org.eclipse.core.internal.runtime.PlatformActivator$1.run(Pl atformActivator.java:228)
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:333)
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:150)
at org.eclipse.core.launcher.Main.invokeFramework(Main.java:268 )
at org.eclipse.core.launcher.Main.basicRun(Main.java:260)
at org.eclipse.core.launcher.Main.run(Main.java:887)
at org.eclipse.core.launcher.Main.main(Main.java:871)
!MESSAGE Bundle update@/c:/eclipse/plugins/org.eclipse.ant.core_3.0.0/
was not resolved.
!SUBENTRY 1 org.eclipse.osgi 2005-04-12 16:08:53.50
!MESSAGE Bundle update@/c:/eclipse/plugins/org.eclipse.ant.core_3.1.0/
was picked instead.
!MESSAGE Bundle update@/c:/eclipse/plugins/org.eclipse.ant.ui_3.0.1/
was not resolved.
!MESSAGE Bundle update@/c:/eclipse/plugins/org.eclipse.ant.ui_3.1.0/ was
picked instead.
!ENTRY org.eclipse.osgi 2005-04-12 16:08:53.65
!MESSAGE Bundle update@/c:/eclipse/plugins/org.eclipse.compare_3.0.0/
was not resolved.
!SUBENTRY 1 org.eclipse.osgi 2005-04-12 16:08:53.65
!MESSAGE Bundle update@/c:/eclipse/plugins/org.eclipse.compare_3.1.0/
was picked instead.
!MESSAGE Bundle
update@/c:/eclipse/plugins/org.eclipse.core.expressions_3.0. 0/ was
not resolved.
!MESSAGE Bundle
update@/c:/eclipse/plugins/org.eclipse.core.expressions_3.1. 0/ was
picked instead.
!MESSAGE Bundle
update@/c:/eclipse/plugins/org.eclipse.core.filebuffers_3.0. 1/ was
not resolved.
!MESSAGE Bundle
update@/c:/eclipse/plugins/org.eclipse.core.filebuffers_3.1. 0/ was
picked instead.
!MESSAGE Bundle
update@/c:/eclipse/plugins/org.eclipse.core.resources_3.0.1/ was
not resolved.
!MESSAGE Bundle
update@/c:/eclipse/plugins/org.eclipse.core.resources_3.1.0/ was picked
instead.
!MESSAGE Bundle
update@/c:/eclipse/plugins/org.eclipse.core.runtime_3.0.1/ was not
resolved.
!MESSAGE Bundle
initial@reference:file:c:/eclipse/plugins/org.eclipse.core.runtime_3.1.0/
was picked instead.
!MESSAGE Bundle
update@/c:/eclipse/plugins/org.eclipse.core.variables_3.0.0/ was
not resolved.
!MESSAGE Bundle
update@/c:/eclipse/plugins/org.eclipse.core.variables_3.1.0/ was picked
instead.
!MESSAGE Bundle update@/c:/eclipse/plugins/org.eclipse.debug.core_3.0.1/
was not resolved.
!MESSAGE Bundle update@/c:/eclipse/plugins/org.eclipse.debug.core_3.1.0/
was picked instead.
!MESSAGE Bundle update@/c:/eclipse/plugins/org.eclipse.debug.ui_3.0.1/
was not resolved.
!MESSAGE Bundle update@/c:/eclipse/plugins/org.eclipse.debug.ui_3.1.0/
was picked instead.
!MESSAGE Bundle update@/c:/eclipse/plugins/org.eclipse.help.base_3.0.0/
was not resolved.
!MESSAGE Bundle update@/c:/eclipse/plugins/org.eclipse.help.base_3.0.1/
was picked instead.
!MESSAGE Bundle
update@/c:/eclipse/plugins/org.eclipse.help.webapp_3.0.0/ was not
resolved.
!MESSAGE Bundle
update@/c:/eclipse/plugins/org.eclipse.help.webapp_3.0.1/ was picked
instead.
!MESSAGE Bundle update@/c:/eclipse/plugins/org.eclipse.jdt.core_3.0.1/
was not resolved.
!MESSAGE Bundle update@/c:/eclipse/plugins/org.eclipse.jdt.core_3.1.0/
was picked instead.
!MESSAGE Bundle
update@/c:/eclipse/plugins/org.eclipse.jdt.debug.ui_3.0.1/ was not
resolved.
!MESSAGE Bundle
update@/c:/eclipse/plugins/org.eclipse.jdt.debug.ui_3.1.0/ was picked
instead.
!MESSAGE Bundle update@/c:/eclipse/plugins/org.eclipse.jdt.debug_3.0.1/
was not resolved.
!MESSAGE Bundle update@/c:/eclipse/plugins/org.eclipse.jdt.debug_3.1.0/
was picked instead.
!MESSAGE Bundle
update@/c:/eclipse/plugins/org.eclipse.jdt.doc.isv_3.0.1/ was not
resolved.
!MESSAGE Bundle
update@/c:/eclipse/plugins/org.eclipse.jdt.doc.isv_3.1.0/ was picked
instead.
!ENTRY org.eclipse.osgi 2005-04-12 16:08:53.81
!MESSAGE Bundle
update@/c:/eclipse/plugins/org.eclipse.jdt.doc.user_3.0.1/ was not
resolved.
!SUBENTRY 1 org.eclipse.osgi 2005-04-12 16:08:53.81
!MESSAGE Bundle
update@/c:/eclipse/plugins/org.eclipse.jdt.doc.user_3.1.0/ was picked
instead.
!MESSAGE Bundle update@/c:/eclipse/plugins/org.eclipse.jdt.junit_3.0.1/
was not resolved.
!MESSAGE Bundle update@/c:/eclipse/plugins/org.eclipse.jdt.junit_3.1.0/
was picked instead.
!MESSAGE Bundle
update@/c:/eclipse/plugins/org.eclipse.jdt.launching_3.0.1/ was not
resolved.
!MESSAGE Bundle
update@/c:/eclipse/plugins/org.eclipse.jdt.launching_3.1.0/ was picked
instead.
!MESSAGE Bundle update@/c:/eclipse/plugins/org.eclipse.jdt.source_3.0.1/
was not resolved.
!MESSAGE Bundle update@/c:/eclipse/plugins/org.eclipse.jdt.source_3.1.0/
was picked instead.
!MESSAGE Bundle update@/c:/eclipse/plugins/org.eclipse.jdt.ui_3.0.1/
was not resolved.
!MESSAGE Bundle update@/c:/eclipse/plugins/org.eclipse.jdt.ui_3.1.0/ was
picked instead.
!MESSAGE Bundle update@/c:/eclipse/plugins/org.eclipse.jdt_3.0.1/
was not resolved.
!MESSAGE Bundle update@/c:/eclipse/plugins/org.eclipse.jdt_3.1.0/ was
picked instead.
!MESSAGE Bundle
update@/c:/eclipse/plugins/org.eclipse.jst.server.core_3.0.0 / was
not resolved.
!MESSAGE Missing required bundle org.eclipse.core.runtime_[3.0.0,3.1.0).
!MESSAGE Missing required bundle org.eclipse.core.resources_[3.0.0,3.1.0).
!MESSAGE Missing required bundle org.eclipse.debug.core_[3.0.0,3.1.0).
!MESSAGE Missing required bundle org.eclipse.wst.server.core_[3.0.0,3.1.0).
!MESSAGE Missing required bundle org.eclipse.jdt.core_[3.0.0,3.1.0).
!MESSAGE Missing required bundle org.eclipse.jdt.launching_[3.0.0,3.1.0).
!MESSAGE Bundle
update@/c:/eclipse/plugins/org.eclipse.jst.server.tomcat.cor e_3.0.0/
was not resolved.
!MESSAGE Missing required bundle org.eclipse.jdt.debug_[3.0.0,3.1.0).
!MESSAGE Missing required bundle org.eclipse.jst.server.core_[3.0.0,3.1.0).
!ENTRY org.eclipse.osgi 2005-04-12 16:08:53.96
!MESSAGE Bundle
update@/c:/eclipse/plugins/org.eclipse.jst.server.tomcat.ui_ 3.0.0/
was not resolved.
!SUBENTRY 1 org.eclipse.osgi 2005-04-12 16:08:53.96
!MESSAGE Missing required bundle org.eclipse.ui_[3.0.0,3.1.0).
!MESSAGE Missing required bundle org.eclipse.ui.ide_[3.0.0,3.1.0).
!MESSAGE Missing required bundle org.eclipse.ui.editors_[3.0.0,3.1.0).
!MESSAGE Missing required bundle org.eclipse.debug.ui_[3.0.0,3.1.0).
!MESSAGE Missing required bundle org.eclipse.jdt.debug.ui_[3.0.0,3.1.0).
!MESSAGE Missing required bundle org.eclipse.wst.server.ui_[3.0.0,3.1.0).
!MESSAGE Missing required bundle org.eclipse.jst.server.ui_[3.0.0,3.1.0).
org.eclipse.jst.server.tomcat.core_[3.0.0,3.1.0).
!MESSAGE Bundle
update@/c:/eclipse/plugins/org.eclipse.jst.server.ui_3.0.0/ was
not resolved.
!MESSAGE Missing required bundle org.eclipse.ui.views_[3.0.0,3.1.0).
!MESSAGE Bundle
update@/c:/eclipse/plugins/org.eclipse.ltk.core.refactoring_ 3.0.1/
was not resolved.
!MESSAGE Bundle
update@/c:/eclipse/plugins/org.eclipse.ltk.core.refactoring_ 3.1.0/ was
picked instead.
!MESSAGE Bundle
update@/c:/eclipse/plugins/org.eclipse.ltk.ui.refactoring_3. 0.1/
was not resolved.
!MESSAGE Bundle
update@/c:/eclipse/plugins/org.eclipse.ltk.ui.refactoring_3. 1.0/ was
picked instead.
!ENTRY org.eclipse.osgi 2005-04-12 16:08:53.112
!MESSAGE Bundle update@/c:/eclipse/plugins/org.eclipse.osgi_3.0.1/
was not resolved.
!SUBENTRY 1 org.eclipse.osgi 2005-04-12 16:08:53.112
!MESSAGE Bundle System Bundle was picked instead.
!MESSAGE Bundle
update@/c:/eclipse/plugins/org.eclipse.platform.doc.isv_3.0. 1/ was
not resolved.
!MESSAGE Bundle
update@/c:/eclipse/plugins/org.eclipse.platform.doc.isv_3.1. 0/ was
picked instead.
!MESSAGE Bundle
update@/c:/eclipse/plugins/org.eclipse.platform.doc.user_3.0 .1/
was not resolved.
!MESSAGE Bundle
update@/c:/eclipse/plugins/org.eclipse.platform.doc.user_3.1 .0/ was
picked instead.
!MESSAGE Bundle
update@/c:/eclipse/plugins/org.eclipse.platform.source_3.0.1 / was
not resolved.
!MESSAGE Bundle
update@/c:/eclipse/plugins/org.eclipse.platform.source_3.1.0 / was picked
instead.
!MESSAGE Bundle update@/c:/eclipse/plugins/org.eclipse.platform_3.0.1/
was not resolved.
!MESSAGE Bundle update@/c:/eclipse/plugins/org.eclipse.platform_3.1.0/
was picked instead.
!MESSAGE Bundle update@/c:/eclipse/plugins/org.eclipse.search_3.0.1/
was not resolved.
!MESSAGE Bundle update@/c:/eclipse/plugins/org.eclipse.search_3.1.0/ was
picked instead.
!MESSAGE Bundle update@/c:/eclipse/plugins/org.eclipse.swt_3.0.1/
was not resolved.
!MESSAGE Bundle update@/c:/eclipse/plugins/org.eclipse.swt_3.1.0/ was
picked instead.
!MESSAGE Bundle update@/c:/eclipse/plugins/org.eclipse.team.core_3.0.0/
was not resolved.
!MESSAGE Bundle update@/c:/eclipse/plugins/org.eclipse.team.core_3.1.0/
was picked instead.
!MESSAGE Bundle
update@/c:/eclipse/plugins/org.eclipse.team.cvs.core_3.0.1/ was
not resolved.
!MESSAGE Bundle
update@/c:/eclipse/plugins/org.eclipse.team.cvs.core_3.1.0/ was picked
instead.
!MESSAGE Bundle
update@/c:/eclipse/plugins/org.eclipse.team.cvs.ssh2_3.0.0/ was
not resolved.
!MESSAGE Bundle
update@/c:/eclipse/plugins/org.eclipse.team.cvs.ssh2_3.1.0/ was picked
instead.
!ENTRY org.eclipse.osgi 2005-04-12 16:08:53.128
!MESSAGE Bundle
update@/c:/eclipse/plugins/org.eclipse.team.cvs.ui_3.0.1/ was not
resolved.
!SUBENTRY 1 org.eclipse.osgi 2005-04-12 16:08:53.128
!MESSAGE Bundle
update@/c:/eclipse/plugins/org.eclipse.team.cvs.ui_3.1.0/ was picked
instead.
!MESSAGE Bundle update@/c:/eclipse/plugins/org.eclipse.team.ui_3.0.1/
was not resolved.
!MESSAGE Bundle update@/c:/eclipse/plugins/org.eclipse.team.ui_3.1.0/
was picked instead.
!MESSAGE Bundle
update@/c:/eclipse/plugins/org.eclipse.ui.cheatsheets_3.0.0/ was
not resolved.
!MESSAGE Bundle
update@/c:/eclipse/plugins/org.eclipse.ui.cheatsheets_3.0.1/ was picked
instead.
!MESSAGE Bundle update@/c:/eclipse/plugins/org.eclipse.ui.console_3.0.0/
was not resolved.
!MESSAGE Bundle update@/c:/eclipse/plugins/org.eclipse.ui.console_3.1.0/
was picked instead.
!MESSAGE Bundle update@/c:/eclipse/plugins/org.eclipse.ui.editors_3.0.1/
was not resolved.
!MESSAGE Bundle update@/c:/eclipse/plugins/org.eclipse.ui.editors_3.1.0/
was picked instead.
!MESSAGE Bundle
update@/c:/eclipse/plugins/org.eclipse.ui.externaltools_3.0. 1/ was
not resolved.
!MESSAGE Bundle
update@/c:/eclipse/plugins/org.eclipse.ui.externaltools_3.1. 0/ was
picked instead.
!MESSAGE Bundle update@/c:/eclipse/plugins/org.eclipse.ui.ide_3.0.1/
was not resolved.
!MESSAGE Bundle update@/c:/eclipse/plugins/org.eclipse.ui.ide_3.1.0/ was
picked instead.
!MESSAGE Bundle update@/c:/eclipse/plugins/org.eclipse.ui.intro_3.0.1/
was not resolved.
!MESSAGE Bundle update@/c:/eclipse/plugins/org.eclipse.ui.intro_3.1.0/
was picked instead.
!MESSAGE Bundle
update@/c:/eclipse/plugins/org.eclipse.ui.presentations.r21_ 3.0.1/
was not resolved.
!MESSAGE Bundle
update@/c:/eclipse/plugins/org.eclipse.ui.presentations.r21_ 3.1.0/ was
picked instead.
!MESSAGE Bundle update@/c:/eclipse/plugins/org.eclipse.ui.views_3.0.0/
was not resolved.
!MESSAGE Bundle update@/c:/eclipse/plugins/org.eclipse.ui.views_3.1.0/
was picked instead.
!MESSAGE Bundle
update@/c:/eclipse/plugins/org.eclipse.ui.workbench.textedit or_3.0.1/
was not resolved.
!MESSAGE Bundle
update@/c:/eclipse/plugins/org.eclipse.ui.workbench.textedit or_3.1.0/
was picked instead.
!MESSAGE Bundle
update@/c:/eclipse/plugins/org.eclipse.ui.workbench_3.0.1/ was not
resolved.
!MESSAGE Bundle
update@/c:/eclipse/plugins/org.eclipse.ui.workbench_3.1.0/ was picked
instead.
!MESSAGE Bundle update@/c:/eclipse/plugins/org.eclipse.ui_3.0.1/
was not resolved.
!MESSAGE Bundle update@/c:/eclipse/plugins/org.eclipse.ui_3.1.0/ was
picked instead.
!MESSAGE Bundle
update@/c:/eclipse/plugins/org.eclipse.update.core_3.0.0/ was not
resolved.
!MESSAGE Bundle
update@/c:/eclipse/plugins/org.eclipse.update.core_3.0.1/ was picked
instead.
!MESSAGE Bundle update@/c:/eclipse/plugins/org.eclipse.update.ui_3.0.0/
was not resolved.
!MESSAGE Bundle update@/c:/eclipse/plugins/org.eclipse.update.ui_3.0.1/
was picked instead.
!ENTRY org.eclipse.osgi 2005-04-12 16:08:53.143
!MESSAGE Bundle
update@/c:/eclipse/plugins/org.eclipse.wst.monitor.core_3.0. 0/ was
not resolved.
!SUBENTRY 1 org.eclipse.osgi 2005-04-12 16:08:53.143
!MESSAGE Bundle
update@/c:/eclipse/plugins/org.eclipse.wst.monitor.ui_3.0.0/ was
not resolved.
!MESSAGE Missing required bundle org.eclipse.wst.monitor.core_[3.0.0,3.1.0).
!MESSAGE Bundle
update@/c:/eclipse/plugins/org.eclipse.wst.server.core_3.0.0 / was
not resolved.
!MESSAGE Bundle
update@/c:/eclipse/plugins/org.eclipse.wst.server.ui_3.0.0/ was
not resolved.
org.eclipse.ui.workbench.texteditor_[3.0.0,3.1.0).
!MESSAGE Bundle
update@/c:/eclipse/plugins/org.eclipse.wst.server.util_3.0.0 / was
not resolved.
!MESSAGE Missing required bundle org.eclipse.wst.webbrowser_[3.0.0,3.1.0).
!MESSAGE Bundle
update@/c:/eclipse/plugins/org.eclipse.wst.webbrowser_3.0.0/ [314] was
not resolved.
Re: Problem installing WTP [message #91699 is a reply to message #91664] |
Tue, 12 April 2005 19:34   |
ok, nevermind.
I just deleted my 3.0 eclipse entirely and then went with the 3.1 WST
edition from scratch...seems to load.
Now I'll add in JDT.
> folder.
> BootLoader constants: OS=win32, ARCH=x86, WS=win32, NL=en_US
> !STACK 1
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> was not resolved.
> was picked instead.
> was not resolved.
> picked instead.
> was not resolved.
> was picked instead.
> !MESSAGE Bundle
> not resolved.
> !MESSAGE Bundle
> picked instead.
> !MESSAGE Bundle
> not resolved.
> !MESSAGE Bundle
> picked instead.
> !MESSAGE Bundle
> not resolved.
> !MESSAGE Bundle
> instead.
> !MESSAGE Bundle
> resolved.
> !MESSAGE Bundle
> was picked instead.
> !MESSAGE Bundle
> not resolved.
> !MESSAGE Bundle
> instead.
> was not resolved.
> was picked instead.
> was not resolved.
> was picked instead.
> was not resolved.
> was picked instead.
> !MESSAGE Bundle
> resolved.
> !MESSAGE Bundle
> instead.
> was not resolved.
> was picked instead.
> !MESSAGE Bundle
> resolved.
> !MESSAGE Bundle
> instead.
> was not resolved.
> was picked instead.
> !MESSAGE Bundle
> resolved.
> !MESSAGE Bundle
> instead.
> !MESSAGE Bundle
> resolved.
> !MESSAGE Bundle
> instead.
> was not resolved.
> was picked instead.
> !MESSAGE Bundle
> resolved.
> !MESSAGE Bundle
> instead.
> was not resolved.
> was picked instead.
> was not resolved.
> picked instead.
> was not resolved.
> picked instead.
> !MESSAGE Bundle
> not resolved.
> !MESSAGE Bundle
> was not resolved.
> !MESSAGE Bundle
> was not resolved.
> !MESSAGE Bundle
> not resolved.
> !MESSAGE Bundle
> was not resolved.
> !MESSAGE Bundle
> picked instead.
> !MESSAGE Bundle
> was not resolved.
> !MESSAGE Bundle
> picked instead.
> was not resolved.
> !MESSAGE Bundle
> not resolved.
> !MESSAGE Bundle
> picked instead.
> !MESSAGE Bundle
> was not resolved.
> !MESSAGE Bundle
> picked instead.
> !MESSAGE Bundle
> not resolved.
> !MESSAGE Bundle
> instead.
> was not resolved.
> was picked instead.
> was not resolved.
> picked instead.
> was not resolved.
> picked instead.
> was not resolved.
> was picked instead.
> !MESSAGE Bundle
> not resolved.
> !MESSAGE Bundle
> instead.
> !MESSAGE Bundle
> not resolved.
> !MESSAGE Bundle
> instead.
> !MESSAGE Bundle
> resolved.
> !MESSAGE Bundle
> instead.
> was not resolved.
> was picked instead.
> !MESSAGE Bundle
> not resolved.
> !MESSAGE Bundle
> instead.
> was not resolved.
> was picked instead.
> was not resolved.
> was picked instead.
> !MESSAGE Bundle
> not resolved.
> !MESSAGE Bundle
> picked instead.
> was not resolved.
> picked instead.
> was not resolved.
> was picked instead.
> !MESSAGE Bundle
> was not resolved.
> !MESSAGE Bundle
> picked instead.
> was not resolved.
> was picked instead.
> !MESSAGE Bundle
> was not resolved.
> !MESSAGE Bundle
> was picked instead.
> !MESSAGE Bundle
> resolved.
> !MESSAGE Bundle
> instead.
> was not resolved.
> picked instead.
> !MESSAGE Bundle
> resolved.
> !MESSAGE Bundle
> instead.
> was not resolved.
> was picked instead.
> !MESSAGE Bundle
> not resolved.
> !MESSAGE Bundle
> not resolved.
> !MESSAGE Bundle
> not resolved.
> !MESSAGE Bundle
> not resolved.
> !MESSAGE Bundle
> not resolved.
> !MESSAGE Bundle
> not resolved.
Re: Problem installing WTP [message #91729 is a reply to message #91699] |
Tue, 12 April 2005 19:53   |
> ok, nevermind.
Ok, I see another point of confusion.
When I click on the link on the eclipse home page for the JDT, it lists
the actually SDK first ( not the JDT ). I was installing this thinking
it was the SDK, when the JDT is actually at the bottom of the page.
>> c:\eclipse folder.
>> so I created it and then copied in the *.jar(s) )
>> !STACK 1
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method)
>> at
>> at
>> was not resolved.
>> was picked instead.
>> was not resolved.
>> was picked instead.
>> was not resolved.
>> was picked instead.
>> !MESSAGE Bundle
>> was not resolved.
>> !MESSAGE Bundle
>> picked instead.
>> !MESSAGE Bundle
>> was not resolved.
>> !MESSAGE Bundle
>> picked instead.
>> !MESSAGE Bundle
>> not resolved.
>> !MESSAGE Bundle
>> picked instead.
>> !MESSAGE Bundle
>> not resolved.
>> !MESSAGE Bundle
>> was picked instead.
>> !MESSAGE Bundle
>> not resolved.
>> !MESSAGE Bundle
>> picked instead.
>> !MESSAGE Bundle
>> update@/c:/eclipse/plugins/org.eclipse.debug.core_3.0.1/ was not
>> resolved.
>> !MESSAGE Bundle
>> update@/c:/eclipse/plugins/org.eclipse.debug.core_3.1.0/ was picked
>> instead.
>> was not resolved.
>> was picked instead.
>> !MESSAGE Bundle
>> update@/c:/eclipse/plugins/org.eclipse.help.base_3.0.0/ was not
>> resolved.
>> !MESSAGE Bundle
>> update@/c:/eclipse/plugins/org.eclipse.help.base_3.0.1/ was picked
>> instead.
>> !MESSAGE Bundle
>> resolved.
>> !MESSAGE Bundle
>> instead.
>> was not resolved.
>> was picked instead.
>> !MESSAGE Bundle
>> not resolved.
>> !MESSAGE Bundle
>> instead.
>> !MESSAGE Bundle
>> update@/c:/eclipse/plugins/org.eclipse.jdt.debug_3.0.1/ was not
>> resolved.
>> !MESSAGE Bundle
>> update@/c:/eclipse/plugins/org.eclipse.jdt.debug_3.1.0/ was picked
>> instead.
>> !MESSAGE Bundle
>> resolved.
>> !MESSAGE Bundle
>> instead.
>> !MESSAGE Bundle
>> not resolved.
>> !MESSAGE Bundle
>> instead.
>> !MESSAGE Bundle
>> update@/c:/eclipse/plugins/org.eclipse.jdt.junit_3.0.1/ was not
>> resolved.
>> !MESSAGE Bundle
>> update@/c:/eclipse/plugins/org.eclipse.jdt.junit_3.1.0/ was picked
>> instead.
>> !MESSAGE Bundle
>> not resolved.
>> !MESSAGE Bundle
>> instead.
>> !MESSAGE Bundle
>> update@/c:/eclipse/plugins/org.eclipse.jdt.source_3.0.1/ was not
>> resolved.
>> !MESSAGE Bundle
>> update@/c:/eclipse/plugins/org.eclipse.jdt.source_3.1.0/ was picked
>> instead.
>> was not resolved.
>> was picked instead.
>> was not resolved.
>> picked instead.
>> !MESSAGE Bundle
>> was not resolved.
>> !MESSAGE Bundle
>> was not resolved.
>> !MESSAGE Bundle
>> was not resolved.
>> !MESSAGE Bundle
>> not resolved.
>> !MESSAGE Bundle
>> was not resolved.
>> !MESSAGE Bundle
>> picked instead.
>> !MESSAGE Bundle
>> was not resolved.
>> !MESSAGE Bundle
>> picked instead.
>> was not resolved.
>> !MESSAGE Bundle
>> was not resolved.
>> !MESSAGE Bundle
>> picked instead.
>> !MESSAGE Bundle
>> was not resolved.
>> !MESSAGE Bundle
>> picked instead.
>> !MESSAGE Bundle
>> was not resolved.
>> !MESSAGE Bundle
>> picked instead.
>> was not resolved.
>> was picked instead.
>> was not resolved.
>> was picked instead.
>> was not resolved.
>> picked instead.
>> !MESSAGE Bundle
>> update@/c:/eclipse/plugins/org.eclipse.team.core_3.0.0/ was not
>> resolved.
>> !MESSAGE Bundle
>> update@/c:/eclipse/plugins/org.eclipse.team.core_3.1.0/ was picked
>> instead.
>> !MESSAGE Bundle
>> not resolved.
>> !MESSAGE Bundle
>> instead.
>> !MESSAGE Bundle
>> not resolved.
>> !MESSAGE Bundle
>> instead.
>> !MESSAGE Bundle
>> not resolved.
>> !MESSAGE Bundle
>> instead.
>> was not resolved.
>> was picked instead.
>> !MESSAGE Bundle
>> not resolved.
>> !MESSAGE Bundle
>> picked instead.
>> !MESSAGE Bundle
>> update@/c:/eclipse/plugins/org.eclipse.ui.console_3.0.0/ was not
>> resolved.
>> !MESSAGE Bundle
>> update@/c:/eclipse/plugins/org.eclipse.ui.console_3.1.0/ was picked
>> instead.
>> !MESSAGE Bundle
>> update@/c:/eclipse/plugins/org.eclipse.ui.editors_3.0.1/ was not
>> resolved.
>> !MESSAGE Bundle
>> update@/c:/eclipse/plugins/org.eclipse.ui.editors_3.1.0/ was picked
>> instead.
>> !MESSAGE Bundle
>> was not resolved.
>> !MESSAGE Bundle
>> picked instead.
>> was not resolved.
>> was picked instead.
>> was not resolved.
>> was picked instead.
>> !MESSAGE Bundle
>> was not resolved.
>> !MESSAGE Bundle
>> picked instead.
>> was not resolved.
>> was picked instead.
>> !MESSAGE Bundle
>> was not resolved.
>> !MESSAGE Bundle
>> was picked instead.
>> !MESSAGE Bundle
>> not resolved.
>> !MESSAGE Bundle
>> instead.
>> was not resolved.
>> picked instead.
>> !MESSAGE Bundle
>> not resolved.
>> !MESSAGE Bundle
>> instead.
>> !MESSAGE Bundle
>> update@/c:/eclipse/plugins/org.eclipse.update.ui_3.0.0/ was not
>> resolved.
>> !MESSAGE Bundle
>> update@/c:/eclipse/plugins/org.eclipse.update.ui_3.0.1/ was picked
>> instead.
>> !MESSAGE Bundle
>> was not resolved.
>> !MESSAGE Bundle
>> not resolved.
>> !MESSAGE Bundle
>> was not resolved.
>> !MESSAGE Bundle
>> not resolved.
>> !MESSAGE Bundle
>> was not resolved.
>> !MESSAGE Bundle
>> not resolved.
Re: Problem installing WTP [message #91761 is a reply to message #91664] |
Tue, 12 April 2005 21:35   |
WTP buils are built on top of Eclipse 3.1 milestone+ builds. You need to
get eclipse 3.1 M6 milestone build if you are using a recent WTP IBuild
from last week.
For WTP M3 milstone you need Eclipse 3.1 M5 milestone build
To build a complete WTP target look at the Requirements section on the
IBuild page and for instruction on how to build one look at ths link
http://www.eclipse.org/webtools/testtutorials/gettingstarted /GettingStarted.html
- Vijay
> folder.
> !STACK 1
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> was not resolved.
> was picked instead.
> was not resolved.
> picked instead.
> was not resolved.
> was picked instead.
> !MESSAGE Bundle
> not resolved.
> !MESSAGE Bundle
> picked instead.
> !MESSAGE Bundle
> not resolved.
> !MESSAGE Bundle
> picked instead.
> !MESSAGE Bundle
> not resolved.
> !MESSAGE Bundle
> instead.
> !MESSAGE Bundle
> resolved.
> !MESSAGE Bundle
> was picked instead.
> !MESSAGE Bundle
> not resolved.
> !MESSAGE Bundle
> instead.
> was not resolved.
> was picked instead.
> was not resolved.
> was picked instead.
> was not resolved.
> was picked instead.
> !MESSAGE Bundle
> resolved.
> !MESSAGE Bundle
> instead.
> was not resolved.
> was picked instead.
> !MESSAGE Bundle
> resolved.
> !MESSAGE Bundle
> instead.
> was not resolved.
> was picked instead.
> !MESSAGE Bundle
> resolved.
> !MESSAGE Bundle
> instead.
> !MESSAGE Bundle
> resolved.
> !MESSAGE Bundle
> instead.
> was not resolved.
> was picked instead.
> !MESSAGE Bundle
> resolved.
> !MESSAGE Bundle
> instead.
> was not resolved.
> was picked instead.
> was not resolved.
> picked instead.
> was not resolved.
> picked instead.
> !MESSAGE Bundle
> not resolved.
> !MESSAGE Bundle
> was not resolved.
> !MESSAGE Bundle
> was not resolved.
> !MESSAGE Bundle
> not resolved.
> !MESSAGE Bundle
> was not resolved.
> !MESSAGE Bundle
> picked instead.
> !MESSAGE Bundle
> was not resolved.
> !MESSAGE Bundle
> picked instead.
> was not resolved.
> !MESSAGE Bundle
> not resolved.
> !MESSAGE Bundle
> picked instead.
> !MESSAGE Bundle
> was not resolved.
> !MESSAGE Bundle
> picked instead.
> !MESSAGE Bundle
> not resolved.
> !MESSAGE Bundle
> instead.
> was not resolved.
> was picked instead.
> was not resolved.
> picked instead.
> was not resolved.
> picked instead.
> was not resolved.
> was picked instead.
> !MESSAGE Bundle
> not resolved.
> !MESSAGE Bundle
> instead.
> !MESSAGE Bundle
> not resolved.
> !MESSAGE Bundle
> instead.
> !MESSAGE Bundle
> resolved.
> !MESSAGE Bundle
> instead.
> was not resolved.
> was picked instead.
> !MESSAGE Bundle
> not resolved.
> !MESSAGE Bundle
> instead.
> was not resolved.
> was picked instead.
> was not resolved.
> was picked instead.
> !MESSAGE Bundle
> not resolved.
> !MESSAGE Bundle
> picked instead.
> was not resolved.
> picked instead.
> was not resolved.
> was picked instead.
> !MESSAGE Bundle
> was not resolved.
> !MESSAGE Bundle
> picked instead.
> was not resolved.
> was picked instead.
> !MESSAGE Bundle
> was not resolved.
> !MESSAGE Bundle
> was picked instead.
> !MESSAGE Bundle
> resolved.
> !MESSAGE Bundle
> instead.
> was not resolved.
> picked instead.
> !MESSAGE Bundle
> resolved.
> !MESSAGE Bundle
> instead.
> was not resolved.
> was picked instead.
> !MESSAGE Bundle
> not resolved.
> !MESSAGE Bundle
> not resolved.
> !MESSAGE Bundle
> not resolved.
> !MESSAGE Bundle
> not resolved.
> !MESSAGE Bundle
> not resolved.
> !MESSAGE Bundle
> not resolved.
Re: Problem installing WTP [message #91881 is a reply to message #91761] |
Wed, 13 April 2005 10:39  |
thanks, actually it works fine now...i just mixed up some things in the
downloads.
> from last week.
> - Vijay
>> c:\eclipse folder.
>> !STACK 1
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> was not resolved.
>> was picked instead.
>> was not resolved.
>> was picked instead.
>> was not resolved.
>> was picked instead.
>> !MESSAGE Bundle
>> was not resolved.
>> !MESSAGE Bundle
>> picked instead.
>> !MESSAGE Bundle
>> was not resolved.
>> !MESSAGE Bundle
>> picked instead.
>> !MESSAGE Bundle
>> not resolved.
>> !MESSAGE Bundle
>> picked instead.
>> !MESSAGE Bundle
>> not resolved.
>> !MESSAGE Bundle
>> was picked instead.
>> !MESSAGE Bundle
>> not resolved.
>> !MESSAGE Bundle
>> picked instead.
>> !MESSAGE Bundle
>> resolved.
>> !MESSAGE Bundle
>> instead.
>> was not resolved.
>> was picked instead.
>> !MESSAGE Bundle
>> resolved.
>> !MESSAGE Bundle
>> instead.
>> !MESSAGE Bundle
>> resolved.
>> !MESSAGE Bundle
>> instead.
>> was not resolved.
>> was picked instead.
>> !MESSAGE Bundle
>> not resolved.
>> !MESSAGE Bundle
>> instead.
>> !MESSAGE Bundle
>> resolved.
>> !MESSAGE Bundle
>> instead.
>> !MESSAGE Bundle
>> resolved.
>> !MESSAGE Bundle
>> instead.
>> !MESSAGE Bundle
>> not resolved.
>> !MESSAGE Bundle
>> instead.
>> !MESSAGE Bundle
>> resolved.
>> !MESSAGE Bundle
>> instead.
>> !MESSAGE Bundle
>> not resolved.
>> !MESSAGE Bundle
>> instead.
>> !MESSAGE Bundle
>> resolved.
>> !MESSAGE Bundle
>> instead.
>> was not resolved.
>> was picked instead.
>> was not resolved.
>> picked instead.
>> !MESSAGE Bundle
>> was not resolved.
>> !MESSAGE Bundle
>> was not resolved.
>> !MESSAGE Bundle
>> was not resolved.
>> !MESSAGE Bundle
>> not resolved.
>> !MESSAGE Bundle
>> was not resolved.
>> !MESSAGE Bundle
>> picked instead.
>> !MESSAGE Bundle
>> was not resolved.
>> !MESSAGE Bundle
>> picked instead.
>> was not resolved.
>> !MESSAGE Bundle
>> was not resolved.
>> !MESSAGE Bundle
>> picked instead.
>> !MESSAGE Bundle
>> was not resolved.
>> !MESSAGE Bundle
>> picked instead.
>> !MESSAGE Bundle
>> was not resolved.
>> !MESSAGE Bundle
>> picked instead.
>> was not resolved.
>> was picked instead.
>> was not resolved.
>> was picked instead.
>> was not resolved.
>> picked instead.
>> !MESSAGE Bundle
>> resolved.
>> !MESSAGE Bundle
>> instead.
>> !MESSAGE Bundle
>> not resolved.
>> !MESSAGE Bundle
>> instead.
>> !MESSAGE Bundle
>> not resolved.
>> !MESSAGE Bundle
>> instead.
>> !MESSAGE Bundle
>> not resolved.
>> !MESSAGE Bundle
>> instead.
>> was not resolved.
>> was picked instead.
>> !MESSAGE Bundle
>> not resolved.
>> !MESSAGE Bundle
>> picked instead.
>> !MESSAGE Bundle
>> resolved.
>> !MESSAGE Bundle
>> instead.
>> !MESSAGE Bundle
>> resolved.
>> !MESSAGE Bundle
>> instead.
>> !MESSAGE Bundle
>> was not resolved.
>> !MESSAGE Bundle
>> picked instead.
>> was not resolved.
>> was picked instead.
>> was not resolved.
>> was picked instead.
>> !MESSAGE Bundle
>> was not resolved.
>> !MESSAGE Bundle
>> picked instead.
>> was not resolved.
>> was picked instead.
>> !MESSAGE Bundle
>> was not resolved.
>> !MESSAGE Bundle
>> was picked instead.
>> !MESSAGE Bundle
>> not resolved.
>> !MESSAGE Bundle
>> instead.
>> was not resolved.
>> picked instead.
>> !MESSAGE Bundle
>> not resolved.
>> !MESSAGE Bundle
>> instead.
>> !MESSAGE Bundle
>> resolved.
>> !MESSAGE Bundle
>> instead.
>> !MESSAGE Bundle
>> was not resolved.
>> !MESSAGE Bundle
>> not resolved.
>> !MESSAGE Bundle
>> was not resolved.
>> !MESSAGE Bundle
>> not resolved.
>> !MESSAGE Bundle
>> was not resolved.
>> !MESSAGE Bundle
>> not resolved.
Current Time: Tue Jul 15 13:54:30 EDT 2025
Powered by FUDForum. Page generated in 0.05483 seconds
