need help on how to use the tptp for GUI testing [message #91657] |
Tue, 23 January 2007 20:46 |
Originally posted by: mjireal.yahoo.com
I am new to eclipse. Currently I'm trying to figure out how to use tptp
for gui testing. I download the tptp 4.3 runtime for windows. I don't
know how to use it with our eclipse based gui application. Would someone
help me?
Thanks.
Michelle
Re: need help on how to use the tptp for GUI testing [message #92452 is a reply to message #91759] |
Tue, 13 February 2007 22:03 |
Hi Liz,
Thank you for teach me how to use the AGR. I was working on other tasks
but now back to the eclipse project.
So far I followed the instruction from the doc and got to the point of
creating a test case, then I got errors as below. And I couldn't find
the Add button from the tab which I was asking to click on:
"Create a new test case: Switch to 'Test Cases' tab of the test suite >
Click on Add". Please help me.
Michelle
While loading class "org.eclipse.hyades.ui.HyadesUIImages", thread
"main" timed out waiting (5000ms) for thread "Worker-1" to finish
starting bundle "org.eclipse.hyades.ui". To avoid deadlock, thread
"main" is proceeding but "org.eclipse.hyades.ui.HyadesUIImages" may not
be fully initialized.
java.lang.Exception: Generated exception.
at
org.eclipse.core.runtime.internal.adaptor.EclipseLazyStarter .preFindLocalClass(EclipseLazyStarter.java:75)
at
org.eclipse.osgi.baseadaptor.loader.ClasspathManager.findLoc alClass(ClasspathManager.java:409)
at
org.eclipse.osgi.internal.baseadaptor.DefaultClassLoader.fin dLocalClass(DefaultClassLoader.java:188)
at
org.eclipse.osgi.framework.internal.core.BundleLoader.findLo calClass(BundleLoader.java:334)
at
org.eclipse.osgi.framework.internal.core.BundleLoader.findCl ass(BundleLoader.java:386)
at
org.eclipse.osgi.framework.internal.core.BundleLoader.findCl ass(BundleLoader.java:347)
at
org.eclipse.osgi.internal.baseadaptor.DefaultClassLoader.loa dClass(DefaultClassLoader.java:83)
at java.lang.ClassLoader.loadClassInternal(Unknown Source)
at org.eclipse.hyades.ui.HyadesUIPlugin$1.run(HyadesUIPlugin.ja va:114)
at org.eclipse.swt.widgets.RunnableLock.run(RunnableLock.java:3 5)
at
org.eclipse.swt.widgets.Synchronizer.runAsyncMessages(Synchr onizer.java:123)
at org.eclipse.swt.widgets.Display.runAsyncMessages(Display.jav a:3325)
at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java :2971)
at org.eclipse.ui.internal.Workbench.runEventLoop(Workbench.jav a:1914)
at org.eclipse.ui.internal.Workbench.runUI(Workbench.java:1878)
at
org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Work bench.java:419)
at org.eclipse.ui.internal.ide.IDEApplication.run(IDEApplicatio n.java:95)
at
org.eclipse.core.internal.runtime.PlatformActivator$1.run(Pl atformActivator.java:78)
at
org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher .runApplication(EclipseAppLauncher.java:92)
at
org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher .start(EclipseAppLauncher.java:68)
at
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:400)
at
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:177)
at org.eclipse.core.launcher.Main.invokeFramework(Main.java:336 )
at org.eclipse.core.launcher.Main.basicRun(Main.java:280)
at org.eclipse.core.launcher.Main.run(Main.java:977)
at org.eclipse.core.launcher.Main.main(Main.java:952)
Liz Dancy wrote:
> Hi Michelle,
> In order to use TPTP's Automated GUI Recorder (AGR) you need to download
> and install the AGR plug-in available on our download page under the
> Technology Preview section.
> Once that is completed, you may wish to review our online documentation
> on the AGR which includes examples of how to record and play back test
> cases. Please see:
> http://www.eclipse.org/tptp/test/documents/userguides/Intro- Auto-GUI-4-3-0.html.
> Let me know if you have any additional questions once you get started.
> Sincerely,
> Liz Dancy
> "Michelle" <mjireal@yahoo.com <mailto:mjireal@yahoo.com>> wrote in
> message news:ep5s69$2bf$1@utils.eclipse.org...
> > Hi,
> > help me?
> > Thanks.
> > Michelle
FUDForum. Page generated in 0.03725 seconds
