Home » Modeling » GMF (Graphical Modeling Framework) » how to create two linked element in a diagram related to a single element in the model
how to create two linked element in a diagram related to a single element in the model [message #8248] Mon, 07 August 2006 08:18 Go to next message
Hi all
I want to map the UML AssociationClass in my UML Class Diagram Editor. I
n the gmfmap I mapped the AssociationClass as a linkMapping; the link in
the diagram editor is correctly created. A class is also created because
the AssociationClass is a Class (that is mapped as a rectangle with
compartments). So I want to create a connection between the link and the
class: I'm able to do this using *note attachment* from the palette but
I would create this attachment programmatically.
Any idea/suggestions?
thanks
michele
| A |---------------| B |
| C |
Re: how to create two linked element in a diagram related to a single element in the model [message #33828 is a reply to message #8248] Wed, 30 August 2006 04:26 Go to previous message
Originally posted by: strommer.big.tuwien.ac.at
i have i similar problem. do you have already found a solution for your
problem?
Michele Puccio schrieb:
> Hi all
> thanks
> michele
> | C |
Previous Topic:doc and source for org.eclipse.gmf.runtime.diagram.ui.parts
Next Topic:To seperate out the code for the new diagram file creation and the GMF part
Current Time: Mon Jul 07 18:41:25 EDT 2025
Powered by FUDForum. Page generated in 0.03654 seconds
