Home » Modeling » GMF (Graphical Modeling Framework) » Final/Stable Release of GMF-sdk-2.0
Final/Stable Release of GMF-sdk-2.0 [message #91535] Thu, 11 January 2007 07:52 Go to next message
Originally posted by: biju_gopinathan.rediffmail.com
Hi friends,
Is there a final or stable release for GMF-sdk-2.0 ,if not is
there any information about when we can expect a final release of
GMF-sdk-2.0
regards biju
Re: Final/Stable Release of GMF-sdk-2.0 [message #91550 is a reply to message #91535] Thu, 11 January 2007 08:07 Go to previous messageGo to next message
Originally posted by: christian.daenekas.informatik.uni-oldenburg.de
Have a look here:
http://wiki.eclipse.org/index.php/GMF_Project_Plan#Release_m ilestones
Latest stable build is M4.
Greetings,
Christian
biju schrieb:
> Hi friends,
> GMF-sdk-2.0
> regards biju
Re: Final/Stable Release of GMF-sdk-2.0 [message #91578 is a reply to message #91550] Thu, 11 January 2007 08:30 Go to previous messageGo to next message
Hi Christian,
Thanks for your reply,
In the following link the status of the GMF-sdk-2.0M4 is shown as
[X] , so would it be a stable release?
http://download.eclipse.org/modeling/gmf/downloads/drops/S-2 .0M4-200701030300/index.php
Thanks again regards biju
Christian Dänekas wrote:
> Have a look here:
> Greetings,
> Christian
> biju schrieb:
>> Hi friends,
>> GMF-sdk-2.0
>> regards biju
Re: Final/Stable Release of GMF-sdk-2.0 [message #91591 is a reply to message #91578] Thu, 11 January 2007 09:15 Go to previous messageGo to next message
I´m not that deep into GMF to give you a advice on whats the test
failure is about. It is supposed to be the latest stable build, though.
Maybe someone more concerned with the development of GMF can tell you if
this failure would possibly affect you.
biju schrieb:
> Hi Christian,
>> Have a look here:
>> Greetings,
>> Christian
>> biju schrieb:
>>> Hi friends,
>>> GMF-sdk-2.0
>>> regards biju
Re: Final/Stable Release of GMF-sdk-2.0 [message #92260 is a reply to message #91578] Fri, 12 January 2007 14:19 Go to previous message
The [X] indicates a JUnit failure for this build.
The failure is caused by an issue with the adoption of EMF's latest release.
The issue is tracked here
https://bugs.eclipse.org/bugs/show_bug.cgi?id=168891 .
Since there is only one issue with a JUnit, we have marked this as our
"stable release" build for the M4 milestone.
Cheers...
Anthony
"biju" <biju_gopinathan@rediffmail.com> wrote in message
news:eo5e6j$ipf$1@utils.eclipse.org...
> Hi Christian,
> Christian D
Previous Topic:creating a image from a diagram file
Next Topic:Compile Errors After Upgrading to GMF2.0M4
Current Time: Fri Jul 25 00:45:09 EDT 2025
Powered by FUDForum. Page generated in 1.07117 seconds
