Home » Archived » Visual Editor (VE) » VE N20050516 problems with M7
VE N20050516 problems with M7 [message #91411] Tue, 17 May 2005 12:55 Go to next message
I'm unable to open a visual class with the new N20050516 for M7.
When I try to open the class, a message box appears with the following
message:
"Error trying to set new file into editor.
Reason: org.eclipse.ve.internal.java.core.BeanProxyAdapter".
I'm working over a clean Eclipse 3.1 M7 installation and a M6 workspace
(W2K).
Thanks in advance for your help,
Francesc Rosés
Re: VE N20050516 problems with M7 [message #91476 is a reply to message #91411] Tue, 17 May 2005 17:17 Go to previous messageGo to next message
Originally posted by: richkulp.us.NO_SPAM.ibm.com
There are problems with the Nightly build. It was a first pass and
mostly Swing/AWT works but SWT has problems.
Did you run eclipse.exe -clean first after you unzipped the driver? You
need to do that to pick up the new code.
Francesc Rosés wrote:
> Hello,
> message:
> (W2K).
> Francesc Rosés
Rich Kulp
Re: VE N20050516 problems with M7 [message #91505 is a reply to message #91476] Tue, 17 May 2005 20:08 Go to previous messageGo to next message
Rich,
I find similar problem when build from cvs
it work in runtime workbench, but 'create visual class' (swing application,
frame etc) doesn't work whe I build vep
reason : plugin org.eclipse.ve.jfc = build properties doesn't include
directory templates and i get 'null pointer error'
There are another files/directories non included in another plugins
regards
Haris Peco
>> Hello,
>> message:
>> (W2K).
>> Francesc Rosés
Re: VE N20050516 problems with M7 [message #91533 is a reply to message #91476] Tue, 17 May 2005 18:34 Go to previous messageGo to next message
Hello Rich,
Yes I run Eclipse.exe with -clean.
Francesc
Re: VE N20050516 problems with M7 [message #91547 is a reply to message #91533] Tue, 17 May 2005 18:42 Go to previous messageGo to next message
Oh, you said you were using an M6 workspace. You will also need to run
Project->Clean->Clean All Projects. There are some cached files laying
around from M6 that have changed and need to be recreated. See if that
helps.
> Hello Rich,
> Francesc
Rich Kulp
Re: VE N20050516 problems with M7 [message #91561 is a reply to message #91505] Tue, 17 May 2005 19:00 Go to previous messageGo to next message
Yeah we just found the templates problem this afternoon. We just created
a new nightly build that fixes that problem, N20050517.
snpe wrote:
> Rich,
Rich Kulp
Re: VE N20050516 problems with M7 [message #91575 is a reply to message #91561] Tue, 17 May 2005 21:37 Go to previous messageGo to next message
I see.Sorry.
I build from cvs and it work fine, but I have to build plugins
org.eclipse.jem.util - have problem with perfmsr.jar
org.eclipse.ve.jfc - return error when build with any another plugin
org.eclipse.ve.swt - like jfc
out of another plugin - I can set features and include all plugins
regards
> snpe wrote:
>> Rich,
>> application, frame etc) doesn't work whe I build vep
Re: VE N20050516 problems with M7 [message #91587 is a reply to message #91547] Wed, 18 May 2005 02:34 Go to previous messageGo to next message
Thanks, Rich. I cleaned the projects and I'm testing the new nightly build
(N20050517). It seems works fine.
I'll test it and I'll post here my comments.
Thanks again,
Francesc
Re: VE N20050516 problems with M7 [message #91659 is a reply to message #91575] Wed, 18 May 2005 11:42 Go to previous messageGo to next message
How are you building? It works fine if you check out through Eclipse and
let the standard incremental editor compile them.
If you are trying to build this outside of Eclipse:
For jem.util: Create a dummy plugin called org.eclipse.perfmsr.core and
put the perfmsr.jar found in the org.eclipse.jem.util checked CVS files.
This is a stripped down only for compile against version of the jar. It
will not run and it should not be in the runtime. It should only be in
the build path.
I don't understand the other other problems. You weren't specific.
Rich Kulp
Re: VE N20050516 problems with M7 [message #91673 is a reply to message #91659] Wed, 18 May 2005 14:03 Go to previous message
I checkout ve manual with (linux)
cvs co ve-all
I import existing projects (all plugins) in eclipse.
I try first export existing feature and it doesn't work
I make simple feature project and add all ve-plugins
export this feature and get logs.zip with error in 3 plugins
I the export this 3 plugins separately (one by one) and it compile fine
(mystery)
all is fine in runtime workbench (always), but I have error when deploy
plugins (sometimes) because exits error in build.properties
> the build path.
Re: VE N20050516 problems with M7 [message #607789 is a reply to message #91411] Tue, 17 May 2005 17:17 Go to previous message
> Hello,
> message:
> (W2K).
> Francesc Rosés
Rich Kulp
Re: VE N20050516 problems with M7 [message #607791 is a reply to message #91476] Tue, 17 May 2005 20:08 Go to previous message
Rich,
regards
Haris Peco
>> Hello,
>> message:
>> (W2K).
>> Francesc Rosés
Re: VE N20050516 problems with M7 [message #607793 is a reply to message #91476] Tue, 17 May 2005 18:34 Go to previous message
Hello Rich,
Francesc
Re: VE N20050516 problems with M7 [message #607794 is a reply to message #91533] Tue, 17 May 2005 18:42 Go to previous message
helps.
> Hello Rich,
> Francesc
Rich Kulp
Re: VE N20050516 problems with M7 [message #607795 is a reply to message #91505] Tue, 17 May 2005 19:00 Go to previous message
snpe wrote:
> Rich,
Rich Kulp
Re: VE N20050516 problems with M7 [message #607796 is a reply to message #91561] Tue, 17 May 2005 21:37 Go to previous message
I see.Sorry.
regards
> snpe wrote:
>> Rich,
Re: VE N20050516 problems with M7 [message #607797 is a reply to message #91547] Wed, 18 May 2005 02:34 Go to previous message
Thanks again,
Francesc
Re: VE N20050516 problems with M7 [message #607802 is a reply to message #91575] Wed, 18 May 2005 11:42 Go to previous message
the build path.
Rich Kulp
Re: VE N20050516 problems with M7 [message #607803 is a reply to message #91659] Wed, 18 May 2005 14:03 Go to previous message
cvs co ve-all
(mystery)
> the build path.
Previous Topic:Class cast exception on customizer OK click
Next Topic:VE crashes when loading Table
Current Time: Wed Jul 09 08:57:40 EDT 2025
Powered by FUDForum. Page generated in 0.33031 seconds
