Eclipse is OSGi Based, but requires reboots...? [message #91292] |
Thu, 28 June 2007 02:36 |
Originally posted by: carlushenry.gmail.com
One of the attractions that I have to OSGi is the concept that you do
not have to restart an application if you want to modify it. I have
done this while playing with OSGi. However, if Eclipse is based on
OSGi, then why does it require a reboot when you add a new plugin / bundle?
Carlus
Re: Eclipse is OSGi Based, but requires reboots...? [message #91306 is a reply to message #91292] |
Thu, 28 June 2007 05:25 |
Originally posted by: alex_blewitt.yahoo.com
It doesn't need it; there's an "apply changes" that you can do to install it dynamically. However, historically (i.e. before 3.0) it's not been possible to do that. Some plugins also don't work because they're not set up to be dynamic; the 'New' wizard was one of them IIRC.
Summary: it can work, it just doesn't always. That's why they still have the 'restart', and it's the default. YMMV.
Alex.
FUDForum. Page generated in 0.02765 seconds
