Home » Newcomers » Newcomers » Setting eclipse.vmargs in config.ini?
Setting eclipse.vmargs in config.ini? [message #8206] Wed, 19 January 2005 11:20 Go to next message
Originally posted by: eric.brenner.gd-ais.com
Is it possible to set the eclipse.vmargs value in the config.ini file with
Eclipse versions 3.0+ ? I am trying to "hardwire" a max heap size of 512M
by adding the following line to the config.ini file:
eclipse.vmargs=-Xmx512M
When I go to the Configuration Details page after Eclipse loads, it
doesn't show up.
Re: Setting eclipse.vmargs in config.ini? [message #8460 is a reply to message #8206] Wed, 19 January 2005 19:19 Go to previous messageGo to next message
Originally posted by: Chris_Laffra.ca.ibm.com
you can pass it to eclipse.exe
eclipse ....... -vmArgs -Xmx512M
Chris Laffra, http://eclipsefaq.org
"Eric Brenner" <eric.brenner@gd-ais.com> wrote in message
news:csm1d5$c9m$1@www.eclipse.org...
> doesn't show up.
Re: Setting eclipse.vmargs in config.ini? [message #9822 is a reply to message #8460] Thu, 20 January 2005 08:22 Go to previous message
Yes, I understand this. But the issue is, is that when I distribute what
I'm developing, I don't want to make the user create a shortcut each time
with the extra parameters. I'd rather be able to tell Eclipse through the
config.ini file what the -Xms and -Xmx values are.
Previous Topic:how configure Ant
Next Topic:Open a method via Package Explorer
Current Time: Tue Jul 08 01:45:54 EDT 2025
Powered by FUDForum. Page generated in 0.34925 seconds
