[EMF Compare] StructureViewer and LabelProvider [message #91153] |
Fri, 20 July 2007 08:30  |
when we compare our model files, the images in the structure viewer are very
small and the label provider doesn`t uses the label features for our model
elements that we have defined in our genmodel. Is there a possibillity to
extend the ItemProviders of the DiffModel to show our images and labels?
Thanks in advance,
Sascha
Re: [EMF Compare] StructureViewer and LabelProvider [message #91169 is a reply to message #91153] |
Fri, 20 July 2007 09:41  |
--------------080805080804090402020309
You could get this behavior by implementing your own ItemProviders
extending those you can find in org.eclipse.emf.compare.diff.provider
and overriding their getImage(Object) and getText(Object) methods.
Once done, you'll have to extends
org.eclipse.emf.compare.diff.provider.DiffItemProviderAdapte rFactory and
override all the create???Adapter you want to replace by your own.
The last step for the StructureViewer's icon replacement will then be to
add "org.eclipse.emf.edit.itemProviderAdapterFactories" to your
contribution plug-in's extension points and adding to it (in your
plugin.xml since it doesn't seem to be possible from the GUI) a child of
the form :
<factory
uri = "http://www.eclipse.org/emf/compare/diff/1.0"
class = %your adapter factory%
supportedTypes =
"org.eclipse.emf.edit.provider.IEditingDomainItemProvider
org.eclipse.emf.edit.provider.IStructuredItemContentProvider
org.eclipse.emf.edit.provider.ITreeItemContentProvider
org.eclipse.emf.edit.provider.IItemLabelProvider
org.eclipse.emf.edit.provider.IItemPropertySource" />
Laurent Goubet
Obeo
Sascha Theves a
Re: [EMF Compare] StructureViewer and LabelProvider [message #608838 is a reply to message #91153] |
the form :
<factory
supportedTypes =
Laurent Goubet
Obeo
Sascha Theves a
FUDForum. Page generated in 0.03385 seconds
