Home » Archived » BPMN Modeler » BPMN Meta Model
BPMN Meta Model [message #8196] Mon, 09 February 2009 06:15 Go to next message
I am looking for BPMN Meta Model. From where can I get.
Ecore file or EMOF or CMOF form of BPMN Meta model should be fine with me.
I checked in OMG site as well I could not find it there.
Can you please help me in locating this.
Thanks and Regards,
Asha.
Re: BPMN Meta Model [message #8227 is a reply to message #8196] Mon, 09 February 2009 08:19 Go to previous messageGo to next message
Originally posted by: atoulme.intalio.com
Our model is available here:
http://dev.eclipse.org/svnroot/stp/org.eclipse.stp.bpmn-mode ler/org.eclipse.stp.bpmn/trunk/org.eclipse.stp.bpmn/model/
Note that it is by no means an OMG approved metamodel. BPMN 2 is still
being discussed and they haven't shared a definitive meta model just yet.
Antoine
Asha wrote:
> Thanks and Regards,
> Asha.
Re: BPMN Meta Model [message #8507 is a reply to message #8227] Sat, 14 February 2009 13:37 Go to previous messageGo to next message
Hi Antoine,
if it's possible I would like to use your metamodel. I want to draw with
your tool a diagram and use the *.bpmn file to import it in another
project. I don't need all the graphical description of the layout and the
representation with gmf. All I need is somehow the information about the
bpmn-tasks, events, gateways and how they are connected beetween each
other.
Is the *.bpmn_diagram file only for the description of the layout?
How could I import out of the *.bpmn file and the ecore-files in the
model-directory a BPMN-diagram? Is there somewhere in your sourcecode
already a "load"-function or something else? I think I need only the
bpmn.ecore, right?
thx Felix
Re: BPMN Meta Model [message #8537 is a reply to message #8507] Sat, 14 February 2009 17:03 Go to previous messageGo to next message
Felix wrote:
> Hi Antoine,
> the representation with gmf. All I need is somehow the information about
> the bpmn-tasks, events, gateways and how they are connected beetween
> each other.
Yes.
> bpmn.ecore, right?
I'm not sure what you mean here. The bpmn_diagram may be initialized
from the bpmn diagram through a gmf action.
> thx Felix
Re: BPMN Meta Model [message #8564 is a reply to message #8537] Mon, 16 February 2009 04:28 Go to previous messageGo to next message
At the moment I'm importing the bpmn-file with an ResourceSet. Therefor I
try to understand your model and create all the object manual, for example
for (EObject object :resource.getContents())
if (BpmnDiagram.class.isInstance(object))
diagrams.add((BpmnDiagram)object);
Is there somewhere in your code a method which instantiate automatically
all the objects definied in the bpmn-file?
ciao Felix
Re: BPMN Meta Model [message #9256 is a reply to message #8564] Mon, 16 February 2009 06:51 Go to previous message
> I try to understand your model and create all the object manual, for
> example
Sorry, but I don't understand what you are trying to achieve there, not
sure it matters if I do.
Yes, of course, the BpmnFactory is there for that. That's how EMF loads
models in general.
> ciao Felix
Previous Topic:Intalio <=x=> OMG
Next Topic:Removing Palette Items Tutorial Help
Current Time: Sun Jul 06 12:06:04 EDT 2025
Powered by FUDForum. Page generated in 0.03918 seconds
