Home » Newcomers » Newcomers » JavaDoc for 1.5 syntax
JavaDoc for 1.5 syntax [message #8175] Wed, 19 January 2005 11:12 Go to next message
Originally posted by: james.keirstead.ouce.ox.ac.uk
I'm running Eclipse 3.1 M4 and it's working great with all the new Java
1.5 generics, for loops etc. The only problem is that the javadoc
generation doesn't like this syntax and crashes. I tried adding -source
1.5 to the end of the javadoc.exe command line but Eclipse won't accept it.
Any ideas?
James Keirstead
Re: JavaDoc for 1.5 syntax [message #217667 is a reply to message #8175] Sun, 24 June 2007 09:18 Go to previous message
James,
What in particular doesn't the Javadoc like? Note that references to
methods must use the erased signature. I.e., * @see List#add(Object)
not @see List#add(E). It's useful to take advantage of JDTs Javadoc
checking facilities by using
Window->Preferences->Java->Compiler->Javadoc to turn on warnings/errors
that will help you fix the problems before javadoc generation croaks.
James Keirstead wrote:
> Java 1.5 generics, for loops etc. The only problem is that the
> javadoc generation doesn't like this syntax and crashes. I tried
> adding -source 1.5 to the end of the javadoc.exe command line but
> Any ideas?
> Thanks
> James Keirstead
Previous Topic:Enterprise Application Project help
Next Topic:Eclipse and IBM WSDK
Current Time: Mon Sep 01 01:05:19 EDT 2025
Powered by FUDForum. Page generated in 0.10308 seconds
