Home » Newcomers » Newcomers » How do you delete a project?
How do you delete a project? [message #90815] Sat, 30 July 2005 18:43 Go to next message
Originally posted by: david.windward.net
The only way I found was to go to the directory C:\Documents and
Settings\dave\workspace\.metadata\.plugins\org.eclipse.core. resources\.projects,
delete the subdirectory for that project, then go to File, Refresh.
It seems to me there must be an easier way?????
thanks - dave
david@at-at-at>@windward.dot.dot.net
Windward Reports -- http://www.WindwardReports.com
DefendTek -- http://www.DefendTek.com
Page 2 Stage -- http://www.Page2Stage.com
Enemy Nations -- http://www.EnemyNations.com
me -- http://dave.thielen.com
Barbie Science Fair -- http://www.BarbieScienceFair.info
Hillary Clinton -- http://www.HillaryIn2004.org
(yes I have lots of links)
Re: How do you delete a project? [message #90846 is a reply to message #90815] Sat, 30 July 2005 19:22 Go to previous message
> thanks - dave
There is..
- Right click project
- Select Delete
- Select either..
1 - Select 'Do not delete contents'. This will drop project from
loading into workspace when you load the workspace.
2 - Select 'Do delete contents' under blabblabblab. This will
physically delete the project from the workspace AND do all of the cleanup.
I think you want the second option.
Thanks in Advance...
IchBin, Pocono Lake, Pa, USA http://weconsultants.servebeer.com
____________________________________________________________ ______________
' If there is one, Knowledge is the "Fountain of Youth"'
-William E. Taylor, Regular Guy (1952-)
Previous Topic:CVS without a server
Next Topic:Can not find the plugin
Current Time: Sat Jul 26 06:01:12 EDT 2025
Powered by FUDForum. Page generated in 0.07014 seconds
