COSMOS 0.4 is now available [message #8174] |
Thu, 26 July 2007 10:13  |
Originally posted by: david_whiteman.us.ibm.com
COSMOS 0.4 is NOW available (version listed is 1.0.0-200706281537)
COSMOS 0.4 provides the following features:
* Tools that support systems management data conforming to the Service
Modeling Language (SML) and SML-Interchange Format (SML-IF) standards
(http://www.w3.org/Submission/2007/01/), including SML and SML-IF
document validation, SML-IF editing, import of SML-IF documents and
export to SML-IF documents
* Example data center described in SML format
* Standard APIs for accessing COSMOS data from heterogeneous clients
* Data collectors that gather data from Common Base Event (CBE) logs,
JMX, and WSDM Event Format (WEF) sources
* Preset reports to visualize event and statistical data
* Data store to persist statistical information based on the standard
SDMX specification (http://www.sdmx.org/)
* Relational data store for the persistence of event information and
* Web-based viewer composed of Web 2.0 gadgets to thoroughly examine
data from SML-IF documents
* Extension points to create complementary visualizations in the form of
Web 2.0 gadgets and BIRT reports
Download COSMOS 0.4 and reap the benefits:
http://eclipse.org/cosmos/downloads/
As always, we welcome your participation and feedback via this
newsgroup, and also hope you will actively "kick the tires" to report
bugs and feature requests via Bugzilla.
The COSMOS Team
Re: COSMOS 0.4 is now available [message #8428 is a reply to message #8238] |
Fri, 03 August 2007 12:34  |
Thanks for the feedback, Michael. Version numbering can be tricky.
After a project has passed the 1.0 version point, the milestones are
named for the release they are approaching. However, the guidelines are
different and less clear before the 1.0 point.
We have decided on the following convention, for better or for worse:
before we get to release 1.0, we will name the releases 0.i, where "i"
is the associated iteration number. Therefore, in this case, we can use
i4, Milestone 1, and Release 0.4 interchangeably. We do need to update
the download page to make it more obvious which download link
corresponds to release 0.4. In the first post in this thread, "version
listed is 1.0.0-200706281537" was supposed to indicate which link to
choose, but if we had it better marked on the page itself, that would
help further eliminate the ambiguity.
David
Re: COSMOS 0.4 is now available [message #569801 is a reply to message #8174] |
Thu, 02 August 2007 09:42  |
"David Whiteman" <david_whiteman@us.ibm.com> wrote in message
news:f8aa5i$vdf$1@build.eclipse.org...
Just a very general remark: when I clicked the above link I was confused
by coming to a download page that offered me a 1.0.0 version while this
append just spoke about a version 0.4 only. Only in the comment column I
discovered the remarks "i4 stable build" or "i3 stable build".
To avoid such confusion and stay with the usual eclipse parlour, it
might be helpful to name (and then speak about) such versions as
"version x.y.zMn[-optionally-with-date]" (where n is the milestone
number), i.e. here e.g.: v1.0.0M4. Seeing such a file or download
everybody being mildly familiar with eclipse habits is immediately
aware, that this is a beta or preview version and not the final v1.0.0.
Just my 2 cents of wisdom...
Michael
Re: COSMOS 0.4 is now available [message #570031 is a reply to message #8238] |
David
FUDForum. Page generated in 0.03716 seconds
