Home » Modeling » M2T (model-to-text transformation) » Using JET2 <c:stringTokens
Using JET2 <c:stringTokens [message #8172] Thu, 29 March 2007 01:11 Go to next message
Originally posted by: evaandoli.dodo.com.au
I struggling to use the function c:stringTokens as I can't seem to plugin a
string rather than a fixed string.
The rest is just cut and paste from the reference guide.
I just put in the ="<c:get select=$action/@expression/>"
Any help would be great.
<c:stringTokens string="<c:get select=$action/@expression/>"
name="currentString" delimitedBy=" ">
value: <c:get select="$currentString/@value"/>
index: <c:get select="$currentString/@index"/>
delimiter: <c:get select="$currentString/@delimiter"/>
first: <c:get select="$currentString/@first"/>
last: <c:get select="$currentString/@last"/>
</c:stringTokens>
Re: Using JET2 <c:stringTokens [message #8204 is a reply to message #8172] Thu, 29 March 2007 02:21 Go to previous messageGo to next message
To add a bit. I also try using a dymanic XPath espression but with no
luck:-
<c:stringTokens string="{$action/@expression}" name="currentString"
delimitedBy=" ">
"Stu" <evaandoli@dodo.com.au> wrote in message
news:eufhr0$5d7$1@build.eclipse.org...
> a string rather than a fixed string.
> </c:stringTokens>
Re: Using JET2 <c:stringTokens [message #8234 is a reply to message #8204] Thu, 29 March 2007 08:23 Go to previous message
Stu:
Unfortunately, you have found a bug:
https://bugs.eclipse.org/bugs/show_bug.cgi?id=179973
I have no work around at this point.
Paul
news:eufltj$7ft$1@build.eclipse.org...
> luck:-
> delimitedBy=" ">
>> </c:stringTokens>
Previous Topic:concatenation in JET2 in get default function
Next Topic:Re: Help with Help "Loading... please wait"
Current Time: Wed Jun 04 13:02:21 EDT 2025
Powered by FUDForum. Page generated in 0.02651 seconds
