Re: Problems with XML and VE [message #90881 is a reply to message #90778] |
Thu, 12 May 2005 14:53 |
That has nothing to do with the VE. I don't know what org.eclipse.wst
component is, but they are doing something that conflicts with the VE.
You will need to go to them for the fix.
Maja wrote:
> Hi!
> I have Eclipse 3.0.2 and VE 1.0.2.1 installed.
> Now I tried to open .xml and .dtd files.
> I did not work and I got some errors. I attached the .log file.
> What can I do to fix this error?
> Maja
> Error Mai 12, 2005 10:16:10.681 Problems occurred when invoking code
> from plug-in: "org.eclipse.core.runtime".
> An error has occurred when initializing the input for the the editor's
> source page. Original Error: org.eclipse.ui.PartInitException: Editor
> could not be initialized.
> at
> org.eclipse.wst.xml.internal.ui.XMLMultiPageEditorPart.addSo urcePage(XMLMultiPageEditorPart.java:185)
Rich Kulp
Re: Problems with XML and VE [message #91463 is a reply to message #91387] |
Tue, 17 May 2005 21:14 |
WTP M3 works on Eclipse 3.1M5a. VE 1.0.2.1 doesn't work on that version
of Eclipse. VE 1.1 driver I20050318 works on 3.1M5a. But I don't know if
the JEM out of I20050318 is compatible with WTP M3. You can give it a
try, but be aware it may not work and you might need to reinstall the
WTP M3 without VE to get back to something working.
There is an WTP M4 available that works on Eclipse M6 and that has a JEM
that is compatible with M6, in fact you could use the I20050415 driver
of VE with WTP M4 on Eclipse 3.1M6. Those are all compatible with each
other.
Rich Kulp
Re: Problems with XML and VE [message #607748 is a reply to message #90778] |
Maja wrote:
> Hi!
> Maja
> at
Rich Kulp
Re: Problems with XML and VE [message #607788 is a reply to message #91387] |
other.
Rich Kulp
FUDForum. Page generated in 0.04670 seconds
