TPTP automation errors [message #90751] |
Tue, 02 January 2007 14:53  |
I'm trying to automate my TPTP environment using the supplied Ant tasks and
I have yet to get anything beyond the most trivial of examples working. I
am interested to know if anyone has been able to accomplish a decent level
of automation and I'm all ears and would greatly appreciate any pointers
anyone may have.
Here is my basic scenario:
Parameters:
tptp.automation.eclipse=C:/Development/Tools/eclipse
tptp.test.workspace=C:/Development/Projects/Workspace
tptp.test.project=Test
Ant target:
<target name="run_tests">
<tptp:test deployment="resources/TPTP/deployments/Solaris.deploy">
<fileset dir="C:/Development/Projects/Workspace/Test"
includes="**/TestManager.testsuite"/>
</tptp:test>
</target>
All resources exist in the specified location(s). I can run my tests
successfully from the IDE.
I get the following error using this configuration:
org.eclipse.emf.ecore.resource.impl.ResourceSetImpl$1$Diagno sticWrappedException:
org.eclipse.core.internal.resources.ResourceException: Resource
/Test/Development/Projects/Workspace/Test/resources/TPTP/dep loyments/Solaris.deploy
does not exist.
org.eclipse.emf.ecore.resource.impl.ResourceSetImpl.handleDe mandLoadException(ResourceSetImpl.java:307)
It looks like the project name is prepended to the path to the deployment
I'm trying to utilize but I don't know why.
Using a full path to the deployment resource does not work, either.
For what it's worth, I get the same type of ResourceException should I try
to use the default deployment but explicitly specify the test suite I want
to run. The only manner in which I have been able to get out of the
starting blocks is to use a fileset to discover the test suite resource(s).
To try to work around the issue(s) I saved the launch configuration and
tried that approach but ran into another wall. Below is the ant target and
subsequent exception from that effort.
<tptp:test
configuration=" C:\Development\Projects\Workspace\Test\resources\TPTP\Proces sManagerTests.launch "/>
</target>
org.eclipse.hyades.test.core.services.AbstractTestExecutionS ervice.initialize(AbstractTestExecutionService.java:556)
This error is the same error I get when I don't specify a test suite. Why
should I need to specify a test suite when I'm specifying a configuration?
Doesn't a launch configuration contain everything it needs? Internally, the
..launch file has a .testsuite file mapped to key so that seems redundant to
me. If I do specify a test suite as an attribute to the tptp:test task, I
run into the same problem I was having with the .deploy resource -- the item
cannot be found.
Another issue is that tptp.test.project is documented as being optional but
I have yet to have found a configuration combination that allows for the
omission of this parameter from either the environment or as an attribute in
the tptp:test task.
org.eclipse.hyades.automation.server.AbstractProjectSensitiv eService.refreshProject(AbstractProjectSensitiveService.java :99)
Any suggestions are welcome.
Jonathan
Re: TPTP automation errors [message #103859 is a reply to message #91014] |
Mon, 09 July 2007 13:04  |
Hi Johnathon and Ravi,
Joe Tommey from the Test Project has said that these issues have been
fixed in 4.4 with the exception of this one:
> >> and subsequent exception from that effort.
> >> <tptp:test
> >> </target>
> >> java.lang.NullPointerException
> >> at
> >> Why should I need to specify a test suite when I'm specifying a
> >> configuration? Doesn't a launch configuration contain everything it
> >> needs? Internally, the .launch file has a .testsuite file mapped to key
> >> so that seems redundant to me. If I do specify a test suite as an
> >> attribute to the tptp:test task, I run into the same problem I was
> >> having
> >> with the .deploy resource -- the item cannot be found.
This issue is covered by the following 4.4.1 defect (a patch file is already
attached.) https://bugs.eclipse.org/bugs/show_bug.cgi?id=194212.
You can move up to the latest TPTP release here:
http://www.eclipse.org/tptp/home/downloads/?ver=4.4.0
Paul
"Jonathan Brown" <jonathan_w_brown@hotmail.com> wrote in message
news:eo097l$9ar$1@utils.eclipse.org...
> The first one doesn't seem pertinent to me but the second bug you pointed
> out could be related.
> Also, I came across this bug report that is definitely the same issue:
> https://bugs.eclipse.org/bugs/show_bug.cgi?id=146901
> I think the same underlying flaw is also impacting the deployment
> parameter.
> "Ravi Roy" <ravi.aroy@gmail.com> wrote in message
> news:enr1i5$nf8$1@utils.eclipse.org...
>> Two bugs reports / discussions are worth looking, I believe :
>> https://bugs.eclipse.org/bugs/show_bug.cgi?id=163387
>> https://bugs.eclipse.org/bugs/show_bug.cgi?id=146539
>> news:ened8k$734$1@utils.eclipse.org...
>>> and I have yet to get anything beyond the most trivial of examples
>>> working. I am interested to know if anyone has been able to accomplish
>>> a decent level of automation and I'm all ears and would greatly
>>> appreciate any pointers anyone may have.
>>> Parameters:
>>> Ant target:
>>> </tptp:test>
>>> </target>
>>> does not exist.
>>> at
>>> deployment I'm trying to utilize but I don't know why.
>>> try to use the default deployment but explicitly specify the test suite
>>> I want to run. The only manner in which I have been able to get out of
>>> the starting blocks is to use a fileset to discover the test suite
>>> resource(s).
>>> <tptp:test
>>> </target>
>>> at
>>> having with the .deploy resource -- the item cannot be found.
>>> but I have yet to have found a configuration combination that allows for
>>> the omission of this parameter from either the environment or as an
>>> attribute in the tptp:test task.
>>> at
>>> Thanks,
>>> Jonathan
FUDForum. Page generated in 0.05826 seconds
