Home » Language IDEs » ServerTools (WTP) » I20050407
I20050407 [message #90671] Thu, 07 April 2005 13:04 Go to next message
I'm still a little unclear on the release process. What distinguishes an
integration build from a nightly build?
Todays integration build on M6 has errors, but then I don't recall ever
seeing the green checkmarks until the milestone builds became available.
If I'm looking for a more recent build than M3 , do I keep looking at
nightly builds until I see green checkmarks, or do I wait for another
integration build? Will it come on a fixed schedule, or do you create new
integration builds until there are no errors?
Thanks!
- Richard
Re: I20050407 [message #90908 is a reply to message #90671] Thu, 07 April 2005 23:14 Go to previous messageGo to next message
On Thu, 7 Apr 2005 17:04:32 +0000 (UTC), Richard Rodseth <rrodseth@mac.com> wrote:
> Thanks!
> - Richard
I-builds are due every Thursday. Discussion of status and readiness is conducted on wtp-dev.
For example, we are re-doing the 4/7 I-build now.
Nightly builds are seldom suitable for use. I-builds are intended to be usable as
development targets. Are goal is all green check marks, but sometimes declared
usable even if not ... unfortunately, for now, the only way to know is to follow
wtp-dev (there's even been much recent discussion there on changing this procedure :)
Re: I20050407 [message #91489 is a reply to message #90671] Mon, 11 April 2005 23:23 Go to previous message
The recents IBuilds are all useable even though they have red X's. The
red X is due to failing JUnits tests. We always check the sanity of a
IBuild before declaring it. Moving forward you should see red X's go
away green tick marks on integration builds as we are in the process of
making sure all JUnits tests pass too for integration builds. If you see
red X then can make sure by clicking on the red X to see if there are
any compile errors and if the red X is just because of failnig JUnits.
You are better off picking up integration builds rather than nightly
builds as they are sanity checked
- Vijay
> new integration builds until there are no errors?
> Thanks!
> - Richard
Previous Topic:NoSuchMethodError when opening J2EE perspective
Next Topic:J2EE Web Project: Where have they been gone?
Current Time: Sat Aug 30 22:30:52 EDT 2025
Powered by FUDForum. Page generated in 0.03518 seconds
