Home » Archived » M2M (model-to-model transformation) » [ATL] retrieve index of an element in a collection
[ATL] retrieve index of an element in a collection [message #90617] |
Fri, 26 September 2008 11:34  |
Originally posted by: matteo.risoldi.unige.ch
I have a collection of Strings (created by splitting a String). With
these, I need to create a collection of elements. However, the elements
I create must be characterized by a number, specifying their order.
Example:
The collection of Strings is :
Sequence{'p1:int','p2:int','p3:bool}
with this collection I do:
Sequence{'p1:int', 'p2:int', 'p3:bool'} -> collect(p | thisModule.
myRule(p))
lazy rule myRule{
from
pdefinition : String
to
ti : DestMM!T (
name <- pdefinition,
index <- .......
what could I do to be able to put in place of the dots an integer
saying in what position of the collection that particular string was?
So that it would be 1 for 'p1:int', 2 for 'p2:int' etcetera. I can't
find an obvious way in the collect command to access the current
position of the iteration. I'd like some way I could pass an integer
parameter to myRule, and use it to give a value to index.
Does anybody have a suggestion?
Thank you in advance.
Matteo
Re: [ATL] retrieve index of an element in a collection [message #90633 is a reply to message #90617] |
Mon, 29 September 2008 04:22   |
Originally posted by: mddfabro.ilog.fr
one solution is to use called rules, which are rules that are called
with parameters.
Your code could be rewritten in the following way:
let seq : Sequence(String) = Sequence{'p1:int', 'p2:int', 'p3:bool'} in
collect(p | thisModule.myRule(p, seq->indexOf(p) ))
rule myRule (pdefinition : String, aIndex : Integer){
to
ti : DestMM!T (
index <- aIndex
do {
ti; -- this is necessary in order to return the new model element
Marcos.
Matteo Risoldi wrote:
> Hello,
> Example:
> myRule(p))
> lazy rule myRule{
> from
> to
> ti : DestMM!T (
> index <- .......
> what could I do to be able to put in place of the dots an integer saying
> in what position of the collection that particular string was? So that
> it would be 1 for 'p1:int', 2 for 'p2:int' etcetera. I can't find an
> obvious way in the collect command to access the current position of the
> iteration. I'd like some way I could pass an integer parameter to
> Matteo
Re: [ATL] retrieve index of an element in a collection [message #90663 is a reply to message #90633] |
Mon, 29 September 2008 05:42  |
great, that works perfectly (I might just add that one needs to put
"seq ->" just after the "in" or you get a "no viable alternative"
error).
Thank you very much!
Matteo
On 2008-09-29 10:22:46 +0200, Marcos Didonet Del Fabro <mddfabro@ilog.fr> said:
> Hello,
> with parameters.
> to
> ti : DestMM!T (
> index <- aIndex
> do {
> Marcos.
>> Hello,
>> Example:
>> thisModule. myRule(p))
>> lazy rule myRule{
>> from
>> to ti : DestMM!T (
>> index <- ....... )
>> Matteo
Current Time: Mon Jul 21 20:07:05 EDT 2025
Powered by FUDForum. Page generated in 0.03704 seconds
