Home » Archived » Memory Analyzer (MAT) » MAT + DTFJ Crash on re-opening extracted zip
MAT + DTFJ Crash on re-opening extracted zip [message #8152] Fri, 12 December 2008 14:10 Go to next message
--------------070100020301070301060608
WinXP; IBM JVM as below:
java version "1.5.0"
Java(TM) 2 Runtime Environment, Standard Edition (build
pwi32dev-20070511 (SR5))
IBM J9 VM (build 2.3, J2RE 1.5.0 IBM J9 2.3 Windows XP x86-32
j9vmwi3223-20070426 (JIT enabled)
J9VM - 20070420_12448_lHdSMR
JIT - 20070419_1806_r8
GC - 200704_19)
JCL - 20070511
I created a jextract'ed zip; opened it, all fine (Eclipse 3.3). Now,
from Eclipse 3.4.1, I try to open the very same jextract'ed zip, and get
the error in the attached log-file. Any clues?
-Paul
name="MatCrash.log"
Content-Disposition: inline;
filename="MatCrash.log"
!SESSION 2008-12-12 12:06:29.302 -----------------------------------------------
eclipse.buildId=M20080911-1700
java.fullversion=J2RE 1.6.0 IBM J9 2.4 Windows XP x86-32 jvmwi3260-20071121_15015 (JIT enabled)
J9VM - 20071121_015015_lHdSMR
JIT - r9_20071121_1330
GC - 20071031_AA
Command-line arguments: -os win32 -ws win32 -arch x86
!ENTRY org.eclipse.help 4 0 2008-12-12 12:07:05.209
!MESSAGE Error reading help table of contents file /"org.eclipse.imp.metatooling/doc/toc.xml" (skipping file)
!STACK 0
java.io.FileNotFoundException
at org.eclipse.help.internal.toc.TocFileParser.parse(TocFilePar ser.java:45)
at org.eclipse.help.internal.toc.TocFileProvider.getTocContribu tions(TocFileProvider.java:45)
at org.eclipse.help.internal.toc.TocManager.getAndCacheTocContr ibutions(TocManager.java:205)
at org.eclipse.help.internal.toc.TocManager.getTocContributions ForToc(TocManager.java:194)
at org.eclipse.help.internal.toc.TocManager.getRootTocContribut ions(TocManager.java:296)
at org.eclipse.help.internal.toc.TocManager.getTocs(TocManager. java:67)
at org.eclipse.help.internal.toc.TocManager.getTopic(TocManager .java:118)
at org.eclipse.help.internal.toc.TocManager.getTopicPath(TocMan ager.java:133)
at org.eclipse.help.internal.webapp.data.UrlUtil.getTopicPath(U rlUtil.java:177)
at org.eclipse.help.internal.webapp.servlet.BreadcrumbsFilter.f ilter(BreadcrumbsFilter.java:68)
at org.eclipse.help.internal.webapp.servlet.EclipseConnector.tr ansfer(EclipseConnector.java:161)
at org.eclipse.help.internal.webapp.servlet.ContentServlet.doGe t(ContentServlet.java:42)
at javax.servlet.http.HttpServlet.service(HttpServlet.java:596)
at javax.servlet.http.HttpServlet.service(HttpServlet.java:689)
at org.eclipse.equinox.http.registry.internal.ServletManager$Se rvletWrapper.service(ServletManager.java:180)
at org.eclipse.equinox.http.servlet.internal.ServletRegistratio n.handleRequest(ServletRegistration.java:90)
at org.eclipse.equinox.http.servlet.internal.ProxyServlet.proce ssAlias(ProxyServlet.java:111)
at org.eclipse.equinox.http.servlet.internal.ProxyServlet.servi ce(ProxyServlet.java:67)
at org.eclipse.equinox.http.jetty.internal.HttpServerManager$In ternalHttpServiceServlet.service(HttpServerManager.java:269)
at org.mortbay.jetty.servlet.ServletHolder.handle(ServletHolder .java:428)
at org.mortbay.jetty.servlet.ServletHandler.dispatch(ServletHan dler.java:677)
at org.mortbay.jetty.servlet.ServletHandler.handle(ServletHandl er.java:568)
at org.mortbay.http.HttpContext.handle(HttpContext.java:1530)
at org.mortbay.http.HttpContext.handle(HttpContext.java:1482)
at org.mortbay.http.HttpServer.service(HttpServer.java:909)
at org.mortbay.http.HttpConnection.service(HttpConnection.java: 820)
at org.mortbay.http.HttpConnection.handleNext(HttpConnection.ja va:986)
at org.mortbay.http.HttpConnection.handle(HttpConnection.java:8 37)
at org.mortbay.http.SocketListener.handleConnection(SocketListe ner.java:245)
at org.mortbay.util.ThreadedServer.handle(ThreadedServer.java:3 57)
at org.mortbay.util.ThreadPool$PoolThread.run(ThreadPool.java:5 34)
!ENTRY org.eclipse.update.configurator 4 0 2008-12-12 12:38:26.750
!MESSAGE Could not rename configuration temp file
!SESSION 2008-12-12 12:44:51.234 -----------------------------------------------
GC - 20071031_AA
!ENTRY org.eclipse.mat.ui 1 0 2008-12-12 12:45:56.531
!MESSAGE Took 22,891ms to get the DTFJ image from file C:\IBM_Watson\eclipse\UDAT_Startup_20081212.5896.dmp.zip
!ENTRY org.eclipse.mat.ui 1 0 2008-12-12 12:45:58.593
!MESSAGE Found 315,503 identifers, 310,291 objects, 5,212 classes
!ENTRY org.eclipse.mat.ui 2 0 2008-12-12 12:45:58.843
!MESSAGE Invalid static field VARIABLE_STACK of type B found in class org/apache/derby/impl/services/bytecode/CodeChunk at address 0x4d3fdc8
!STACK 0
com.ibm.dtfj.image.CorruptDataException: parse error
at com.ibm.dtfj.java.j9.JavaStaticField.parse(JavaStaticField.j ava:92)
at com.ibm.dtfj.java.j9.JavaStaticField.getByte(JavaStaticField .java:55)
at com.ibm.dtfj.java.j9.JavaField.get(JavaField.java:62)
at org.eclipse.mat.dtfj.DTFJIndexBuilder.genClass(DTFJIndexBuil der.java:3091)
at org.eclipse.mat.dtfj.DTFJIndexBuilder.fill(DTFJIndexBuilder. java:681)
at org.eclipse.mat.parser.internal.SnapshotFactoryImpl.parse(Sn apshotFactoryImpl.java:184)
at org.eclipse.mat.parser.internal.SnapshotFactoryImpl.openSnap shot(SnapshotFactoryImpl.java:102)
at org.eclipse.mat.snapshot.SnapshotFactory.openSnapshot(Snapsh otFactory.java:87)
at org.eclipse.mat.ui.snapshot.ParseHeapDumpJob.run(ParseHeapDu mpJob.java:54)
!ENTRY org.eclipse.mat.ui 2 0 2008-12-12 12:45:58.937
!MESSAGE Invalid static field DISPID_PROPERTYPUT of type S found in class org/eclipse/swt/internal/ole/win32/COM at address 0x4319a08
!STACK 0
at com.ibm.dtfj.java.j9.JavaStaticField.getShort(JavaStaticFiel d.java:87)
at com.ibm.dtfj.java.j9.JavaField.get(JavaField.java:66)
!ENTRY org.eclipse.mat.ui 2 0 2008-12-12 12:45:58.953
!MESSAGE Invalid static field VARIANT_TRUE of type S found in class org/eclipse/swt/internal/ole/win32/COM at address 0x4319a08
!STACK 0
!ENTRY org.eclipse.mat.ui 2 0 2008-12-12 12:45:59.078
!MESSAGE Invalid static field LIST_MASK of type S found in class org/apache/xerces/impl/dtd/DTDGrammar at address 0x4cff948
!STACK 0
!ENTRY org.eclipse.mat.ui 2 0 2008-12-12 12:45:59.687
!MESSAGE Invalid static field NOT_PRIMITIVE of type B found in class org/apache/derby/iapi/types/JSQLType at address 0x4edef28
!STACK 0
!ENTRY org.eclipse.mat.ui 2 0 2008-12-12 12:45:59.890
!MESSAGE Invalid static field DIRECTIONALITY_UNDEFINED of type B found in class java/lang/Character at address 0x1f108a8
!STACK 0
!ENTRY org.eclipse.mat.ui 2 0 2008-12-12 12:45:59.921
!MESSAGE Invalid static field MIN_VALUE of type S found in class java/lang/Short at address 0x1f3a800
!STACK 0
!ENTRY org.eclipse.mat.ui 2 0 2008-12-12 12:46:00.062
!MESSAGE Invalid static field TAG_CONTEXT of type B found in class com/ibm/security/util/DerValue at address 0x235e798
!STACK 0
!ENTRY org.eclipse.mat.ui 2 0 2008-12-12 12:46:00.078
!MESSAGE Invalid static field TAG_PRIVATE of type B found in class com/ibm/security/util/DerValue at address 0x235e798
!STACK 0
!ENTRY org.eclipse.mat.ui 2 0 2008-12-12 12:46:00.140
!MESSAGE Invalid static field MIN_VALUE of type B found in class java/lang/Byte at address 0x1f3a408
!STACK 0
!ENTRY org.eclipse.mat.ui 2 0 2008-12-12 12:46:00.156
!MESSAGE Invalid static field XML_VERSION_ERROR of type S found in class org/apache/xerces/impl/Constants at address 0x2ff65a8
!STACK 0
!ENTRY org.eclipse.mat.ui 2 0 2008-12-12 12:46:00.250
!MESSAGE Invalid static field ESCAPE_BYTE of type B found in class com/ibm/security/util/text/Utility at address 0x247e360
!STACK 0
!ENTRY org.eclipse.mat.ui 1 0 2008-12-12 12:46:01.203
!MESSAGE Possible problem reading native stack frame number 2 at 0x7530 estimated size 256 for thread 0x10513108 so conservative garbage collection roots may be missing
!STACK 0
com.ibm.dtfj.image.MemoryAccessException
at com.ibm.dtfj.image.j9.ImageAddressSpace.readPointerAtIndex(I mageAddressSpace.java:82)
at com.ibm.dtfj.image.j9.ImagePointer.getPointerAt(ImagePointer .java:85)
at org.eclipse.mat.dtfj.DTFJIndexBuilder.searchFrame(DTFJIndexB uilder.java:2645)
at org.eclipse.mat.dtfj.DTFJIndexBuilder.scanImageThread(DTFJIn dexBuilder.java:1547)
at org.eclipse.mat.dtfj.DTFJIndexBuilder.fill(DTFJIndexBuilder. java:880)
!ENTRY org.eclipse.mat.ui 1 0 2008-12-12 12:46:01.218
!MESSAGE Possible problem reading native stack frame number 2 at 0xea60 estimated size 256 for thread 0x1029dca8 so conservative garbage collection roots may be missing
!STACK 0
!MESSAGE Possible problem reading native stack frame number 2 at 0xea60 estimated size 256 for thread 0x102a89b8 so conservative garbage collection roots may be missing
!STACK 0
!MESSAGE Possible problem reading native stack frame number 2 at 0x2710 estimated size 256 for thread 0x102c9a88 so conservative garbage collection roots may be missing
!STACK 0
!ENTRY org.eclipse.mat.ui 1 0 2008-12-12 12:46:04.625
!MESSAGE Object of type java.io.FileInputStream at 0x100772f8 is presumed to be finalizable so has been marked as a GC root
!MESSAGE Object of type java.io.FileInputStream at 0x1010b2a0 is presumed to be finalizable so has been marked as a GC root
!ENTRY org.eclipse.mat.ui 1 0 2008-12-12 12:46:04.640
!MESSAGE Object of type java.io.FileOutputStream at 0x10461910 is presumed to be finalizable so has been marked as a GC root
!MESSAGE Object of type java.io.FileInputStream at 0x10484478 is presumed to be finalizable so has been marked as a GC root
!MESSAGE Object of type java.io.FileInputStream at 0x1048e8d0 is presumed to be finalizable so has been marked as a GC root
!MESSAGE Object of type java.io.FileInputStream at 0x1048e930 is presumed to be finalizable so has been marked as a GC root
!MESSAGE Object of type java.io.FileInputStream at 0x1048ed40 is presumed to be finalizable so has been marked as a GC root
!MESSAGE Object of type java.io.FileOutputStream at 0x1048f640 is presumed to be finalizable so has been marked as a GC root
!MESSAGE Object of type java.io.FileInputStream at 0x1048fb40 is presumed to be finalizable so has been marked as a GC root
!ENTRY org.eclipse.mat.ui 1 0 2008-12-12 12:46:04.656
!MESSAGE Object of type java.io.FileOutputStream at 0x1049f7c0 is presumed to be finalizable so has been marked as a GC root
!MESSAGE Object of type java.io.FileInputStream at 0x1049fd68 is presumed to be finalizable so has been marked as a GC root
!MESSAGE Object of type java.io.FileInputStream at 0x104a0158 is presumed to be finalizable so has been marked as a GC root
!MESSAGE Object of type java.io.FileInputStream at 0x104a0fe0 is presumed to be finalizable so has been marked as a GC root
!MESSAGE Object of type java.io.FileInputStream at 0x104a1468 is presumed to be finalizable so has been marked as a GC root
!MESSAGE 14 finalizable objects marked as extra GC roots
!ENTRY org.eclipse.mat.ui 1 0 2008-12-12 12:46:04.671
!MESSAGE Using DTFJ root support with 1,352 roots
!MESSAGE Took 8,187ms to parse the DTFJ image file C:\IBM_Watson\eclipse\UDAT_Startup_20081212.5896.dmp.zip
!ENTRY org.eclipse.mat.ui 1 0 2008-12-12 12:46:07.718
!MESSAGE Purged 2,104 identifiers using 128,920 bytes
!ENTRY org.eclipse.mat.ui 1 0 2008-12-12 13:11:54.399
!MESSAGE Took 5,328ms to get the DTFJ image from file C:\IBM_Watson\eclipse\UDAT_ConceptFinder_20081212.5896.dmp.z ip
!ENTRY org.eclipse.mat.ui 1 0 2008-12-12 13:12:13.446
!MESSAGE Found 3,629,906 identifers, 3,623,353 objects, 6,553 classes
!ENTRY org.eclipse.mat.ui 2 0 2008-12-12 13:12:17.461
!STACK 0
!ENTRY org.eclipse.mat.ui 2 0 2008-12-12 13:12:19.102
!STACK 0
!ENTRY org.eclipse.mat.ui 2 0 2008-12-12 13:12:21.461
!STACK 0
!ENTRY org.eclipse.mat.ui 2 0 2008-12-12 13:12:21.914
!STACK 0
!ENTRY org.eclipse.mat.ui 2 0 2008-12-12 13:12:22.383
!STACK 0
!STACK 0
!ENTRY org.eclipse.mat.ui 2 0 2008-12-12 13:12:22.539
!STACK 0
!ENTRY org.eclipse.mat.ui 2 0 2008-12-12 13:12:22.570
!STACK 0
!ENTRY org.eclipse.mat.ui 2 0 2008-12-12 13:12:22.742
!STACK 0
!ENTRY org.eclipse.mat.ui 2 0 2008-12-12 13:12:23.304
!STACK 0
!STACK 0
!ENTRY org.eclipse.mat.ui 2 0 2008-12-12 13:12:23.742
!MESSAGE Invalid static field MAGIC1 of type B found in class com/ibm/icu/impl/ICUBinary at address 0x60a95a8
!STACK 0
!ENTRY org.eclipse.mat.ui 2 0 2008-12-12 13:12:24.508
!MESSAGE Invalid static field lastCount of type S found in class java/rmi/server/UID at address 0x5dbcc08
!STACK 0
!ENTRY org.eclipse.mat.ui 2 0 2008-12-12 13:12:24.664
!STACK 0
!ENTRY org.eclipse.mat.ui 1 0 2008-12-12 13:12:26.414
!MESSAGE Possible problem reading native stack frame number 2 at 0xea60 estimated size 256 for thread 0x1029d7f0 so conservative garbage collection roots may be missing
!STACK 0
!ENTRY org.eclipse.mat.ui 1 0 2008-12-12 13:12:26.429
!MESSAGE Possible problem reading native stack frame number 2 at 0xea60 estimated size 256 for thread 0x102a8048 so conservative garbage collection roots may be missing
!STACK 0
!ENTRY org.eclipse.mat.ui 1 0 2008-12-12 13:12:26.445
!MESSAGE Possible problem reading native stack frame number 2 at 0x2710 estimated size 256 for thread 0x102c9018 so conservative garbage collection roots may be missing
!STACK 0
!ENTRY org.eclipse.mat.ui 2 0 2008-12-12 13:13:01.271
!MESSAGE Problem getting outbound references for object at 0x14e6d4f8
!STACK 0
com.ibm.dtfj.image.CorruptDataException: Unable to retrieve component type for array: [F
at com.ibm.dtfj.java.j9.JavaArrayClass.getComponentType(JavaArr ayClass.java:127)
at org.eclipse.mat.dtfj.DTFJIndexBuilder.isPrimitiveArray(DTFJI ndexBuilder.java:2911)
at org.eclipse.mat.dtfj.DTFJIndexBuilder.exploreArray(DTFJIndex Builder.java:2815)
at org.eclipse.mat.dtfj.DTFJIndexBuilder.processHeapObject(DTFJ IndexBuilder.java:1414)
at org.eclipse.mat.dtfj.DTFJIndexBuilder.fill(DTFJIndexBuilder. java:1088)
!ENTRY org.eclipse.mat.ui 2 0 2008-12-12 13:13:03.474
!MESSAGE Problem getting outbound references for object at 0x15420008
!STACK 0
com.ibm.dtfj.image.CorruptDataException: Unable to retrieve component type for array: [I
!ENTRY org.eclipse.mat.ui 2 0 2008-12-12 13:13:09.411
!MESSAGE Problem getting outbound references for object at 0x160ffc38
!STACK 0
com.ibm.dtfj.image.CorruptDataException: Unable to retrieve component type for array: [B
!ENTRY org.eclipse.mat.ui 2 0 2008-12-12 13:13:10.349
!MESSAGE Problem getting outbound references for object at 0x1681e5d8
!STACK 0
!MESSAGE Problem getting outbound references for object at 0x1681e638
!STACK 0
com.ibm.dtfj.image.CorruptDataException: Unable to retrieve component type for array: [Ljava/lang/String;
!MESSAGE Problem getting outbound references for object at 0x1681e688
!STACK 0
!ENTRY org.eclipse.mat.ui 2 0 2008-12-12 13:13:10.380
!MESSAGE Problem getting outbound references for object at 0x16b462a8
!STACK 0
!ENTRY org.eclipse.mat.ui 2 0 2008-12-12 13:13:10.396
!MESSAGE Corrupt data reading objects from heaps at null : Unknown class ID 370149280 from Java runtime 0x87ee8
!MESSAGE Problem getting outbound references for object at 0x16c82b90
!STACK 0
!ENTRY org.eclipse.mat.ui 2 0 2008-12-12 13:13:10.411
!MESSAGE Problem getting outbound references for object at 0x16c82bc8
!STACK 0
!ENTRY org.eclipse.mat.ui 2 0 2008-12-12 13:13:10.427
!MESSAGE Problem getting outbound references for object at 0x16ca2a00
!STACK 0
com.ibm.dtfj.image.CorruptDataException: Unable to retrieve component type for array: [C
!ENTRY org.eclipse.mat.ui 2 0 2008-12-12 13:13:10.443
!MESSAGE Problem getting outbound references for object at 0x16ca4900
!STACK 0
!ENTRY org.eclipse.mat.ui 1 0 2008-12-12 13:13:11.286
!MESSAGE Object of type java.io.FileOutputStream at 0x10bf4aa8 is presumed to be finalizable so has been marked as a GC root
!MESSAGE Object of type java.io.FileInputStream at 0x10c11700 is presumed to be finalizable so has been marked as a GC root
!MESSAGE Object of type java.io.FileOutputStream at 0x10c1c940 is presumed to be finalizable so has been marked as a GC root
!MESSAGE Object of type java.io.FileInputStream at 0x10c1e4e8 is presumed to be finalizable so has been marked as a GC root
!MESSAGE Object of type java.io.FileOutputStream at 0x10e9c948 is presumed to be finalizable so has been marked as a GC root
!MESSAGE Object of type org.apache.uima.analysis_engine.impl.AggregateAnalysisEngine _impl at 0x10eaad38 is presumed to be finalizable so has been marked as a GC root
!ENTRY org.eclipse.mat.ui 1 0 2008-12-12 13:13:11.302
!MESSAGE Object of type java.io.FileInputStream at 0x10eac5f8 is presumed to be finalizable so has been marked as a GC root
!MESSAGE Object of type java.io.FileOutputStream at 0x10f77040 is presumed to be finalizable so has been marked as a GC root
!MESSAGE Object of type java.io.FileInputStream at 0x10f841c0 is presumed to be finalizable so has been marked as a GC root
!MESSAGE Object of type java.io.FileInputStream at 0x10f97060 is presumed to be finalizable so has been marked as a GC root
!MESSAGE Object of type java.io.FileOutputStream at 0x10f973c0 is presumed to be finalizable so has been marked as a GC root
!MESSAGE Object of type java.io.FileInputStream at 0x10f9a608 is presumed to be finalizable so has been marked as a GC root
!MESSAGE Object of type java.io.FileOutputStream at 0x1105f248 is presumed to be finalizable so has been marked as a GC root
!ENTRY org.eclipse.mat.ui 1 0 2008-12-12 13:13:11.318
!MESSAGE Object of type java.io.FileOutputStream at 0x110a0878 is presumed to be finalizable so has been marked as a GC root
!MESSAGE Object of type java.io.FileInputStream at 0x11377c58 is presumed to be finalizable so has been marked as a GC root
!MESSAGE Object of type java.io.FileOutputStream at 0x11378980 is presumed to be finalizable so has been marked as a GC root
!MESSAGE Object of type java.io.FileInputStream at 0x11a5ed70 is presumed to be finalizable so has been marked as a GC root
!ENTRY org.eclipse.mat.ui 1 0 2008-12-12 13:13:11.333
!MESSAGE Object of type java.io.FileOutputStream at 0x14684260 is presumed to be finalizable so has been marked as a GC root
!MESSAGE Object of type java.io.FileInputStream at 0x150fde50 is presumed to be finalizable so has been marked as a GC root
!ENTRY org.eclipse.mat.ui 1 0 2008-12-12 13:13:11.427
!MESSAGE Object of type java.io.FileOutputStream at 0x160a9ae0 is presumed to be finalizable so has been marked as a GC root
!ENTRY org.eclipse.mat.ui 1 0 2008-12-12 13:13:11.443
!MESSAGE 42 finalizable objects marked as extra GC roots
!MESSAGE Using DTFJ root support with 1,569 roots
!ENTRY org.eclipse.mat.ui 2 0 2008-12-12 13:13:11.443
!MESSAGE 22 repeated messages have been suppressed
!MESSAGE Took 77,044ms to parse the DTFJ image file C:\IBM_Watson\eclipse\UDAT_ConceptFinder_20081212.5896.dmp.z ip
!ENTRY org.eclipse.mat.ui 4 0 2008-12-12 13:13:12.739
!MESSAGE 3,623,353 objects found but 6,553 classes had 3,626,530 objects in total
!ENTRY org.eclipse.mat.ui 1 0 2008-12-12 13:13:44.238
!MESSAGE Purged 851,971 identifiers using 22,015,960 bytes
!ENTRY org.eclipse.core.jobs 4 2 2008-12-12 13:13:44.738
!MESSAGE An internal error occurred during: "Pars
Re: MAT + DTFJ Crash on re-opening extracted zip [message #8315 is a reply to message #8152] Tue, 16 December 2008 00:27 Go to previous message
See now the thread "freshly-installed MAT+DTFJ unable to read any
extracted DMP-files" ...
Previous Topic:Review Results for Memory Analyzer 0.7 Release Review
Next Topic:freshly-installed MAT+DTFJ unable to read any extracted DMP-files
Current Time: Sat Jul 12 19:21:50 EDT 2025
Powered by FUDForum. Page generated in 0.04046 seconds
