Home » Archived » BIRT » PDF generation and saving
PDF generation and saving [message #90599] Mon, 14 November 2005 07:59 Go to next message
Originally posted by: jake.westviewclose.co.uk
Hi, I'm after a bit of advice / help?
I've been through the old newsgroup emails and the help site, but i'm
not 100% clear on what i need to do next.
Basically, I've built a report in BIRT that I want to execute
automatically as a PDF and save to file.
The best way I can think of is to create some Java code to execute the
report, and save it (examples of which seem to be available in the
newsgroup emails). However, this code relies on the Report Engine being
enabled on the application server(ie Tomcat or somesuch). (I'm out of my
depth at this point).
I'm just working on a standalone PC. So there is no application server
as such?
Maybe i could pull in the report engine jar from the runtime download?
or something like that?
I really have no idea what i'm doing, and whilst i assume its possible,
would really appreciate some advice.
Thanks greatly for anyones help.
Jake
Re: PDF generation and saving [message #90629 is a reply to message #90599] Mon, 14 November 2005 08:19 Go to previous messageGo to next message
have a look at the online help within eclipse:
Menu Help-->Help contents
then open 'BIRT Developer Guide'
then open 'Field Guide to BIRT'
then open 'Programming with the BIRT reporting APIs'
then open 'Generating reports from an application'
may thats what you are looking for?
hth,
best regards, mr. Burns
Re: PDF generation and saving [message #90731 is a reply to message #90629] Mon, 14 November 2005 10:00 Go to previous messageGo to next message
Mr Burns.
Again thanks for your help. I had read through those pages, but i wasn't
even sure they applied to what I was doing.
With your help I've now got a little java program that runs the report
and save's itself to my hard-drive, and then triggers off an email
program that emails it to a friend. I'm going to wrap it in a little exe
and put it in the task scheduler.....no more messing around in the
evening for me....my PC is doing all the work.
Thanks again for your guiding hand.
Jake
Mr. Burns wrote:
> Hello,
> hth,
Re: PDF generation and saving [message #90765 is a reply to message #90731] Mon, 14 November 2005 10:50 Go to previous message
You're welcome!
Previous Topic:Problem with page top margin
Next Topic:Multiples PageMasters
Current Time: Fri Jul 18 05:57:24 EDT 2025
Powered by FUDForum. Page generated in 0.29580 seconds
