Home » Language IDEs » Java Development Tools (JDT) » smart cursoring through java names doesn't work on prev-word
smart cursoring through java names doesn't work on prev-word [message #90558] Fri, 29 August 2003 00:27 Go to next message
Originally posted by: leeb.linkline.com
Using 3.0 M3. The new "smart cursoring through java CamelCase names" only
seems to work in the forward direction (Ctrl-RightArrow), but does not work
in the backward direction (Ctrl-LeftArrow). Is this as-designed?
Re: smart cursoring through java names doesn't work on prev-word [message #90575 is a reply to message #90558] Fri, 29 August 2003 00:44 Go to previous messageGo to next message
Hm... Works in build 200308261317.
However I hate this feature. This is not usually for me to change name of
variable, so I don't need to skip part of it. But often I need to skip it
wholly, but now this is impossible. :-(
Is it possible to add option in preference?
SY, Konstantin.
Advanced Eclipse SWT Designer (http://www.swt-designer.com)
Re: smart cursoring through java names doesn't work on prev-word [message #90635 is a reply to message #90575] Fri, 29 August 2003 03:54 Go to previous messageGo to next message
AFAIR there is a setting in the Work in Progress tab.
But I could be wrong, just downloading M3.
martin
Re: smart cursoring through java names doesn't work on prev-word [message #90680 is a reply to message #90635] Fri, 29 August 2003 05:58 Go to previous messageGo to next message
Originally posted by: tom.eicher.gmx.ch.nodomain
Its in the Preferences, Java->Editor->Typing Tab, "Smart cursor
positioning in Java names"
-t
> martin
Re: smart cursoring through java names doesn't work on prev-word [message #90695 is a reply to message #90575] Fri, 29 August 2003 06:03 Go to previous messageGo to next message
No. It should work in both directions. In some cases it does not work
correctly (see bug 42199
<https://bugs.eclipse.org/bugs/show_bug.cgi?id=42199>) and Martin is
right, you can disable the feature,
HTH
Dani
No, because then we have it twice since it is already there ;-) See
Window > Preferences > Java > Editor > Typing
HTH
Dani
Re: smart cursoring through java names doesn't work on prev-word [message #90708 is a reply to message #90635] Fri, 29 August 2003 06:40 Go to previous messageGo to next message
Thanks, I found it.
SY, Konstantin.
Re: smart cursoring through java names doesn't work on prev-word [message #90753 is a reply to message #90695] Fri, 29 August 2003 09:16 Go to previous message
Ah, indeed I was running into bug 42199. I tried it some more and see that
it does work correctly for most identifiers.
Lee
"Daniel Megert" <daniel.megert@gmx.net> wrote in message
news:bin8cv$c29$1@eclipse.org...
only
work
> HTH
> Dani
of
> HTH
> Dani
Previous Topic:tooltips for primary variables
Next Topic:Ant View hangs from time to time
Current Time: Wed Aug 13 12:19:25 EDT 2025
Powered by FUDForum. Page generated in 0.12725 seconds
